Reballing does NOT mean it'll last long!
Re: Reballing does NOT mean it'll last long!
I'll have to dig it up but i remember i used the same circuit found in the fan controller of some (cheap) power supplies. One transistor, one resistor and one thermistor is all there is to it.
Btw, the fan in the DVxxxx series can be controlled via software, back then i didn't know that. And ultimately, it wasn't the fault of the reballer, it was a bad chip. I've since pulled it off the board and the solder was perfect underneath.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by thesteveHi. I think I ruined my TV.
So I’ve had a KDL-55EX720 for a long time. We’ve been through a lot. It was out of commission for a few years after developing a white line down the middle of the screen. I fixed it though at the beginning of the pandemic and have been using it as a standing desk computer monitor / second TV.
Well a few weeks ago there was a lightening flash while I was watching TV in the kitchen.
I had three TVs on at the time, all connected (electrically) to the same HDMI output of my cable box.
The kitchen TV recovered just fine... - Loading...
I was watching a HD video and bang. And this time i can rightfully blame the guy who reballed it as it was the GPU which failed. But nothing can stop a man with a heat gun.
) goes to HP, Quanta and a certain dude who does "professional reballs". I'll never trust a computer service in my country ever again.
