monitor OS and ups problem
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    I have a strange problem my computer it has an AMD CPU,2 video card's one is an Elsa the second one ATI radeon,8 gig's Kingston ram,CPU clocking is 3.6 ghz and 1MB cache but the problem is one of the four OS-es don't work with the CRT but it work's with the LCD and the other three work with all of the monitor's but on the UPS all of the OS-es work with all of the monitor's I can't for the life of me figure it out?
    PS the OS windows XP,opensuse,deban and PC-BSD.
    Follow the white rabbit.
  • mariushm
    • May 2011
    • 3799
    Re: monitor OS and ups problem
    There were only two ' required in your post... the don't and can't. When in doubt, DO NOT use the apostrophe. It's less of an eyesore.
    The CRT monitor is more sensitive about refresh rate, both horizontal and vertical. Some of those Linux/bsd operating systems don't always detect the CRT monitor properly (their refresh rates) so the monitor won't show any picture, especially if you use DVI to VGA adapters.
    Give more details about how you connect the CRT monitor to the computer....
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      ok MOBO has to video card ports in the first one the Elsa card port one is DVI port 2 is VGA both go to my
      • dumpystig
        • Jul 2011
        • 485
        to your...?
        System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          sorry android keybord
          MOBO has to video card ports in the first one the Elsa card port one is DVI port 2 is VGA both go to my desktop monitors
          card 2 has 4 ports port 1 is the DVI port to the LCD TV in my room port 2 is video in unused port 3 is CATV to the TV in my living room and port 4 is video in from a digital TV converter
          it's windows XP that is the problem
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            deban is gone cent OS is in and it fixed it
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • Askic
              Problem with monitor DS-D5022QE-B
              by Askic
              Hello to all,
              I have a problem with monitor that is delivered together with CCTV system.
              The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
              I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
              05-31-2023, 03:14 AM
            • CptChronic
              Samsung LU32J590UQUXEN Monitor display problem
              by CptChronic
              I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
              Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
              But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
              04-24-2023, 04:33 PM
            • tmhobadcap
              LG 24MP56HQ-P Monitor Backlight problem?
              by tmhobadcap
              I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
              Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
              I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
              10-13-2021, 01:52 PM
            • tmhobadcap
              by tmhobadcap
              10-12-2021, 01:43 PM
