Dell Latitude E6410 Bios Passward
  • krjavi
    • Mar 2012
    i used the software and it gave me the right bios password.
    now its asking me for hdd password and when i put the hdd serial it tells me the serial # has to be 11digit long
    heres my hdd serial
    6VCP23YU-2A7B
  • colormebad
    colormebad
    • Dec 2010
    • 114
    Re: Dell Latitude E6410 Bios Passward
    You sure its not asking for the OS password ?
    Here is the quick fix below..
    If you have forgotten your Bios password then you should open your computer case and remove the motherboard battery for five minutes. Find the jumper that resets CMOS (it is usually located near the battery). It has three contacts. Two of them, the first and second, are short - circuited with a jumper. Short-circuit the second and third for a few minutes. This clears CMOS and removes passwords.
    • Ami Sapphire
      Extreme Lurker
      • Sep 2010
      • 180
      Last I remembered, that doesn't seem to work on laptops. Especially on recent laptops like OP's.
      I don't recall the HDD password string with 8 digits and 2A7B, only 11, and then 2A7B. Unless...
      Edit: Read it should be padded with asterisks... Probably either before or after the tag...? Like ***6VCP23YU-2A7B or 6VCP23YU***-2A7B?
      Short service tag should be right padded with '*' up to length 7 chars
      HDD serial number is right 11 chars from real HDDSerNum left padded with '*'
      Some BIOSes has left pad HDD serial number with spaces instead '*'
      Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
      I have two v2s and one v1.
      I am still looking at these boards nearly every day.
      What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
      • krjavi
        • Mar 2012
        well i already got the bios password. now i need the hdd password.
        i know ive done computers in the past and they got 11digit hdd serial, but this one only has 8.
        i removed the hdd and on there it has 8 as well.
        • LatinMcG
          • Jun 2015
          • 73
          • USA/Puerto Rico
          _zu.exe for hdd pass reset on most
          • !!KianBolton302!!
            • Jun 2015
            _zu.exe it is!
            • gizaha
              by gizaha
              02-13-2024, 07:18 AM
            • YOUCEF4787
              Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
              by YOUCEF4787
              I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
              Initial Problem:
              The laptop was completely dead, no signs of life, no power LED.
              Action Taken:
              I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
              Current Situation & The Main Issue:
              The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
              Today, 12:19 PM
            • jhanra
              by jhanra
              11-02-2024, 04:19 AM
            • TripTop
              Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
              by TripTop
              Hi
              i have dell latitude E7270 with following symptoms:
              - takes long time to restart.
              - sometimes powers on and then off
              - sometimes while working it just dies,
              From googling online bios clean could possible resolve this?
              i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
              As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
              I reinstall...
              09-09-2024, 02:05 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
