Super Twisted
  • arneson
    • Sep 2005
    • 1267
    Super Twisted
    I bought an lcd tv and in the lower right corner is one bright white pixel.
    I've just realized that on a normal tv almost everything at the bottem is dark, a suit, a desk, the ground, whatever.
    So this dot is just staring at me.
    I just read that if you apply gentle pressure on that pixel and power the screen it may come back to life? Something about the liquid filling in?
    I would be satisfied just to turn it on so it was black or green or anything but bright.
    Ever heard of bad pixels comming on?
    Jim
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2662
    • oooo ess aaaaaaaaa
    Re: Super Twisted
    i had an LCD monitor that had a stuck on pixel. i pressed on it and it worked...sorta. it wasn't just white. it would do dark shades, but it wasn't 100%.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • Galvanized
      • Mar 2006
      • 468
      Re: Super Twisted
      Don't bank on it, but I have read where ppl use an eraser covered with several layers of polishing cloth to rub the pixel area. Some got a result w/o damaging the screen because I think it has to be rubbed pretty hard.
      Give it a few days as I'm sure some here can offer more than I have.
      This is a used or repaired LCD you have? So no return or warrenty? How about a tiny dot of dark paint over the pixel.
      • arneson
        • Sep 2005
        • 1267
        Re: Super Twisted
        Yes it was an Ebay as is, Panasonic 13' .
        Nice for mounting in kitchen.
        Funny to think I could erase a pixel with a pencil...
        Wife may laugh at me.
        Jim
        • Galvanized
          • Mar 2006
          • 468
          Re: Super Twisted
          Let her laugh. The eraser will still be firm enough to exert pressure on that tiny area but soft enough not to cause damage. Guys use a new eraser but do cover it with polishing cloth.
          Let us know how it goes
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • Destroyer-Br
            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
            by Destroyer-Br
            I'm working on an Acer Nitro 5 unit with the following specs:
            • Motherboard: LA-J871P Rev: 1B
            • Model: Acer AN515-55-59MT
            • S/N: NHQ7JAL00403906A973400
            • SNID: 03902728734
            Initial Issue
            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
            04-17-2025, 08:18 PM
          • ongobongo
            Asus ROG Ally - Super IO Chip replacement
            by ongobongo
            anyone here who has experience with replacing the super IO chip of an ROG ally?
            I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
            Ongo
            11-17-2024, 11:27 AM
          • rumi409
            LG OLED C1 Pixel Cleaning Made Picture Worse
            by rumi409
            ​​​​​​ Hi,
            I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
            11-15-2024, 01:09 AM
          • Schwoin
            Philips 243v5lhsb00 Monitor Picture too bright
            by Schwoin
            Hey everyone,
            the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
            While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
            you can see them on the top half of the photo.
            At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
            03-21-2023, 12:40 PM
