I need to make a fan controller.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    #81
    Re: I need to make a fan controller.
    There are several different types and not all may potentially be an issue when used the way you did, and I think in a lot of cases you may not get a problem because the resistance of them is very high, but it's still probably not a good idea.
    -David VanHorn
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      #82
      So if I'm commando'ing one of my motherboards what do I set it on? wood? cardboard?
      • mariushm
        • May 2011
        • 3799
        #83
        On the cardboard box, or on the layer of foam the board comes in.
        As for your device, some simple mcguyver idea that comes to mind is one or two plastic dvd cases.. drill some holes that fill the holes of that breadboard and you're golden. I guess a thin plywood would also work.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4977
          • New Zealand
          #84
          Watch out with that though, some of that foam can be conductive too...
          -David VanHorn
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            put down a few layers of packing tape or generic gray duct tape onto the mounting surface and set it on that... for tiny boards, electrical tape works too (I did that for a custom board I put in a case once...)
            sigpic
            (Insert witty quote here)
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • master3112
              ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
              by master3112
              I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
              When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
              10-29-2024, 09:32 PM
            • nmbb
              Can not find Model/Value of Thermistor.
              by nmbb
              Machine: Autoclave.
              Brand/Model: SANYO MLS-3780
              Manual: (Sorry search option not working on this PDF)
              Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
              06-02-2022, 05:55 PM
              TL494 PWM Controller Module Booard to control a SMPS switching power supply are they available for this purpose
              I have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
              Dose anymore known if there is such a module and where would I find some
              While searching this topic on google I found this
              https://www.badcaps.net/forum/troubl...anything/page3
              I have read through this I have some switching...
              09-16-2024, 05:39 AM
            • sikocan
              Lenovo X1 Carbon 9th Gen Black Screen
              by sikocan
              I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
              SN: PF3G1REP
              MODEL: 20KW-00J1AU
              PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
              Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
              06-24-2025, 09:01 PM
