enermax liberty(what kind of caps does it contain?)
  • bignose
    • Nov 2006
    Hello everybody,
    I'm new on this board, so great hello to you all, and i would start by this. i have in my rig a enermax liberty psu,
    and my question is which kind of caps are they using , ( as enermax is really good psu) i'm curious of the caps name,or brand.
    Thank you ,moc vam dekuji.
  • toastygoodness
    • Jul 2005
    • 813
    Re: enermax liberty(what kind of caps does it contain?)
    My enermax liberty has Hitachi input and JPCE-TURs and one UCC output.
    • Shroomie
      • Apr 2006
      • 356
      From what I understand, JPCE's TUR series are pretty common as output caps. They're OK, I believe, not the best though. That's what I have in my Noisetaker, along with Panasonic input.
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • toastygoodness
        • Jul 2005
        • 813
        I've heard that Enermaxs don't fail as much even with the JPCE-TURs because they have much more efficient cooling. Is this true?
        • linuxguru
          • Apr 2005
          • 1564
          If you get the chance, replace those JPce-turs with better caps. While they're not as bad as the truly bad JEE/Rulycon, YEC, Gloria, Chhsi, etc. caps, I've seen a fair number of blown JPce-turs, especially large ones.
          • bignose
            • Nov 2006
            Thank you guys for more infos.
            • mutant
              • Mar 2006
              • 123
              I have the Enermax Liberty ELT620AWT 620 watt and have had it on pretty much 24/7 since April. Very stable so far but I haven't even come close to using its full capacity. That will change with a new video card SLi.
              I took some pics and they are in this thread
              • mutant
                • Mar 2006
                • 123
                Well I pulled these caps out and replaced them with some Rubycons and some Xicons. I may replace the Xicons if I get some better caps.
                These are cTc caps. Whether replacing them helps or not only time will tell but it sounds like the problem with this power supply from what people are saying is a MOSFET or rectifier.
                • starfury1
                  • May 2006
                  • 1256
                  Yeah got mine in bits at the moment
                  CTC's look OK but mine doesn't get a workout.
                  They are appear to be crap caps so keep us posted on how yours goes Mutant
                  neither does mine...
                  Yes the " Flash Bang "Factor
                  cause unknown, and Q5 appears to be one victim
                  (what else is history I don't know)
                  Now a question...do you use an UPS?
                  I am just wondering how many are on an UPS when they die
                  (hoping yours... and mine never do of course )
                  From plywood9's post over at Xtreme seems the 500 and 400 are victims to according to one post
                  So that does not Bode well for Liberty range at all
                  (seems Enermax my have really dropped the ball with that range)
                  So The line up for the caps is
                  4 X 3300 uf 10V
                  2 X 3000 uf 16V
                  1 X 1500 uf 10V
                  1 X 1000 uf 10V
                  Cheers
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
                  • Foetuss
                    Gigabyte GA-6OXT :: caps question
                    by Foetuss
                    Good evening
                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                    But I was also suprised about the bigger boys, which are 330µF 25V.
                    Could it be they used 25V caps because they were cheaper / available at that time?...
                    02-11-2025, 12:22 PM
