is f@h still happening?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    it was started in 2000 and i sort of want to join in but i don't know if its a dead project or not, so is it still going?
    Follow the white rabbit.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: is f@h still happening?
    IIRC yes. I haven't been folding in a long time though, due to the last rig overheating and thermal throttling over it. As for the upcoming rig, I may have to try it.
    sigpic
    (Insert witty quote here)
    • Sweet & Spicy
      Techie's Wife
      • Apr 2013
      • 281
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        https://www.badcaps.net/forum/showthread.php?t=1277
        • Sweet & Spicy
          Techie's Wife
          • Apr 2013
          • 281
          oh. Thanks. Un-confused now.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Yeah I recently started folding again. WTF else would I do with all my i7's and high end GPUs since I'm barely ever home and work full time now LOL.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              I would fold more often but the cooling solution on my GPU leaves much to be desired.
              my cpu only pulls low numbers.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                my F@H stopped getting work units again the other day....second time its done this in the last few months..... Last time, updating the SMP client fixed it. Haven't worked on it this time yet, havent had time.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Shut down my folding machine since it's too damn hot right now.
                  • cheapie
                    null
                    • Jul 2010
                    • 849
                    I just started it up 15 minutes ago. It's still reading "Running 0.00%" for both CPU and GPU. I'll have to check it after work and see if it's done anything by then.
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      I run it on my machine at work 24/7. At home, I'll run it 24/7 in the winter, and sparingly in the summer.
                      As a team, we're not doing too bad... If I had the resources, I would run it more... but a/c is expensive.
                      Ludicrous gibs!
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        well its refusing to connect so i guess no f@h for me *sigh*
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          I may start folding again once the summer is up. Last thing I want is more heat in my room!
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Thermal throttling? Sounds like your room was too warm.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              No, it was a cool basement in winter. I put slower fans than stock on the heatsinks, figuring that since I was using a cooler CPU (92W vs 160W IIRC), the drop in RPM's (5K PWM to 3k non-PWM) would be OK. I was wrong... since apparently it couldn't do full time 100%. I've since switched to a pair of 3K-5K temp contolled fans off a set of AMD 940 stock coolers, which seem OK (running at 5K under high load, can't hear it due to the HVAC unit behind me )
                              sigpic
