My system restarts no warning
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hi everyone, my system in the last few weeks has developed a few issues.
    #1. GPU fan needs to be replaced.
    #2. Occasional BSOD and applications crashing.
    #3. Sudden reboots no BSOD system log all clear.
    Problem 1 working to get GPU replaced still under warranty.
    Problem 2 ran memtest386 over night may have a stick bit
    Problem 3 well I have to investigate seems like some 1 presses the reset button I don't have a clue where to find that source thinking ram or psu.
    My system is in my sig.
    any opinions ideas
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: My system restarts no warning
    Well I have noticed restart happens when I'm running vmware player but I think I remember it restarting another time when I was not running vmware.
    Also I can play bf3 for 6+ hours no problem.
    RAM : Corsair XMS3 4GB
    HD0 : Seagate ST3120022A
    HD1 : Seagate ST3750640A
    HD2 : WDC WD3200AAKX-001CA0
    HD3 : WDC WD5000AACS-00ZUB0
    My pc
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      My dad had one, it did the samething. It started crashing. I memtest it, it kept failing but test the ram in another rig it was fine. I RMA'd it 3 times but I still got the same board back, the third time they just removed the serial sticker and replaced it with another one, it still failed memtest.
      The problem was the sideport memory, you can disable it in the bios and memtest again.
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Thanks MP I'll disable it and see if it helps.
        I used to love asus but if this board going to give me more head aches hmmm.
        My pc
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Do you know where the setting in the bios is?
          My pc
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            it's under AI tweaker, "GFX overclocking" set it to disabled or if you need it set it to UMA.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Ah I can't find it due to my model does not have integrated graphics.
              My pc
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Well for now I have unpluged the reset switch.
                It reset when I was in game.
                also so you guys know all my machines have the automatically restart check box unchecked in startup and recovery also this restart happens in either of my win 7 machines
                I will also use it in xp and see if xp can trigger it.
                From what I have read it may be new mainboard time
                If that is the case will it be fine to use same chipset this mb uses?
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  ok so far it still reset with front panel disconnected.
                  I have now reset bios to factory removed all unnecessary hardware.
                  My pc
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Have you scanned for malware?
                    I don't think that's it but it's worth a shot...
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      Possibly.
                      Still reset with the extras removed.
                      Well at the moment i'm running with one core enabled.
                      My pc
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        old mb
                        http://www.asus.com/Motherboards/AMD...specifications
                        maybe future new mb
                        http://www.gigabyte.co.nz/products/p...px?pid=3781#sp
                        and 1.5v ram x2 (gigabyte site says 1.5 my current ram is 1.65)
                        https://cdn.badcaps-static.com/pdfs/...a454e12ce0.pdf
                        My pc
                        • Mad_Professor
                          A Mech Warrior
                          • Feb 2011
                          • 1587
                          That sucks, I have the M4A89GTD PRO/USB3.
                          It sounds like lack of voltage somewhere, bump the volts a little and see what happens.
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            OK bumped up the volts on all mb components and cpu nb.
                            hope it works.
                            What gets me is it can run fine for 6+ hour heavily loaded. and sometimes 30 mins with lite load, I would expect stress to trigger issue.
                            My pc
                            • joshnz
                              • Feb 2011
                              • 969
                              • New Zealand
                              7 hours looking promising.
                              My pc
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                ok got back and it was hard locked so I reset it
                                It hard locked windows boot
                                powered it down then powered it back up and is working again.
                                My pc
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  Turned on today reset it self during windows boot then again when I was using it.
                                  My pc
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    One other thing you can try is using Kingston RAM. If that doesn't help, then it's probably the motherboard.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      IMO Corsair RAM is unreliable crap.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        +1
                                        • Prosatanosz
                                          Asus B85M-GAMER no hdmi output and random restarts
                                          by Prosatanosz
                                          Hi!
                                          Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                                          10-19-2024, 05:27 AM
                                        • guyandpit
                                          Asus tuf fa507r BSOD
                                          by guyandpit
                                          Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                                          05-09-2025, 11:46 PM
                                        • alambrose
                                          LG GRAM random bsod SOLVED
                                          by alambrose
                                          LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                                          Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                                          Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                                          02-12-2023, 06:12 PM
                                        • alleotechno
                                          HP Omen RTX2060 BSOD while nothing presure on CPU
                                          by alleotechno
                                          Details:
                                          Model : Omen HP Laptop 15-DH0038TX
                                          Serial Num : CND93433LW
                                          Product ID : 7LJ89PA#UUF
                                          Bios Version : AMI F.53 4/24/2024 (8600)
                                          Laptop Input Voltage : 19.5Vdc | 10.3a
                                          My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
                                          My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
                                          The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use...
                                          02-04-2025, 10:37 PM
                                        • gshark1
                                          Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
                                          by gshark1
                                          Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
                                          12-29-2023, 04:42 PM
