hey top cat got a question about "mac address's"
  • latimo
    • Dec 2003
    • 9
    hey top cat latimo here, i got a question that maybe you could help me answer.........
    now is it possible for someone to hack into ones system by the mac address alone ?? the board i got has on board lan connection .
    is this possible ? i have dsl witha dynamic ip address. i am getting the feeling that the guy i got my board from may be doing some un-nessary ease dropping on me . could be parinoid about it all ( lol !) just wanted some one that has a bit more networking expertise to tell me if this is possible with a honest answer. if it is ....would installing a pci "nic" solve this privacy invasion ?!?!?! or should i go get a appointment with a shrink !
    thanks once again for your wisdom. . . . . . .
    L.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Hi again! Long time!
    To answer your question, no, that's not very likely. A 'mac' address is an address given to a NIC in the NIC's firmware. This address cannot be changed, as it's part of the firmware of the NIC. Each NIC has a unique MAC address, which is like a fingerprint of the NIC, which a DHCP server, router, switch, or other such network appliance can use to identify your NIC and give it an IP or whatever protocol has been assigned. Since you indicated you have a 'dynamic' IP, this means that your IP will change from time to time. If you have a 'static' IP, this means it does not change. The only way a hacker could single out your system is if he knows your actual IP address. With the MAC address alone, there's really nothing he could do to locate your actual system unless he works for the ISP your DSL connection is on and had access to their servers and routers. If you gave me the MAC address of your NIC, there's absolutely nothing I could do with it to hack your system. You might consider using a firewall utility if you're on a constant Internet connection, this will hinder hacker attacks dramatically!
    I hope that helps!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • latimo
      • Dec 2003
      • 9
      :!: dam that was quick , as soon as i wrote you the message i went researching mac address spoofing on google and thought to check back to see if i got a reply from you !! thanks for being promt.
      i got zone alarm pro newest version with xp pro. i was useing the free version of sysgate personal firewall and i stop useing it because i think i got hacked ...of sorts ......funny story,
      i had 3 empty folders on my desk top for putting some albums that i was to encode to mp3 format into and for one reason or another i decided not to do it. so..... after a hour of doing other things on my system i was about to go to bed and told my self to go ahead an delete those empty folders in the recycle bin , i did just so ( easy enough right ?)well after i deleted those 3 folders with nothing in them i stayed up a bit later and did other things on my system ( 1 hour to be exact ) and low and behold guess what showed back on my desk top ....one of the empty album folders !!
      the thing i like best about sysgate firewall is that it had a graph that showed all in an out going traffic...so after i saw that folder i thought to my self "hmm, maybe the o/s thought it got rid of it " so i deleted it again ,it came back ! 30 times it came back :? so i started looking at sysgate ...and i found out that when i deleted it i looked on the in coming traffic chart and sure enough i could see a " ping" ( guess it was a ping ) and then after that happened the folder magiclly re-appeared back on my desk top ....i thought to my self "some little s.o.b is getting his jollys with me tonight" made me MAD .
      sorry to go on like this ........but thanks for your insite on my question and yes i still got the iwill dvd266u-rn board ,soon it will be getting a new home in a shiny new alum. case next month with 512mb of memory and will be back in commision .
      L.
      p.s. : i guess now would be a good idea to give that shrink a call ! lol !
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sygate Personal Firewall (standard) is a good firewall, at least if you always keep it up to recent date.
        You may have gotten cracked because of not getting an updated version of Sygate Personal Firewall (standard).
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Sygate is a nice util. I also recommend Black Ice if you plan to use a software firewall. However, if you have a broadband (cable or DSL) connect, a good way to stop a lot of this is to get a cheap-o Linksys router. They cost around $40.00 and are pretty secure. They're also nice because you can share your connect with multiple computers from behind the firewall.
          Team : 49813
          Join in!!
          Team Stats
          • latimo
            • Dec 2003
            • 9
            Howdy all ! just got a e-mail on this thread today.......
            i think that i had the upto date version of sygate but i also have an linksys 4 port router mdl# befsr41 but i have not updated the firmware at that point ...so maybe that was the problem with me getting hacked .i have since then updated the firmware on my router and im still useing zone alarm pro and so far , my system / network has remained untouched by the evil forces abroad. software fire walls are good but i think that also like what top cat said useing a dsl router with "nat" ( network address translation) also make sure for a good defence .my neighbors that live across the street from me have charter cable internet service and the modem the use is a RCA brand cable modem (no router functions to it) ...they kept getting hacked into all the time and virus's /hijackers/anything else you can think of they caught ! needless to say i was very tired of fixing their computer all the time so, after building a new computer for them abouta month ago i installed zone alarm pro on the computer and i was shocked on how many attemps the had in a hour's time. i think the total was about 150 - 200 ......the most i have ever had on my network was maybe 2-6 and thats only because other people in the house was logging into their computers an zone alarm was recording the event. not like my neighbors system but zone alarm has kept all of them abay and so far i have not been called to make a house call ( lol ! )
            topcat ....hope you had a good 4th this year and shot many of those illegal fireworks off ( at least in georgia they are ) .
            talk to you guys later .
            best regards ,
            Latimo. . . . . .
            • Hondaman
              Hardware firewall to block ad servers?
              by Hondaman
              I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
              The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
              02-05-2025, 05:04 AM
            • juergenb
              Sophos XG86w Firewall forgets the date and time as well as the DMI environment variables after power cycle
              by juergenb
              I have a small Sophos XG86w firewall here, which is still working so far. But there is a problem with the BIOS and the DMI environment variables.
              The hardware forgets the date and time after a reboot or a power failure.
              The DMI environment variables are also reset to default values.
              I have now tried 2 different batteries (CR2032).
              I reset the DMI vars via an EFI shell and with AMIDEEFI64 (v5.21.0057).
              However, after a reboot or a power cycle, these values are reset again.
              It is an Apollo Lake platform with an Intel...
              10-08-2024, 04:19 AM
            • ravi_1617
              HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
              by ravi_1617
              Hello to all ,
              I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
              Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
              on external VGA port image is perfect /normal , Attached image...
              07-25-2025, 12:07 AM
            • TheWizard
              Need to shrink a 128 MB BIN to 64mb.Inspiron 3593
              by TheWizard
              Took read of chip with wrong selected MB from programmer. The current BIN i have backed up is 128MB and it needs to fit on a 64mb chip. Is there an application that makes this easy to shink the BIN and keep all data intact? I am familiar with HeXHD. Any help would be appreciated.
              11-01-2022, 10:47 AM
            • gica69
              Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
              by gica69
              I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
              Resistor shows orange range silver gold and green lines.
              Thanks in adv...
              07-21-2025, 09:49 PM
