Empty SPI socket on Foxconn motherboard, will it work?
    Re: Empty SPI socket on Foxconn motherboard, will it work?
    Originally posted by Gabriel View Post
    I guess you are missing the bios chip, 8Mb flash eeprom.
    8 Mb=1 MB
    lol
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      Originally posted by RJARRRPCGP View Post
      8 Mb=1 MB
      lol
      Yes, and your point is...???
        Originally posted by gilly1984 View Post
        I have one of them on a dead foxconn mobo. Its a winbond chip.
        Not sure of what numbers are written on it but could find out if you need it.
        No need but thanks, I'll try to hotflash another chip for it. Found another 8mbit bios chip from another dead mobo. Should work I think, latest BIOS file for my mobo is 940kb.
        Guns don't solve problems. I'll take 12
          8 Mb=1 MB
          lol
          Your math seems to be good, have you been eating yellow snow ?
          @ Koda
          Why did your cousin remove the bios chip ?
            That chip next to the RAM slots is not the bios, it is the ICS cpu controller. It monitors the cpu voltage, temperature etc.
              No probs, but if you need it anyway I can send it your way.
              Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                @ Koda
                He said it fell off in transport while he was moving the case somewhere doing something. The case was open and he simply lost it. He must have banged it pretty good for the chip to exit the socket or for some reason he's lying to me.
                  That 8-pin DIP is the BIOS chip, and I've seen other motherboards where the BIOS label was stuck on something other than a BIOS chip.
                  I've done one SPI flash, for a bricked MSI mobo with a soldered BIOS chip (Macronix MX25L800, 2.7V - 3.6V read/write/erase). I used SPIPGM2 to flash it from a parallel printer port and didn't need a CPU.
                    That's the BIOS circled in Green.. The chip by the RAM slots is the Super I/O chip.. Serial Flash ROMS are common on newer boards, and they are 8 pins, either DIP or SMT..
                      Originally posted by Per Hansson View Post
                      The thing you marked in green is not a BIOS chip, it's probably the legacy controller for things like PS/2, Serial and such stuff (ISA based)
                      The small 8 legged IC is the BIOS, it is a SPI based BIOS (SPI stands for Serial Peripheral Interface and explains how it needs so few legs to do it's work, it's like SATA for your HDD to make a crude comparison)
                      100% correct!
                        Originally posted by shovenose View Post
                        I will agree with Koda here, that the BIOS is up by the RAM. Just try it! If you need an AM2 CPU I've got some, send me a PM and I'll send one your way cheap.
                        100% Wrong
