linux image software
  • klkmalik
    seeking Tips
    • Nov 2011
    • 68
    • UAE
    Hi all, anyone know linux image software? I want to take image of linux software
    from flash memory. I dont know which is best and simple use? thank for help.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: linux image software
    How about dd? It should be preinstalled on most distros.
    • gerg
      • Nov 2010
      • 278
      clonezilla
      • Time2Retire
        • Aug 2012
        • 256
        Yes, dd is the way to go. First you need to identify the correct disk.
        Code:
        sudo fdisk -l
        Find the correct device in the output by looking at the sizes of the devices. Then, say it is /dev/sdh, enter this:
        Code:
        sudo dd if=/dev/sdh of=sd_image.img
        Let it run, and it may take a while. This will make an exact copy of the card. If it is a bootable card, that is copied to.
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
