Re: Ratdude's Main rig V3.5
3+ HDDs in RAID 0 rox!
So you're using three in RAID0? I would personally find an HDTune benchy interesting?Leave a comment:
Installed the card reader icon pack from AFT, rebooted, seems to be working again.
Doing some cable cleanup, will take pics.Leave a comment:
Here's some HDD pictures:
The good drives have stickers that say "D1":
While the two failed ones have blank stickers:
I swore a saw a granular like texture under the clear plastic parts of the stickers... which almost makes me think it's some sort of shock/failure dector somehow.
It could also be a coinicdance. I have no idea... any thoughts?
PS- It seems my new card reaser has already shat on me... won't see my XD M+ card. Given it's a newer reader, It's probably toast and needs RMA'd?Leave a comment:
The replacement HDD for the replacement HDD that died came in. Oddly, it's seal stickers match the other 3... and no bad sectors. No pending sectors. perfect health.
So far so good... which leads me to wonder if the "D1" marks on the good drive's stickers means something... Very odd indeed.Leave a comment:
With /LARGEADDRESSAWARE 32bit programs can use 4GB on 64bit Windows.
And we're off topic again >.< (sorry RD!)Leave a comment:
edit- already working on a new drive, bought a HL DVD RW with lightscribe for $17 on fleabay.Last edited by ratdude747; 08-02-2013, 03:22 PM.Leave a comment:
Damn, you seem to have horrible luck this time around.
Perhaps the drive was banged around during shipping?Leave a comment:
most of the time blue ray drives come with a copy of a full blown player of some sort, cyberlink or whatnot. Mine didLeave a comment:
(drumroll)
The issue is... a faulty drive!
I placed the port 2 drive in port 3, and all was well... I'm going to try for a refund and lok for another drive yet again.
Why does my luck suck so bad?
Edit- Not convinced on the Blu-ray drive... as w/o the software disc, the blu-ray is useless for movies... not even K-lite is any good. Looks like the only way to make it work to buy new (since the used ones with the SW disc are nearly as much $$$) F*ck that, I'll just get a light scribe DVD+RW w/o blu-ray and call it good.Last edited by ratdude747; 08-02-2013, 01:27 AM.Leave a comment:
Installed the 4th hdd to the 3ware card, it appears dead. Not even the mobo's own controller detects it.
I'm about to test the card by plugging another drive into port 3 of the card... backign up data first. Let's hope it doesn't die... otherwise I have a drive killer card and only two good drives (and a main rig 3.5 that's presumably cursed).Leave a comment:
The discs are weird... they're student/facualty editions of 7 ultimate... but the COA's are upgrade.
I hate to bump, but bump my last post's Q. I only have 48 hours before my offer expires... so if you know if those drives are any good, speak up.Leave a comment:
You only need that existing Windows install thing when using the retail upgrade versions, AFAIK.
Typical of folks getting Windows from Walmart.....
That's why it was a PITA when I was trying out Vista back in early 2008.
And for the retail version, also be prepared to get treated like a criminal for upgrading your hardware, too.....Leave a comment:
Bottom outted off at 45 on the drive. Take it?Leave a comment:
Here's some more parts:
I made an offer on this:
http://www.ebay.com/itm/LG-WH08LS20-...torefresh=true
That's like everything I'd want in a drive. Seriously. My eventual goal was to have both blueray and lightscribe, and given that I already have a SATA burner with neither, IMHO it's a better idea to kill two birds with one stone. Yeah, I probably won't be using blueray all the time (I don't own any BD drives or discs), but I figured it may come in handy down the road... And lightscribe, I have a bunch of lightscirbe DVD+R's that I have a use for... V2 has a lightscribe drive, so I figure V3 ought to as well (other wise I'm stuck using my slow external one).
Ordering this:
http://www.newegg.com/Product/Produc...82E16820176012
I've always been an AFT fan... V2's case and final reader was an AFT. I also considered the $16 more kiosk model, but it's too much $ more, too colorful, and has the annoying connector design in the back (V2's has that, didn't like it).
Comments/ideas? And if you have a SATA burner with lightscribe and/or Blueray (BD-RW is a plus), let me know.Leave a comment:
And for the retail version, also be prepared to get treated like a criminal for upgrading your hardware, too.....Last edited by RJARRRPCGP; 07-31-2013, 08:44 PM.Leave a comment:
Take a look at method 2 from here: http://winsupersite.com/article/wind...e-media-128512
That's all you need to do to get Windows 7 upgrade disks activated. A frend of mine worked for MS back in 2009 (when 7 was released) and they pretty much helped everyone who called in for this sort of activation issue. They even used the registry fix found in the link above.Last edited by ratdude747; 07-31-2013, 08:22 PM.Leave a comment:
The former- I'm working on that, I know.
The latter- they're legit upgrade discs, since I have a valid student ID (I am a student at the college) I can get win 7 upgrade discs for $20 a pop. The reason I don't just use another disc and skip activation till I find it is since it's an upgrade, the COA key won't work (you have to have had xp/vista on the hdd used for the install when windows setup begins). Not like XP and 2K, when the upgrade disc was a different image and one could be prompted to insert a previous windows disc to prove the upgrade.
That's all you need to do to get Windows 7 upgrade disks activated. A frend of mine worked for MS back in 2009 (when 7 was released) and they pretty much helped everyone who called in for this sort of activation issue. They even used the registry fix found in the link above.Leave a comment:
by DobrowolHello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
Steps i done and results:
I exported a clean bios from update file via pfs extract.
1. Build clean bios with clean ME, PMC, PCH in flash image tool.
Result: Dead
2. Build clean bios with no changes in ME, new PMC, PCH
Result: Dead
3. Build old bios with clean ME, new PMC, PCH
Result: The same
Channel: BIOS Requests ONLY!
This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...09-12-2024, 03:28 PM
by iotaaHi,
You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
This sound can be manually triggered by me if I'm inside the van, or played automatically... -
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... - Loading...
