She straight up froze.....
  • weirdlookinguy
    • Sep 2007
    • 1638
    Last night I was derping around on my PC, browsing the internet as usual.
    Gigabyte EP45-UD3P
    Core 2 Duo E7500
    XFX Radeon HD 4850
    640GB Caviar Black
    4GB G.Skill DDR2
    400w Delta DPS-400RB
    Antec Solo case with great ventilation
    This is my main PC. My broke college ass only has this and my laptop, so I care deeply about this computer's well-being.
    She has never, ever, let me repeat, EVER given me ANY trouble. She has always been rock solid and fast, just as you would expect from any Gigabyte-based system.
    But last night she straight up froze on me. The cursor stopped moving, the Numlock key stopped responding. I waited a few minutes but she was gone, so I rebooted.
    There was nothing in the event log, and HD tune shows nothing suspicious except for a CRC error count of 18. Nothing else to indicate my Caviar Black is having any sort of trouble.
    I don't know what to make of this, because this computer has been extremely stable until last night. Not just that, but I have never had a Windows PC ever just straight up freeze on me like that without at least an event log entry. Was it a freak occurrence or could something be wrong with my lovely?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4914
    • New Zealand
    Re: She straight up froze.....
    I had random freezing with one of my systems, which in all other respects was OK except a cheapish PSU.
    I replaced the PSU with a Corsair and freezing stopped - for about a month, then it happened again.
    Then one day I noticed I could get it to freeze by touching the VGA cable.
    Reseated the video card and haven't had the issue since.
    I think you just need to wait and see what happens, if it happens again, then you know there's certainly something going on.
    CRC Errors on HDD generally indicate a crappy\loose data and\or power cable, but could also be indicative of a deeper problem, of course.
    -David VanHorn
    • dmill89
      • Dec 2011
      • 2531
      Check to make everything is seated properly all cables are tightly plugged in. One of my old systems had some problems like that and it turned out to be a wifi card that had worked its way loose and was no longer seated properly.
      Also while 400w is enough, it is a little on the low side for that system. I've never seen a Delta that can't deliver its rating but all PSUs deteriorate over time as the Capacitors age so if it is a few years old it may be running near capacity when the system is at 100% load and have difficulty handling that.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        the OP stated he was "browsing the internet like usual" so I doubt the system was at 100% load.
        However, if it happens again, try a different power supply.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          its not the PSU
          his rig has a 400W delta in it... you know, the $40 ex-gateway ones from hypermicro?
          my advice is to go back to using and try to replicate the issue... sometimes freak things happen once and never happen again... if it happens twice, then there probably is an issue.
          sigpic
          (Insert witty quote here)
          • dmill89
            • Dec 2011
            • 2531
            Just putting it in as a possibility if future problems arise. The first suggestion of loose card/connector is far more likely under a light load like that. Could just be a software related random freeze too. not as common on newer OSs but can still happen occasionally, although it's very rear for even the keyboard to stop responding, I've seen it happen once or twice.
            • mockingbird
              • Dec 2008
              • 5484
              Have a look inside the PSU.
              • chopduel
                Bad mains power causing TV malfunctions?
                by chopduel
                I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                • TV would randomly turn off then back on.
                • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                12-29-2024, 03:20 AM
              • Lee M.
                IR night vision goggles to find shorted panel line?
                by Lee M.
                Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
                11-10-2023, 03:19 PM
              • rutgerv
                Acer Swift 3 SF314-42 not powering up
                by rutgerv
                Dear all,
                For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                The issue with the Acer laptop is the following:
                It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                08-02-2024, 06:59 AM
              • gendowor
                boardview msi b150m night elf
                by gendowor
                help me i need msi b150m night elf board viewer ms-7979 ver 1.0. i know paid forums provide it but i dont have enough money to subscribe i hope someone can help me thanks.
                07-06-2023, 02:45 PM
              • phantomEVO
                [help] 820-00840: no ssd, no usb, wifi froze
                by phantomEVO
                i don't know the history of this board…I'm pretty sure that u3900 was touched/changed (i don't know why)
                Motherboard boot with “no disk error.”
                Tried another disk, same error!
                It can't see usb bootable from both usb
                USB stick light stay on fixed
                As soon as i try to boot in Recovery and write the password, it hangs, and then reboot
                any help?​
                03-22-2024, 02:51 AM
