Someone at Opera was inhaling something!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Why?
    I installed Opera 12.11 build 1661 and the default page draw delay was set to 3 seconds!
    Previous versions were set to 1 by default.
    Whoever did this at Opera only is only causing bad publicity.
    Epic fail for defaulting to satellite-like delays!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • YG007
    Asus BIOS How To Reset To Default Settings?
    by YG007
    Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
    I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
    06-05-2023, 08:22 PM
  • japlytic
    Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
    by japlytic
    On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
    So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
    12-30-2022, 11:12 PM
  • ivtec
    win 10 not allowing google chrome to be the default browser ?
    by ivtec
    Hi guys ;no matter how many time i make google chrome my default browser it keeps showing not default every time i open chrome....
    04-19-2021, 12:05 PM
  • pfrcom
    Reset/erase Hynix SC210 to factory default
    by pfrcom
    Some Googling made this seem straightforward, but it ain't necessarily so:
    First try was Hynix Drive Manager, supposed to be able to do PSID reset
    In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
    After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
    How I got it work:
    1. Command prompt
    2. Change to install directory \Program Files\SK Hynix Drive Manager
    3....
    04-23-2022, 07:30 AM
  • notorius
    Toshiba Satellite L50-B-2G7 doesnt save BIOS Settings / reverts always to default
    by notorius
    Hey guys, im new here and i have a problem.
    I bought the above mentioned Laptop without a Harddrive.
    I put in a SSD and wanted to install Windows but i cant boot neither from
    USB-Stick nor from the build-in DVD-Drive.
    So i went into the BIOS and changed the boot sequence. But then, after
    saving the settings (+reboot) i checked BIOS again and still had the old default settings loaded.
    I also needed to have the CSM-Mode instead of UEFI for proper Installation, so i changed it , and guess what - after the "Save and Exit"...
    03-03-2020, 06:07 AM
