Strange SDRAM DIMM
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    Strange SDRAM DIMM
    What exactly is this?
    Has anyone seen something like this before?
  • brethin
    • Dec 2008
    • 1907
    Re: Strange SDRAM DIMM
    Yep seen them before. Its just a 16 chip stick with all the chips on one side vrs 8 chips on each side.
    • goodpsusearch
      • Oct 2009
      • 2848
      • Greece
      It has chips on the other side too!
      • mariushm
        • May 2011
        • 3799
        Since it has 2 holes on the pin line, it's SDRAM. It has 2 x 8 chips so it's not ECC, it's regular sdram.
        Since the chips are 10 ns rated, it's probably at some low frequency.. 133 Mhz, 128 or 256 MB SDRAM.
        ps. double the size if it has on both sides... but they could have resorted to just using low capacity chips to save money.
        • Old Thrashbarg
          • Jan 2010
          • 20
          10ns is PC66 or PC100. And that's actually a 64MB stick... those are the old 4Mx4 chips that were used on the very early SDRAM DIMMS.
          • mariushm
            • May 2011
            • 3799
            Yes, you're right. I stand corrected.
            I remember now I had memory modules with 7ns chips at 133 Mhz on my first computer, an AMD K6-2 333 Mhz. So the 10ns should be slower.
            The chip above is hy57v164010b ... so it's 64 MB @ 100 mhz.
            • goodpsusearch
              • Oct 2009
              • 2848
              • Greece
              It came out from an old Pentium2 PC.
              • c_hegge
                • Sep 2009
                • 5219
                No, it came from a car. A Hyundai to be exact
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I've seen such things before with registered server memory. Infact I have a double height reg/ecc PC-133 stick with all BGA chips. might post a pic later, but from what i've seen double heights like that are usually server ram, I never even saw old P2's with double height
                  • goodpsusearch
                    • Oct 2009
                    • 2848
                    • Greece
                    I tested the DIMM with Intel 440BX board and it didn't work.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I used to have some like that.
                      The only reason they are uncommon is because back in the day modules like that cost in the 100's of dollars.
                      I've seen similarly 'stacked' modules in 30-pin and 72-pin RAM.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        I've also seen SDRAM with two chips on top of each other. At the time, there was no cheaper way to make high-capacity memory modules.
                        Ludicrous gibs!
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Whoa! That's really cool!
                          • mariushm
                            • May 2011
                            • 3799
                            ram wasn't always so complex though.
                            here's something i still have in my desk... so simple times back then yet so expensive....
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Yep, like this - http://www.ebay.com/itm/M37S64A-15-O...-/370255160561
                              But with the newer memory chips.
                              Ludicrous gibs!
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                as I implied, its probably registered, and will not work on a 440BX
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  It's not registered.
                                  Would need one or two more IC's [which would contain the registers].
                                  http://en.wikipedia.org/wiki/Registered_RAM
                                  Some 440BX do take registered.
                                  Look up Intel N440BX.
                                  It takes either-or.
                                  I've seen 30-pin modules with 36 chips to a module.
                                  - And they weren't piggy-backed.
                                  Very tall for a RAM module.
                                  RAM like in the OP wasn't really that unusual back in the day but it was expensive so lower production.
                                  They either piggy-backed or made them tall to get more RAM on the stick.
                                  If you want to see something actually rare look up SIPP RAM module.
                                  RAM modules with round pins. I once had a PC that used them.
                                  Bugger to find those!!! [Even back then.]
                                  [edit] Found pic.
                                  http://en.wikipedia.org/wiki/SIPP_memory
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    You can get a lot about what RAM is by where the keys are.
                                    This is the OP's RAM with they 'codes' overlaid.
                                    It's run of the mill 3.3v Unbuffered SDRAM.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Better pic from an old mobo manual...
                                      - Dr Seuss
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        you might be wrong. i've seen reg sticks with two register chips on one side, so the reg chips might be on the other side
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • feherhollo
                                          WSON8 NEW Bios Chips READ, ERROR, ETC.
                                          by feherhollo
                                          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                          11-26-2023, 09:33 AM
                                          LENOVO V520 i5-7400 Specification for Upgrade or Repair
                                          This specification for the LENOVO V520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the V520 boardview and V520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO V520 is accurate, safe,...
                                          09-12-2024, 01:58 PM
                                        • Novgorod
                                          Asus Strix Z270i Gaming dead DIMM troubleshoot
                                          by Novgorod
                                          Hi!
                                          I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
                                          What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
                                          07-13-2024, 02:35 PM
