Dell XPS 8300 issues
  • Kylethedude1
    • Mar 2012
    • 16
    Re: Dell XPS 8300 issues
    Thanks for everyone's help! This forum has helped me ALOT with this issue.
    I just have another question, corsair or antec? Price does somewhat matter, but I'm willing to spend 20-45 bucks more on something that will last longer. is it also true that using non dell PSU's fry components? And is special connectors on Dell PSU'S an issue?
    • c_hegge
      • Sep 2009
      • 5219
      Depends on the series. The corsair TX series are good, but they don't go lowet than 650W. The Antec HCG series are also not too bad, but 520W is as low as they go.
      Personally, I like XFX, since all of their PSUs have good caps. I'd be using (http://www.newegg.com/Product/Produc...82E16817207018 or http://www.newegg.com/Product/Produc...82E16817207013. 450W is enough for your PC, but if you plan on upgrading your PC in the future, then the extra hundred watts won't hurt.
      EDIT: The Dell/Hell specialised connector is a thing of long ago. They all use standard connectors now and have for the last several years, so using a non-Hell branded PSU is perfectly fine.
      • Kylethedude1
        • Mar 2012
        • 16
        And is it true that non dell PSU'S fry components?
        • c_hegge
          • Sep 2009
          • 5219
          Sorry, I edited my last post. It used to be an issue 10 years ago, but it's fine now. I have used non-Hell branded PSUs on lots of Hell Dementia and XPS (Dell Dimension) PCs and it's never been a problem.
          • Kylethedude1
            • Mar 2012
            • 16
            Does the Awful nasty trash thing still apply to antec?
            I might most likely buy an XFX
            • Kylethedude1
              • Mar 2012
              • 16
              Also, I know this is off topic, but should I put some Arctic Silver on my CPU instead of dells cheap crap? I don't think it comes stock.
              Will these PSU'S both fit my case?
              • dmill89
                • Dec 2011
                • 2534
                Originally posted by Kylethedude1
                My PSU says: dell model: AC460AD-00
                REV: A00
                DATE: B1144
                Total Power 460W MAX
                Interesting. That is not a commonly used model and I couldn't find much information on it. I'm guessing the AC means it's and ACbel but I couldn't find any info to confirm that. If you post the UL number (starts with an E, located under the UL symbol) I might be able to confirm the actual manufacture. I'm guessing the multiple failures / replacements is why you got a model of PSU not commonly used in that system, by the time of the repair/ replacement they may have moved to different manufactures than what was used in normal production or they may have tried something different due to the failures. Dell PSUs in general seem to have gone downhill over the last few years. They used to be almost exclusively Delta/Newton, LiteOn, and HiPro, but I have been seeing units from Bestec, Huntkey, and other less than stellar manufactures in recent models, although they still use some Delta/Newton, LiteOn, and HiPro PSUs it is common for them to use multiple PSU manufactures for the same system, making what you get the luck of the draw.
                • c_hegge
                  • Sep 2009
                  • 5219
                  The Awfull Nasty Trash with Exploding Capacitors thing still applies to their low end units, but not the HCGs. Personally, I just don't buy Antec stuff at all because I hate them as a company after the way they tried to cover up the Smartpower disaster and pretend it was never an issue, plus the issues I've had with my case.
                  Any standard ATX PSU will fit in your case, so yes, both of those units will fit.
                  I'd say go for the Arctic Silver. Clean the old stuff off and just put a small blob of it about half the size of a pea in the middle of the CPU.
                  • dmill89
                    • Dec 2011
                    • 2534
                    It can't hurt but probably isn't necessary. The stock thermal compound is generally sufficient since the Dell board isn't overclockable. If you have some AS go for it, It can't hurt and may even improve temps.
                    Yes, The Dell mounting pattern is ATX but the stock PSU is actually slightly oversized compared to standard ATX dimensions so there may be some gaps around the PSU for some units, however any standard ATX unit will fit.
                    • dmill89
                      • Dec 2011
                      • 2534
                      I'm not sure I'd go that far. They might not be as good as high end units but are comparable in their price range. The low-end units do have Ltec(Delta units), OST (SeaSonic units), and CapXon (FSP units) but none of them have anywhere near the failure rate of the Fuhjyyu caps in the old CWT built Antec PSUs. These "budget" PSUs will generally last 4-5 years+ under normal use / conditions which is comparable to most other PSUs in their price range. The HCG and HCP with 100% Japanese caps are more reliable, basically as good as other premium units from good manufactures and HCG/HCP are often priced lower than these competitive premium units.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        LTEC, OST and CapXon are all 'Replace on sight' brands for me. 4-5 years is too short a lifespan for me. I want 10+ years from my PSUs.
                        • dmill89
                          • Dec 2011
                          • 2534
                          I fully agree, but remember that Antecs with these caps are budget units, and I have yet to find a budget unit from any manufacture that has 100% premium Japanese caps. It would be nice to see good quality caps in every PSU from a respectable major manufacture, but at the relatively low price points of budget units manufactures will look to anything that will save money and not increase failure rates during the warranty period, caps are a prime target for this since they have a relatively predictable life span and failure mode. it may only be a few cents per unit but of course when you produce thousands or even millions of units those few cents add up. I'm not saying these are the best PSUs, but they are not any worse than similarly speced and priced units from other major respectable brands.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            XFX don't offer anything without Japanese capacitors. If the manufacturer is really that desparate for the extra few cents, I'll more than happily pay an extra few cents for the PSU. It's nothing but planned obselesence IMO.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              #34
                              I didn't know you minded that much, in that case i'd say go for a corsair tx650. I have a tx850 and I pull 80%+ power off it with no problem
                              antec used to really suck, but in the past few years, their quality has gotten really good.
                              clean off both surfaces with 91% isoprobyl WELL. Put a little dab in the middle, then take ether some plastic surface over your finger (a fresh plastic bag) (I use sterile latex gloves but thats just me) and spread it thin. you want to cover the whole area, but make it thin. The thinner, without smearing it off, the better. There is no better heat transfer then metal on metal, but all the micro chasms on both surfaces actually prevent real metal on metal, which is why you need thermal paste, but a THIN layer
                              edit: oh yeah, and the inside of the earthwatts, as with most PSU's, you never know what you're going to get. I've seen reviews with pics of samxon and rubycons, to UCC's and capxons (and one rubycon). I think the latter versions are better (samxon and rubys)
                              • Kylethedude1
                                • Mar 2012
                                • 16
                                Could the PSUS in my old dells (sent back for replacement since then) be what made the fans go SUPER SUPER Loud and make the smoke+burn smell?
                                And if I'm into gaming on my PC, and multitasking with several applications open, does that affect the PSU I should get?
                                I really appreciate everyone that's helped me with this so far, thank you.
                                • Kylethedude1
                                  • Mar 2012
                                  • 16
                                  I emailed corsair before I visited this forum asking about a good psu and if it could damage my system. And you said I'm fine with my dell 8300 to upgrade the psu right?
                                  This is their reply:
                                  Dear Kyle,
                                  All of our PSUs meet the latest ATX specifications (ATX 2.1-ATX2.3), however not all system manufacturers build their systems to ATX spec.* this is why there are reports of aftermarket power supplies damaging OEM systems. You will neeYd to make sure that the system you have is designed for a standard ATX PSU.* In some cases OEM manufacturers use proprietary or outdated designs, so it is best to check with the system manufacturer to be sure.
                                  • dmill89
                                    • Dec 2011
                                    • 2534
                                    Dear Kyle,
                                    You are fine the proprietary Dell PSUs date back to the Pentium 2 and Pentium 3 era. Once they want to ATX 12v (Pentium 4) Dell went to a standard ATX connector. Given your system is much newer than these non-standard connectors are not an issue for the XPS 8300.
                                    • Kylethedude1
                                      • Mar 2012
                                      • 16
                                      What type of arctic silver is the best?
                                      • dmill89
                                        • Dec 2011
                                        • 2534
                                        Arctic Silver 5 (the actual silver based Arctic Silver) is generally considered best but it is conductive so you must be extremely careful not to get any on any contacts, leads, exposed traces, or surface mount components.
                                        Arctic Silver Ceramique (Ceramic Based non-conductive) is a close second and since it is non-conductive it is much more forgiving to mistakes.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mamado mosa
                                          Slow boot dell latitude 5410 laptop issues
                                          by mamado mosa
                                          So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                                          The problem is it takes more than a minute to boot ..
                                          The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                                          Can someone suggest something to fix
                                          06-19-2025, 06:55 AM
                                        • JKetcham
                                          Dell 3100 Chromebook Power issues
                                          by JKetcham
                                          Hello, wanting to see if anyone has any experience with Dell 3100 Chromebook's and might have some input on an issue I've been seeing with them.
                                          I work in Technology for a good size school district, and we've began to switch away from Lenovo Chromebooks over to Dell 3100. I like the Dell 3100's because they seem to be more durable than the Lenovo N22's, N23's and 100e's we've used in the past.. but my main complaint with them is they randomly won't turn on.
                                          Currently, in my building I have about 200 students using the Dell 3100's and daily I have a rash of students...
                                          05-04-2022, 11:31 AM
                                          HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) Compaq Elite 8300 i3-3220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) boardview and Compaq Elite Compaq Elite 8300 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-12-2024, 03:28 PM
                                          HP Compaq Elite 8300 Compaq Elite 8300 i5-3470 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite 8300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8300 boardview and Compaq Elite 8300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
