OK this is a WTF moment my laptop display quit working so it got opened it up and reseated everything except the CMOS battery and it didn't work, so i opened it up again and in the proses i lost the original CMOS so a new one got stuck into the laptop and it works now! so did the new battery fix the issue and if so could a dead CMOS battery be the cause of the "dead" displays on some of the laptops that i repair at work?
bad cmos battery = no display?
Follow the white rabbit.Tags: None -
Re: bad cmos battery = no display?
I doubt that the battery removal did anything but reset the motherboards' BIOS settings to default. Perhaps the bios had become corrupted and could not POST because of that ? A CMOS reset was perhaps all it needed. -
ok thats what i thought thx for the answer.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
You are welcome.. For related interest.. I just got a desktop in that the guy had removed a third party graphics card from because it failed. He tried using the motherboard's onboard VGA but it would not boot, so he brought it in.
Of course, the BIOS was set on using the seperate card and had no fall-back setting to use the onboard if the seperate card was missing.
A BIOS (CMOS) reset did the trick.Comment
by Genghis_KhanHello everyone,
I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
Issue summary:
Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,... -
by questoreHi Everyone,
I have brought you a mistery item
This laptop have come with some strange faults.
1. CMOS battery was flat 0v
Symptoms:
- After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
Amp drawing was stuck at 0.005 milliamps.
- Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
After inverstigation RTCD1 diode had a low value... -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mkdjHello everyone,
Mark and model: ASUS X571
Tests already made:
- I have removed... -
This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...09-06-2024, 06:06 AM
- Loading...
