Asus A8N-E
Asus A8N-E
Last edited by c_hegge; 03-16-2012, 02:48 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProTags: None -
(Insert witty quote here) -
A man convinced against his will is of the same opinion still.Comment
Re: Ratdude's Main rig V2
nope. in the middle of a memtest, it just shuts off, with its own antec 350, and with a thermaltake tr2 430. Maybe its related to the 4000+ single core thats in it. both temps show fine, and there is no shut down tempeture set
this board was my gaming board (combined with a 3500+, 6800 GS and 1GB corsair) for god, 4 years? not a single problem. Lot of those corruption issues if I remember are related to certain version of nforce drivers
(oh yes, and I recapped the kgz's with pannys)
and rat from thier website i' getting
Code:Error! Application error: Object reference not set to an instance of an object. See error log for more information.
Last edited by Uranium-235; 03-16-2012, 02:09 PM.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
the entire site is down. again what they get for using aspCap Datasheet Depot: http://www.paullinebarger.net/DS/
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Team : 49813
Join in!!
Team StatsComment
omgstopusinghugetextCap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: Asus A8N-E
are you sure its wise to split the thread, and undo the hijack when YOUR FORUM BOSS is the one who hijacked it to begin with?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: Asus A8N-E
It was MY thread about MY computer. your topic has little in common.
If I wasn't so lazy, I would have copied your post here and split it up...
It's not like I deleted the Posts... if he has a problem with it, he can just merge the threads... I I really doubt he will have a problem...Last edited by ratdude747; 03-17-2012, 06:26 PM.sigpic
(Insert witty quote here)Comment
Re: Asus A8N-E
Nope, no problem.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: Asus A8N-E
it wasn't really MY topic, as even though I mentioned my A8N-E was acting up, I was mostly asking about those 604 heatsinks and adding info about the board I wanted them for
hegge started bitching about asus, and I provided information, maybe someone had an idea why my A8N-E was doing thatCap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: Asus A8N-E
I was the OP... as for whose topic it is, that is irrelevant. I should have said "that topic". I wanted my thread back and I moved the side discussion to a different thread. I don't see what is wrong with that? (even topcat agrees with me).sigpic
Re: Asus A8N-E
my 'boss' post was ment to be kinda of a joke actually, but hey, whateverCap Datasheet Depot: http://www.paullinebarger.net/DS/
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by sikocanUX580G Laptop
Motherboard: UX550GD REV 2.2
ITE IT8225VG Chip
Asus website: https://www.asus.com/au/supportonly/...desk_download/
Windows BIOS: https://dlcdnets.asus.com/pub/ASUS/n..._Installer.exe
Manual BIOS: https://dlcdnets.asus.com/pub/ASUS/n...50GDXAS312.zip
Thanks-
by c.danielhello; so, i have this asus fx506hm-az121, it's an i7-11800H with NVIDIA GeForce RTX 3060; so, this notebook received some liquid on him; all coil resistance looking good, all looking ok; i clean the oxides, and now, battery is charging, but when i press power button, led light up, and leds from keyboard light up but no screen.
So, i think bios messed up; i try to download bios from asus site, but after delete those 2kb from beginning, bios image on start of the file they are very different; i think asus change the way bios appears/how they are build.
So, any of you can make a Clean...-
by vixeko_They asked me to change the HDD to an SSD on this Asus laptop, in case the laptop already had problems such as it not turning on every time and the battery charge lasting very little.
and perform the task successfully and clone the data from the hdd to the new ssd
I managed to start windows on the ssd and everything was normal so I decided to restart it to measure the startup speed and when I did that instead of starting windows the laptop sent me to the bios
I exited the bios to continue to windows but when the laptop turned off it did not turn on again, it was strange but... -
by Prima83Hi,
I'm looking for a .bin file to flash the BIOS for:
Notebook: ASUS ROG G713QR-HG121 (Strix G17).
https://rog.asus.com/laptops/rog-str...desk_download/
SN: MBNRKD004835486
Motherboard model: G533-6050A3250203-MB-A01(A1)
I have attached pics of the mobo and 2 IC's on it that look like BIOS chips, just not sure which one needs to be flashed.
The flat chip has this on it
Winbond M12JWPIQ
2132
6129
M0061
and the other one's model is Winbond 25Q16JWNIQ...-
- Loading...
