how to install xp on ibook g4
  • alihomee
    • Dec 2012
    • 1596
    • malaysia
    i have a ibook g4 model name:ibook g4 model identifier:power book6,7 processor name:power pc g4(1.5) memory:1.5gb system version:mac os x 10.5.8. now i want to install win xp .how can i do it
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: how to install xp on ibook g4
    short answer: no. XP requires an x86 processor
    long answer: yes. Using linux, and installing a virtual copy of XP ontop of that
    or virtual PC 7 on OSX
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      using qemu on linux or BSD.
      or
      virtual pc on OSX works to.
      Follow the white rabbit.
      • alihomee
        • Dec 2012
        • 1596
        • malaysia
        how i can get this vitural pc do u have a link
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5045
          • US
          google is your friend.
          http://www.microsoft.com/en-us/downl...s.aspx?id=7833
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            This has to be a joke.
            Microsift dropped powerpc support after nt 4 and only supported nt 4.
            Even with linux ppc support is hit and miss. No flash support to speak of (unless gnash or lightspark ever started working).
            If wou want to xp a mactop, you'd need a macbook or macbook pro, which are intel based.
            sigpic
            (Insert witty quote here)
            • alihomee
              • Dec 2012
              • 1596
              • malaysia
              so means i cant install xp on ibook g4
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                not DIRECTLY, no
                XP doesn't have powerPC processor support, completely different instruction set
                • mariushm
                  • May 2011
                  • 3799
                  Windows runs only on x86 processors. x86 is an architecture, a type of processors.
                  The Mac is using a PowerPC processor, which is based on another architecture, so Windows can't run on it.
                  To make it easier for you to understand, it's like Windows being a tire. You can install it on various types cars (the x86 architecture) but you can't install it on a truck (Power PC) even though both cars and trucks have wheels.
                  Now... you can install Linux on it, think of Linux like a tire that can stretch a lot and can adapt to various types of vehicles. It just works on various architectures.
                  From there, you could run a Linux software that simulates a computer that could run Windows.
                  The problem is that computer you have is already old, slow, with little memory. The software creating a virtual computer uses processor and memory and will be slow. Inside the virtual computer, Windows will be even slower. it would probably run as if your computer is a 486 or Pentium mmx, very very slow.
                  It's not worth it. Not even mentioning programs because it's pointless.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5045
                    • US
                    actually some people have had fair performance using virtual PC 7 & OSX, but not great
                    • mkdj
                      Acer Swift won't boot after a Linux install
                      by mkdj
                      Dear all,
                      I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                      History and symptoms:
                      A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                      What I have done so far:
                      As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                      10-30-2025, 04:31 AM
                    • ivtec
                      install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                      by ivtec
                      Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                      01-17-2025, 12:54 PM
                    • japlytic
                      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                      by japlytic
                      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                      Tried (only with keyboard/mouse connected):
                      • BIOS + database update
                      • Using latest Windows 11 image built with official image creation tool
                      • Previous setup version for Windows 11 installer
                      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                      06-19-2025, 04:59 PM
                    • 24gsm
                      MacBook Pro A1708 install macos fail
                      by 24gsm
                      hi to all
                      i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                      after enter to recovery and format hdd 1to .
                      after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                      can help please
                      Serial Number: FVFXP0U0HV2J
                      Config Code: HV2J
                      Find My Mac: OFF
                      04-16-2025, 03:57 AM
                    • duwane
                      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                      by duwane
                      Hi All.
                      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                      The issue:
                      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                      10-26-2022, 07:02 AM
