Dell XPS 8300 issues
  • Kylethedude1
    • Mar 2012
    • 16
    Hey guys,
    I am on my 3rd replacement xps 8300 from dell in under a year span due to smoke and VERY loud fans at random times(jet engine loud) usually upon startup let's say once out of 300 start ups and after the loud fans smoke follows. Anyways, I opened my case, and found Su scon and KZG caps on the mobo, and capxon in my dell PSU... What's the worst that could happen to me? Im very nervous to even plug in the newest replacement I was sent, I have a vision it will happen again, and if I leave it unattended it will go up in flames. Please tell me how I should appropriately deal with this? Thanks!
    Its getting nerve racking knowing that dells have ALWAYS smoked for some reason in my house, no other computers that are not dells that I have/had EVER did that. Am I over reacting?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: PLEASE HELP I NEED ADVICE! Dell Problems
    I don't know if this is you posting on a different board but, same problem
    http://slickdeals.net/f/3961338-Acer...ore-com?page=3
    here too
    http://ecorporateoffices.com/Dell-1550
    these people are talking about fan failures on the 8300 (look under "quality" section they talk about it)
    http://www.flightsim.com/main/review/alien.htm
    here someone said dell stopped making them
    https://www.badcaps.net/forum/showthread.php?t=19533
    I would have to say this model is defective from the factory. Get your money back and get an Acer, or Asus. Bitch to them about how this is the 3rd replacement
    remember, dell stands for : Doesn't Ever Last Long
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Dell XPS 8300 issues
      fixed title.
      sigpic
      (Insert witty quote here)
      • Kylethedude1
        • Mar 2012
        • 16
        Should I be afraid to the point that I don't even want to turn it on? Or is that just being over reactive? And how loud is a cap going?
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          it just occoured to me. If you know enough to take your PSU out and apart, you probably know enough to build your own
          I don't know how much you spent, but if you want something with QUALITY then I would get a gigabyte board, all poly caps. Unfortunetly, the i7 2600k is kind of expensive, Dell can sell them in PC's cheap by ordering them in bulk, and ordering shit parts in bulk too
          I put a i7 system on newegg together with a 2600K, Gigabyte lga1155 all poly board, 8gb, 500GB RE4, Earthwatts 650W, GT 520, DVD burner for only $100 more then dells middle-line 8300 (same specs, though dells site does not tell me how big the HD is)
          edit: I would not turn it on, might void your warranty to the point dell might not accept it, they would use any excuse to keep their dough
          • Kylethedude1
            • Mar 2012
            • 16
            Cool, thank you!
            I will have to keep that in mind.
            So my 8300 is probably safe to use for a few weeks at least until I build my own?
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I wouldn't count on it. if a fan in the PSU failed (you can see this for yourself if you turn it on and the PSU fan isn't turning [most of the time, some 'green' psus won't turn on the fan till they get hot]) then that might be the problem. Actually, if it IS JUST the power supply, you should be able to order an one from newegg, or if you have one lying around (A good one, remember this is a i7 2600k), meaning probably 450W or higher, then go ahead and use that. but I would reccomend a Antec Earthwatts 650
              now if your motherboard fan quit working, then you could get a new heatsink, assuming the excessive heat didn't blow the caps around the cpu. and KGZ's sometimes die without bloating (broken seals causes pressure to be released in places other then the top of the cap)
              was the smoke coming from your PSU or from the motherboard?
              give us a pic of the board if you can
              • Kylethedude1
                • Mar 2012
                • 16
                Sure thing,and thank you for all the help so far!
                I will post a picture of my board tommorrow, so expect a update with pictures by tommorrow evening.
                • Kylethedude1
                  • Mar 2012
                  • 16
                  • c_hegge
                    • Sep 2009
                    • 5219
                    You're recommending Acer or ASUS? shame on you!!!
                    Acer = Always Completely and Entirely Rubbish
                    Asus = Always Seriously UnStable
                    • dmill89
                      • Dec 2011
                      • 2534
                      Dell Used 2 different PSUs in this system. Model: D460DB-00 is made by Delta. Model: H460AD-00 is made by Huntkey. I would guess your system has the Huntkey unit due to the high rate of failures and fact that it got to the point of smoking. As Uranium-235 said If it is just the PSU I would probably just replace the PSU, Your Motherboard doesn't show any obvious damage or failed caps from the Pics that were posted. As Uranium-235 suggested the Antec Earthwatts EA-650 is a good option for this system, this is a good Delta built unit, although as a budget/midgrade unit it will likely have some Ltec caps in it, but these generally do ok in Delta PSUs. If you don't mind waiting for a rebate the PC Power and Cooling Silencer MK III is even better, this is a SeaSonic built unit with all Japanese caps. It is currently going for $60 after rebate and promo code. A 600-650w is slightly overkill but given the minimal (~$10) price difference between a good 500w and a 600-650w it makes sense to go for the higher wattage PSU to allow extra room for upgrades.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I don't think Dell ever used huntkey PSUs. they only ever use Delta/Newton, AcBel, Lite-on and Hipro.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          I can tell you this
                          two years in a computer shop, I have seen VERY few acers and even less asus's from bad hardware, most of them just viruses
                          thats all I can say, take it or leave it, hate asus or not, that is what I observed. I have actually seen ONE bad Acer desktop (motherboard) in two years
                          • Kylethedude1
                            • Mar 2012
                            • 16
                            How can you decide if I should get just a new psu or recap my board? My mobo has kzg, on it and other ones I can't read.
                            • Kylethedude1
                              • Mar 2012
                              • 16
                              My PSU says: dell model: AC460AD-00
                              REV: A00
                              DATE: B1144
                              Total Power 460W MAX
                              • c_hegge
                                • Sep 2009
                                • 5219
                                I can tell you this
                                Odd. I have worked at a computer shop for the last four years. From what I've seen ALL of the big brands except for IBM/Lenovo are junk, and the only half decent boards are Intel, Gigabyte, DFI and MSI. I see as many asus boards die as all of those four combined - even though Gigabyte is by far the most popular brand around here.
                                I'd say just get a better PSU. KZG may not be great, but with a good PSU and good cooling, they might do OK for a year or two.
                                EDIT: based on that model number, it's probably an AcBel. They can make some very good units, but they can also make some not so good ones.
                                • Kylethedude1
                                  • Mar 2012
                                  • 16
                                  What about the other unidentified caps in my mobo?
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    here is my i7 parts list
                                    Antec EarthWatts EA-650 GREEN 650W Power Supply
                                    Item #:N82E16817371044
                                    Return Policy: Standard Return Policy
                                    $74.99
                                    Antec Three Hundred Black Computer Case
                                    Item #:N82E16811129042
                                    Return Policy: Limited Replacement Only Return Policy
                                    $59.99
                                    Microsoft Windows 7 Home Premium SP1 64-bit
                                    Item #:N82E16832116986
                                    Return Policy: Software Standard Return Policy
                                    $99.99
                                    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
                                    Item #:N82E16820231314
                                    Return Policy: Memory Standard Return Policy
                                    $46.99
                                    Western Digital RE4 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
                                    Item #:N82E16822136697
                                    $129.99
                                    ASUS 24X DVD Burner - Bulk Black SATA Model DRW-24B1ST/BLK/B/AS
                                    Item #:N82E16827135204
                                    $21.99
                                    EVGA GeForce GT 520 (Fermi) 01G-P3-1526-KR Video Card
                                    Item #:N82E16814130680
                                    Return Policy: VGA Standard Return Policy
                                    $54.99
                                    Intel Core i7-2600K 3.4GHz LGA 1155 95W Quad-Core Desktop Processor
                                    Item #:N82E16819115070
                                    Return Policy: CPU Replacement Only Return Policy
                                    $324.99
                                    GIGABYTE GA-H61MA-D3V Micro ATX Intel Motherboard
                                    Item #:N82E16813128539
                                    $69.99
                                    Grand Total:$883.91
                                    (with shipping to tx, this ended up being $899)
                                    here is an AMD version, slightly cheaper, best AMD desktop chip they have to offer, still slower then a 2600K, but very fast enough for most people
                                    $74.99
                                    $59.99
                                    $46.99
                                    $99.99
                                    AMD FX-8150 3.6GHz Socket AM3+ Eight-Core Desktop Processor
                                    Item #:N82E16819103960
                                    $249.99
                                    $129.99
                                    $54.99
                                    MSI 970A-G46 ATX AMD Motherboard with UEFI BIOS
                                    Item #:N82E16813130637
                                    $89.99
                                    $21.99
                                    Grand Total:$828.91
                                    (with shipping to texas, this ended up being $845)
                                    personally, I would take the I7, considering how much more performance for only $65 more
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      oh yes I would also recommend getting the 650 FIRST, seeing if it fixes your dell problems, if it dosen't, and the board is indeed fried, just get the rest of the parts
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        From the picture, it looks like the ones under the CPU heat sink are Chemi-con polies, which are reliable and can stay. The others look like small caps less than 470uF, which don't often fail and can also stay, so it's really only the KZGs which you have to worry about.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mamado mosa
                                          Slow boot dell latitude 5410 laptop issues
                                          by mamado mosa
                                          So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                                          The problem is it takes more than a minute to boot ..
                                          The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                                          Can someone suggest something to fix
                                          06-19-2025, 06:55 AM
                                        • JKetcham
                                          Dell 3100 Chromebook Power issues
                                          by JKetcham
                                          Hello, wanting to see if anyone has any experience with Dell 3100 Chromebook's and might have some input on an issue I've been seeing with them.
                                          I work in Technology for a good size school district, and we've began to switch away from Lenovo Chromebooks over to Dell 3100. I like the Dell 3100's because they seem to be more durable than the Lenovo N22's, N23's and 100e's we've used in the past.. but my main complaint with them is they randomly won't turn on.
                                          Currently, in my building I have about 200 students using the Dell 3100's and daily I have a rash of students...
                                          05-04-2022, 11:31 AM
                                          HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) Compaq Elite 8300 i3-3220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) boardview and Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-12-2024, 03:28 PM
                                          HP Compaq Elite 8300 Compaq Elite 8300 i5-3470 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite 8300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8300 boardview and Compaq Elite 8300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
