My system restarts no warning
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: My system restarts no warning
    Corsair used to be the best stuff you could get.
    I agree they've lost that title. - I think about DDR2.
    If you stay away from their high-end product lines usually it at least usually works.
    Their high-end lines only work sometimes. Very picky. Hit-miss.
    Kingston Value-Ram has worked in everything I've tried it in - even servers.
    [Mostly for server RAM]
    If buying used: Samsung that is branded 'for HP' has worked in everything I've tried it in and sometimes it's really inexpensive because the 'for HP' scares a lot of buyers off.
    I've seen a lot of gripes about Samsung for regular PC's but I've never ever had a problem with Samsung RAM myself so I dunno where those complaints are coming from.
    Maybe they are all using bitchy Asus boards... LOL.
    Mann-Made Global Warming.
    - Dr Seuss
    • c_hegge
      • Sep 2009
      • 5219
      And DDR3 is worse again. not even the lower end stuff works. We always get BSODs in new systems when we use corsair. Kingston works fine.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        That's what I meant. - From DDR2 on.
        Not sure about Corsair DDR [meaning DDR1].
        I haven't seen enough of that to say.
        Corsair PC133 was kick-ass though.
        Back then Kingston was the iffy one.
        - Dr Seuss
        • severach
          • Aug 2007
          • 1055
          I prefer RAM without heat sinks. Heat sinks tell me they are overclocking to push chips to the next speed level and overclocking RAM is excessively uncool. I'll wait 6 months until the chips have improved to where they don't need cooling any more.
          I'd buy if they'd heat sink RAM chips that already run cool but that never happens.
          sig files are for morons
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I think the heat-sinks on RAM are just bells and whistles myself.
            They add a few cents worth of sheet metal and raise the price $5 or $10.
            [IIRC]
            DDR is like 14 watts/stick and heatsinks were rare.
            DDR2 is like 7 watts/stick and heatsinks are common.
            - Yet the surface area is the same....
            Just don't make sense, does it...
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I had some RAM with those thick finned aluminum heatsinks and those actually made matters worse.
              As installed there was almost no clearance between the heatsinks so all those things did was block the air flow between the modules.
              - Dr Seuss
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Corsair XMS DDR sucked. It had cool LEDs but I have never seen a working module of it...
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #28
                  KVR1333D3N9K2/8G
                  Will this be ok is only 61.50 for 8 gigs
                  My pc
                  CPU : AMD PHENOM II x4 @ 3.5Ghz
                  MB : ASUS M4A89TD PRO USB3
                  RAM : Kingston ValueRAM 16gb DDR3
                  PSU : Cooler Master 850W Silent Pro
                  GPU : ATI Radeon HD 6850
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Dunno what your board takes but this is what that RAM is.
                    KVR = Kingston Value RAM
                    1333 = 1333 MHz
                    D3 = DDR3
                    N = Unbuffered
                    9 = CL9
                    K2 = Kit w/2 Modules
                    8G = 8G for the Kit
                    - Dr Seuss
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      #30
                      I know this.
                      It is compatible with my pc (speed and voltage) and unbuffered.
                      No Kingston is on the QVL for 1333 .
                      I have attached the QVL PDF.
                      My pc
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        #31
                        I've had 3 corsair ddr sticks
                        2x512 XMS with silver-colored jackets. put in A8N-E. works beautifully still
                        1x512 /w the cool leds. still works fine.
                        I actually have two sticks of similar to these (except 2x1gb)
                        http://ncix.ca/products/?sku=24035
                        with the fan included. Got them for free, don't ask! Still don't know if they work. Like 4-3-4 shit. I should pop out the old P5N and test them sometime, maybe sell them here if they do. but they're so cool I'm almost afraid to
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Originally posted by joshnz
                          I know this.
                          Forget those RAM compatibility lists. All DDR3 RAM will work with all DDR3 motherboards (well, 99.99% of the time it does).
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            #33
                            Same thing i was thinking.
                            on a side note the issue is just not in windows i'm on linux right now and has reset twice.
                            So It will be ok to go Kingston value ram?
                            My pc
                            • Mad_Professor
                              A Mech Warrior
                              • Feb 2011
                              • 1587
                              #34
                              Originally posted by shovenose
                              IMO Corsair RAM is unreliable crap.
                              +1
                              That is so weird, that corsair got negative rep from here. I've bought corsair for every rig I've built including clients which is alot. Value, XMS, XMS2, XMS3, you name it I've used it. I've only had to RMA twice in my life.
                              I even had those too. 2GB of PC3200 with LED's they were awesome then 5 years down the line one stick died. Called up corsair but they didn't manufacture them anymore, so I had to take some regular XMS in exchange.
                              But about 2 years ago I bought another 2GB DDR2-800 with LEDS and they are still working. But I had to RMA the first batch I got. They worked for 20 minutes after I installed them then the LEDs on one stick died and even the stick no longer registered. Not surprised because I called up newegg and bitch them out for sending these sticks in a simple envelope that had a foot print on it. Considering I work for UPS, I know it was a loose small in a feeder and it fell on the floor when someone was loading or unloading and step on it.
                              Glad to see it working for someone.
                              That's why you go to the memory manufacturer and use their memory finder/compatibility finder tool then when it doesn't work just call and bitch them out. LOL!
                              I still find it weird that I've had use these sticks exclusively and had good experiences with them.
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                #35
                                So green light for Kingston value ram?
                                My pc
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  #36
                                  I'm using the Kingston ram I mentioned above 3 hours OK for now will run some tests later and see if any problems.
                                  My pc
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    @mad_professor: I always buy cheap ram and have NEVER had a stick fail on me, and never had to rma any of it
                                    • severach
                                      • Aug 2007
                                      • 1055
                                      Some RAM passes all tests yet still crashes the machine. I recently diagnosed a DDR3 Dell that had to sit idle 2-3 days to crash. That means I get one test per weekend and it took a week or so to determine the test methodology. It took 4 weeks to swap back and forth between 2 modules but I got it.
                                      I can't always run tests exhaustively so I prefer RAM that has a no hassle no receipt warranty. Most of the time that's Kingston.
                                      DDR3 seems to have made worse the problem where two perfectly good sticks refuse to work together.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        When two sticks work fine individually but won't work together it's usually a RAM voltage regulation problem on the mobo.
                                        Sometimes that's bad caps. Sometimes it's bad VR design.
                                        Some of the socket 478 boards had a bad VR design such that if you went to 4 sticks the RAM started screwing up.
                                        It turned out Intel made a mistake when they published the design requirements for the RAM VR.
                                        Anyone that built boards to the minimum required by the spec ended up with a dodgy board that wouldn't work reliably with 4 sticks.
                                        - Dr Seuss
                                        • joshnz
                                          • Feb 2011
                                          • 969
                                          • New Zealand
                                          #40
                                          Update,
                                          System still stable.
                                          My pc
                                          • Prosatanosz
                                            Asus B85M-GAMER no hdmi output and random restarts
                                            by Prosatanosz
                                            Hi!
                                            Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                                            10-19-2024, 05:27 AM
                                          • guyandpit
                                            Asus tuf fa507r BSOD
                                            by guyandpit
                                            Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                                            05-09-2025, 11:46 PM
                                          • alambrose
                                            LG GRAM random bsod SOLVED
                                            by alambrose
                                            LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                                            Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                                            Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                                            02-12-2023, 06:12 PM
                                          • alleotechno
                                            HP Omen RTX2060 BSOD while nothing presure on CPU
                                            by alleotechno
                                            Details:
                                            Model : Omen HP Laptop 15-DH0038TX
                                            Serial Num : CND93433LW
                                            Product ID : 7LJ89PA#UUF
                                            Bios Version : AMI F.53 4/24/2024 (8600)
                                            Laptop Input Voltage : 19.5Vdc | 10.3a
                                            My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
                                            My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
                                            The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use...
                                            02-04-2025, 10:37 PM
                                          • gshark1
                                            Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
                                            by gshark1
                                            Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
                                            12-29-2023, 04:42 PM
