do you guys think its OK to recycle capacitors and the like? ive got a bunch of scrap boards with rubycons and etc on them
Recycling parts
Re: Recycling parts
If they are a reliable brand, then yes, I sometimes re-use them for older boards. If they are KZG or something, then if they get taken off at all, it's just to put them in a fire.
One thing to bear in mind is that the cap will no longer be able to handle its rated voltage. They become conditioned to whatever voltage they get in the circuit. So, if you pull a 6.3V cap off a 1.5V VRM, it's now only a 1.5V cap.Last edited by c_hegge; 06-28-2013, 08:59 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Re: Recycling parts
I always recommend against reusing caps from one board to the other, especially motherboards. Even good brands that are years old will have a great degree of degradation, especially those of the ultra-low ESR variety. You're always better off getting new replacements, as the used ones may not be much better off than the ones you're taking out.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Re: Recycling parts
Usually, the good capacitor brands like Panasonic, Rubycon, Nichicon, Chemicon, and Sanyo I will reuse with confidence (except for Chemicon KZG/KZJ).
The unreliable brands (pretty much everything else) I may reuse, but only if they aren't bulged, haven't been overheated, and show good ESR on an ESR meter or pass my "spark" test. And of course, I may only use those for a test/temporary repair. Nothing long term unless I really don't care about the hardware I'm repairing and just want to get it going again. One place where I often use the unreliable brands is when I'm building/testing some circuit on my breadboard and need filtering capacitors.
And then there's the "never-use" unreliable brands on my list - Sacon FZ (they like to pop violently for no reason), Rulycon, problematic Nichicon HM/HN with 2001-2004 datecodes, and probably a few others I can't remember right now.
Originally posted by c_heggeOne thing to bear in mind is that the cap will no longer be able to handle its rated voltage. They become conditioned to whatever voltage they get in the circuit. So, if you pull a 6.3V cap off a 1.5V VRM, it's now only a 1.5V cap.Comment
Re: Recycling parts
Let me tell you, I tried recycling some parts to repair one of my monitors but I didn't fully test them.
That monitor is failing once again with symptoms of bad capacitors. It's not too bad yet, but I will have to take it apart again.Comment
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
by 2elwHey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
GW1N-UV9UG169C6/I5 FPGA - Its a...07-04-2025, 12:23 PM -
I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
by DynaxSCHi,
I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
Thanks in advance... -
by lorins_coreHello to all.
may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
I need some good advice and also some information about it. thank you and God Bless... - Loading...
