Had to disconnect CMOS battery. Now wont go past recovery utility....
  • 1F5A
    Bios reset to factory specs and date is 2009. I have a dell latitude e6400 ATG service tag: 5MPVHL1 1F5A
    Searching the site seems to show that I have to do some serious business to either bypass or generate a password and the only one who can do it for me is on the Ivory Coast.
    5MPVHL1 1F5A any takers? I need a bios password.
    Running Windows 7 64bit
    Upgraded wifi and running Solid State Drive.
    4 gb ram
    Dual core 3gb T9900. It's not a gamer, but is very stable and puts up with my abuse.
    Ran this configuration for the last 12 months no problem, but had to remove mother board to replace the USB/Audio daughter board.
    Now, I can see the hard drive and all the windows files on the command prompt, but wont boot.
    All I can think of is that the Bios needs to be updated with a download from Dell.
    Can I boot off an UBUNTU ISO DVD and then update the BIOS from the dell website that way?
    Any thoughts.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Had to disconnect CMOS battery. Now wont go past recovery utility....
    Sounds like SSD corruption. I would wipe the SSD and reinstall the OS.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • myth77
      macbook pro a2141 can not make recovery
      by myth77
      So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
      So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
      06-19-2022, 11:21 AM
    • alfredposadas09
      cant enter recovery mode lenovo c13 yoga chromebook
      by alfredposadas09
      cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
      11-09-2024, 10:09 AM
    • conghuyms
      Macbook air m1 can't access the recovery options by pressing and holding the power button
      by conghuyms
      I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
      After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
      10-14-2024, 06:43 AM
    • volinakis
      Chromebook recovery failed - how to fix it
      by volinakis
      So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
      Finally I found a site where they suggested to try with an older image and ... it worked!
      What I did:
      - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
      09-18-2023, 03:26 PM
