CDs make me sick
  • Shocker
    Banned
    • Dec 2011
    • 635
    CDs make me sick
    LOL...who thought making a high-precision optical device out of easily scratched polycarbonate and then not encasing it was a good idea???
    Don't forget that there's only a neglegibly thin layer between the outside world and the data on traditional CDs.
    And to top it off, blank optical media seems to be another thing where it's harder and harder to get good quality. I even remember seeing visible defects on TDK branded CD-Rs after like 2-3 days. FAIL. And I thought TDK was meant to be a good brand...
    Anyway, here's my advice: ALWAYS back up optical discs of everything, unless it's a non-PC-readable format. DON'T use CD-Rs for personal data unless you have to for compatibility. Right???
    Yes, I know hard drives fail. But CDs are 1,000,000 times easier to destroy.
  • dumpystig
    • Jul 2011
    • 485
    Re: CDs make me sick
    You can always encase it yourself within a jewel-box or cover...
    System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Well, when CDs came your other choice was a 1ft stack of floppies...
      sigpic
      (Insert witty quote here)
      • Shocker
        Banned
        • Dec 2011
        • 635
        But you have to take it OUT of the case to use it. Plus, jewel cases crack if you step on them.
        • mariushm
          • May 2011
          • 3799
          If you don't like them, you have tapes.
          Oh, I'm sorry, you want big storage AND fast random access? Then live with it.
          ps.
          Initially the discs were meant as replacement for regular discs, the ones where a head physically touches the grooves and forms sound due to the vibrations in the crystal, and cassette tapes. Computers already had 1-4 GB tapes and tape drives.
          There were ideas thrown around to encase the disc in a cartridge but they gave that up to make things cheaper to manufacture (sega and sony also gave up on cartridges soon after and went with cd like formats). Also, they wanted to be very easy to explain to old people and noobs how they work... imagine how you would explain your grandmother how to use them if they were cartridges.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5037
            • New Zealand
            Hmm.. One good whack with a sledgehammer and both will be equally toast.
            -David VanHorn
            • Shocker
              Banned
              • Dec 2011
              • 635
              No, I don't - tapes have poor fidelity, wear out, are unusable for anything demanding of random access and are incredibly vulnerable to magnets.
              That's what we have flash and HDDs for.
              Make the protector transparent and it wouldn't be that hard would it???
              So would YOU, if you got hit...
              • mariushm
                • May 2011
                • 3799
                You didn't have flash memory in 1982, when the compact disc (CD) was invented. You didn't even have 3.5" floppy disks until 1984, when IBM came up with 720 KB floppies in that format.
                So you only had floppy drives, tape drives and hard disks that were going into the 5.25" slots because 3.5" drives only appeared in 1988 when Connor made the first.
                CDs were very good and reasonably protected. Remember, they were supposed to be played at 1x which is 150 rpm, and the imprints in the chemical layer were much more pronounced than nowadays so the devices were able to read the data on them even with quite a few scratches.
                Much later as burning speed went up, different chemical compositions were used and the "grooves" made by the writers were less pronounced and more prone for read errors. Fast read speed also made it worse as the plastic expands with the high speed, but the drives themselves got better error correction and so everything kept up.
                ps. Oh... even the CD-R standard was added to the CD standard only in 1988. So you should probably look up how much did a 3.5" drive cost in 1988 and see how well it would have worked for you to use hard drives to move data around.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  There is only one thing to remember: There is no substitute for a proper backup system.
                  -David VanHorn
                  • Shocker
                    Banned
                    • Dec 2011
                    • 635
                    I found this while I was waiting. Hope you'll find it useful. Once you've installed it, it functions almost as if it was integral to Windows.
                    By the way: I understand if you don't have the HDD space necessary to back up all your CDs and DVDs. But if you have it, you really should use it. I'll bet you $1000 that a TON of hard drive space goes to waste these days.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5037
                      • New Zealand
                      There are piles of tools to emulate CD\DVD drives from ISO images etc, haven't heard of that one before though.
                      -David VanHorn
                      • mariushm
                        • May 2011
                        • 3799
                        First of all, why use CDs when you have DVD discs?
                        Second... stop and think about it, how much is a 1 TB drive and how much are packs of 8x25 dvd packs?
                        I'll tell you, about the same.
                        1 TB drive (~950 GB usable)... 90$ : http://www.newegg.com/Product/Produc...82E16822136490
                        8 x 25 dvd packs (~ 880 GB usable) ... 70$ .... http://www.newegg.com/Product/Produc...82E16817172099
                        It's just not worth it, do the initial investment and store your data on it. if you're paranoid, get a second one and keep them in two separate parts of your house or store one at your parents' house.
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          First, "DVD disc" is redundant.
                          Second, we have Blu-ray.
                          • mariushm
                            • May 2011
                            • 3799
                            I know, but I'm too concerned about their long term reliability to recommend them.
                            Also, they're much more expensive.
                            The chemical composition of the most often used dvds is already time tested so if you get quality discs, your data is safe for 2-3 years, at least..
                            • Keatah
                              • 11
                              why would you want to step on them?
                              On a clear disk you can seek forever.
                              • Keatah
                                • 11
                                why would you want to smash them with a hammer?
                                If you need that level of protection, then you buy a steel safe and put the media in there.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  For the same reason you dont follow the site rules and put your location in your profile (although your comcast IP shows you to be in Illnois)......its annoying.
                                  <--- Badcaps.net Founder
                                  Badcaps.net Services:
                                  Motherboard Repair Services
                                  http://folding.stanford.edu/
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Quoted for Truth
                                    sigpic
                                    • severach
                                      • Aug 2007
                                      • 1055
                                      The same person who thought that CDs should be as easy and cheap to make as records so there wouldn't be supply problems every time an entertainer releases a new hit album that sells millions of copies in a weekend.
                                      If CD releases cost 4 times a much or took several months longer than record releases then the format wouldn't have caught on as fast.
                                      Lots of technologies came out soon after CDs that were better and safer. Why didn't you buy them?
                                      Because they were too expensive. CD was cheap and good enough.
                                      The good is the enemy of the best. (not said by Voltaire)
                                      sig files are for morons
                                      • Shocker
                                        Banned
                                        • Dec 2011
                                        • 635
                                        BTW, I think I've got a case of DVD bronzing.
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
                                        • Techie_hobby1
                                          Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
                                          by Techie_hobby1
                                          Need some help please with a few components on this small board so that I can troubleshoot the circuit.
                                          The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
                                          J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
                                          J2 - to DC Output
                                          J3 is Battery cell connector
                                          however I am struggling to identify if:
                                          Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
                                          07-24-2025, 12:43 PM
                                        • Russ1
                                          Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
                                          by Russ1
                                          Sick of seeing big numbers of these routers dead no power light underneath.....
                                          Chasing Schematic of this power supply I have searched high and low....
                                          Already spotted a few swollen caps, but Ac fuse ok.....
                                          This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
                                          Can anyone help with any type of schematic and parts list ?
                                          Thanks and Regards, Russ
                                          07-10-2025, 11:01 PM
                                        • shepp
                                          Techno Gym - TGYM ALE A - S6T12 - VSD
                                          by shepp
                                          Hello People, Not been on here for a long time but I have a treadmill to get my teeth into & I'm struggling to find the problem....
                                          So the machine runs sometimes, but then other times I get the error code 3 for Low voltage, so the low voltage could be the motor output voltage from the drive or it could mean something else, all the voltages seem stable enough, like 24V etc...
                                          On startup from a mains power up the relay at the line input socket clicks in & out constantly which its not suppose to do, so my 1st thoughts are with this circuit somewhere.....
                                          03-26-2025, 01:09 PM
                                        • wrobbie
                                          Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
                                          by wrobbie
                                          My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
                                          02-26-2025, 10:02 PM
