is this drive bad?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    is this drive bad?
    it randomly locks up during high access situations, its slow to boot,slow to access, and the and the reallocated sector count is through the roof as seen in the pic, so should i clone the disk or is it ok?
    Follow the white rabbit.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: is this drive bad?
    double check that. make sure it's an actual value, use hdat2 or smartctl
    If that is the actual value, you have a failing drive. I don't know how it managed to survive that long, backup data!!!
    Once you back up data, then you can try cloning the disk, my guess is and I have done this before with a failing toshiba drive using clonezilla, that it will most likely throw device not ready or failed to read errors and won't be clone-able.
    • 1supertech
      • Apr 2012
      • 384
      hd tune is good & free it scans your drive for bad sectors
      http://www.hdtune.com/
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        only 2 bad sectors so the drive is ok? also the uncorrectable error rate it through the roof at 1932752060422 errors as reported by smartctl, is that bad?
        hd tune is for linux to!?
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          sounds like it might have a bad board/cache
          • gg1978
            • Dec 2004
            • 431
            it is shot/dying either way.. If there's something important on there i'd use ddrescue to get it, as it'll get everything it can if there are ungettable sectors on the disk.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              all the bad sectors are in the swap partition so all the data is intact. i hope
              • cheapie
                null
                • Jul 2010
                • 849
                Reallocated + Pending sectors = "Bad" Sectors
                0 = OK
                1-10 = Keep an eye on it
                11-50 = Don't use it for anything important (swap or whatever probably OK)
                51+ = Back up IMMEDIATELY and do not use
                (In my opinion, anyway)
                Not good.
                its slow to boot
                Might not be the drive, not good if it is.
                slow to access
                I would turn that drive into a speaker or something.
                so should i clone the disk or clone the disk?
                FTFY.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  0 = OK
                  0-2 = ok for me.
                  Not good.
                  just browsing the web with chrome lockedup the drive.
                  tryed with THREE os'es all slow to boot
                  the seven other drives in the machine access 7 times faster than this drive
                  hmm. dubstep would sound good on that.
                  FTFY.
                  didn’t clone. so i grabbed a list of software installed with this command
                  Code:
                  $ dpkg --get-selections > /ihopethisworks/software.list
                  and copy my whole homedir to the new home-partition then re-installed my os'es. *sigh* now i have to go thru the tedius process of adding repository back. ah well at least it wasn’t RAID
                  heck it wasnt 5 minuts after i copied my homdir that i was getting a "drive inaccessible" error.
                  thanks everybody for your help you saved my but.
                  • madura2010
                    DAY11AM6E0 hard disk drive and optical disk drive not detected
                    by madura2010
                    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                    i checked the connectivity of ribbon=good communication with hard and motherboard
                    changed hard disk and checked=3f0 error persist
                    sata power=+5v available
                    Then checked data capacitors=all good
                    Then checked data lines path connectivity to pch=all good
                    reflashed...
                    03-12-2023, 09:09 AM
                  • federalhouse
                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                    by federalhouse
                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                    **Background:**
                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                    **What I've Tried So Far:**
                    1. I accessed
                    08-01-2024, 07:03 PM
                  • reformatt
                    Intel iMacs, 3rd party SSD failures and Fusion setups
                    by reformatt
                    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                    12-18-2024, 10:34 PM
                  • perfm2
                    HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                    by perfm2
                    So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                    Steps taken in my usual process.
                    Reset security settings in the BIOS
                    Ensure existing HD comes up into the OS
                    Shut down the laptop and disconnected the main battery
                    Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                    Replace battery connector and close up the laptop
                    Insert my USB drive with my Windows 10 image I've...
                    03-21-2023, 08:45 PM
                    HP EliteBook 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 1000 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 1050 G1 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                    09-06-2024, 08:50 AM
