Nvidia GeForce 8800GTS
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Nvidia GeForce 8800GTS
    Will do once I can walk around again (toe surgery recovery) and Iget real flux (a felt tipped flux pen won't work, right?)
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I bought some Paste flux in a syringe at Fry's Today. I oven reflowed it tonight.
      So far, It looks to have been a success:
      The setup:
      A shot while booting Mageia 2 from a usb stick:
      Once I got to the desktop, the graphics kept on lagging, which I suspect is a driver bug, not a card fault.
      Comments?
      sigpic
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        son of a bitch I think thats nearly the same model 8800 GTS I have in storage, except mine is half the ram
        nice find. If you ever tried the goodwill in DFW they would of probably listed it as $100 untested AS-IS no returns. They're still idiots over there, I wish I could of changed things.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Sweet!
          I like the shiny paint on that Ole Blue .
          Most likely yes. I've had that happen multiple times when trying to install the latest and "greatest" drivers for some old graphics cards. It's best to stick to an older but proven version.
          I say give it a try in Windows with both old and new drivers and see what happens.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Originally posted by momaka
            Sweet!
            That was mandriva usingNouveau... no Windows since that would require a HDD to try. I am out of decent HDDs that I could use... If I ever get a decent case and a HDD for that, I may make it into a multimedia rig.
            sigpic
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              You don't need a "decent" HDD to make a test Windows install . Anything with 3 GB or more will do. I have several sub 20 GB ones that I use exactly for that purpose (one of them being an old 3.2 GB Quantum BigFoot 5.25" HDD that occasionally gets stuck heads ).
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Most of my spares died... I think I have a WD 7200RPM 20gb unit, but its IDE and the board only has one port (I hear mixing opticals and modernish HDDs on the same cable is a bad idea). I am also out of SATA opticals; I only have 2 and both are in use.
                The reason I am pretty sure the card wasn't the issue was that my mouse pointer was okay speed wise... I think hardware accelerated pointers is enabled by default though.
                Bottom line is that until I fond a decent case, its kinda useless to me.
                sigpic
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  Don't listen, try it.
                  I do it all of the time without problem. Most of the time I don't even have an 80 pin cable (which is the recommended route if mixing HDDs and opticals) so I use a 40 pin cable. And even so, the only downside of that is that the HDD is limited to UDMA mode 2 (33 MB/s max). With 80 pin, the HDD will work at whatever max the board/HDD supports and the optical drive will work at just mode 2. That's not really a problem with your 20 GB HDD since it will likely never do 33 MB/s continuous anyways.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    I see. The last problem is that I don't have time to try right now... although mageia 2's stable release just came out today... maybe that is more stable?
                    sigpic
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      #30
                      ...With 80 pin, the HDD will work at whatever max the board/HDD supports and the optical drive will work at just mode 2. That's not really a problem with your 20 GB HDD since it will likely never do 33 MB/s continuous anyways.
                      its not 80 pin, its 40 pin 80 wire. each data wire is interleaved with a ground wire to decrease interference. There is no 'dual channel' PATA like what you're implying.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I took the cover off the heatsink... there was more dust in there that I originally thought...
                        at leas the cage fan has a delta motor in it...
                        sigpic
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Good. Those hamster wheel fans are a nightmare to find replacments for
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #33
                            Yeah, I hope nobody tried to look for 80-pin cables after reading that post . Thanks for correcting that typo.
                            Regular fans work too. Just mount them above where the hamster wheel fan used to be.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              I guess it works, though.
                                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                10-02-2024, 08:52 AM
                                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                10-02-2024, 07:51 AM
                                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                10-01-2024, 01:54 PM
                                HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                09-12-2024, 03:30 PM
                                ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                09-07-2024, 01:00 AM
