Replaced 3 caps on a gx620, redid the thermal, cleaned and oiled the fan,but it's still running hotter than I think it should. Tried speedfan but apparently the thing has no sensors. Anybody have any ideas how I can speed this fan up_seems pretty slow_or otherwise cool this monkey down?
Hot gx620
Re: Hot gx620
That's the way Dell designs them. They spin the fans slow, so that the PCs are quiet. I have a 960 at work that I run folding@home on... all 4 cores pegged, and it doesn't come up off of idle fan speed.
That's why the caps cook...
Oh, and the boards do have sensors (though sometimes they're built into the fans), they're just not accessable by speedfan.Ludicrous gibs!
Re: Hot gx620
I use this program http://www.diefer.de/i8kfan/index.html
It says its for laptops but it will let you change the fan speed on a Optiplex GX620. The wife has one and I have tested it on her machine. None of the sensors will give a reading but if you just want to control the CPU fan it will do that.Comment
Re: Hot gx620
If you can't control the fans using software, you can use a fan controller. Does this computer use four-wire fans?
Does anybody know what frequency the fan expects on the PWM line? I might be able to design a circuit that switches at the correct frequency and has a temperature and fan failure warning.Comment
Re: Hot gx620
you *might* be able to get a normal sized fan in there to replace the dell one-hooked to molex, but some of those dells have a minimum number of molex connectors so a splitter might be required. I google imaged the 620 and it looks like a normal 60-80mm fan, but make sure you get the widthCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Re: Hot gx620
Brethin, you're doubtless right about the Pci-e, just glanced and assumed it was agp. At any rate it couldn't ever be used with a fan stuck over it.
The fan in it plugs into the board; I'll have to check if it's 3 wire or four. The power supply only has the p4 connector and one sata hd, but I guess I could patch into it; have oodles of fans from an inch up.
Thanks for the other ideas, guys. I'll try Brethin's program; if that doesn't work I might have to get low down and dirty.Comment
Re: Hot gx620
you know if its the heatsink thats hot, this is normal--heatsinks are supposed to be hot, i'd be worried if they were not on a P4. Hot heatsinks mean they're doing thier job
I don't think the cpu fan connector is standard, which is why i'm saying you might have to use a molex connector right from the power supplyCap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: Hot gx620
Hey, good to know! I didn't know there was a new version out. I just tried it on my Optiplex 960, and it was able to read GPU and CPU sensors, as well as the CPU fan. I was also able to adjust the fan speed.Ludicrous gibs!
Re: Hot gx620
Clearly you guys know something I don't. Tried speedfan again, enabled laptop support, but still couldn't get anything. The other program linked does seem to be doing me some good, however, and it shows the fan speed in the launch bar. If I have it set the way I think I do it will speed up if it gets past 131f. Right now I'm running an av and it's 1700rpm_a good bit faster than it was.Comment
Re: Hot gx620
Clearly you guys know something I don't. Tried speedfan again, enabled laptop support, but still couldn't get anything. The other program linked does seem to be doing me some good, however, and it shows the fan speed in the launch bar. If I have it set the way I think I do it will speed up if it gets past 131f. Right now I'm running an av and it's 1700rpm_a good bit faster than it was.Ludicrous gibs!
by macbook1967I can't get my Lefant vacuum go straight after a battery replacement. It continues going in circles in open field or follows the wall constantly. What happened is I had to remove a circuit board to be able to replace a battery. After putting the circuit board back in place the sensor alignment went off, and I can't find the right position for sensors 1 and 2. Sensors 3 are not adjustable. Your help would be very appreciated....10-03-2025, 08:53 AM
I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the... -
by likhsuHi any suggestion would really help.
I have Hp Envy X360 13 which is AMD.
Model : 13-ar0005AU
motherboard No : 18740-1.
Problem : can't turn on.
After inspecting the motherboard, I discovered that one of the hall sensors was broken. Can't find the schematic for this board, so not sure about this SMD device number.
Does anyone know the serial number of this LID Switch?2 Photos -
by insomniacno1Hi,
Anyone here know the name and model number of the Super I/O chip in the L540 20AU (HM86 EXPRESS CHIPSET)?
I need the information to solve an issue in Linux Mint, where fan is not detected correctly.
If anyone know the exact name of the sensor that show fan speed it would also be great.
I tried looking on my motherboard but can't see it without taking the laptop apart and I really don't want to do that. I asked Lenovo, but they are not answering. I searched google for photos of the motherboard but they were too blurry to read anything, according... -
by SleepiestHi, My HP Omen laptop started having performance slowdowns, and while restarts initially fixed it, it seems to have become permanent. GPU-Z shows that it's power limiting the 2070 to 300Mhz constantly, and shows two fields labeled "Board Power Draw" and "PWR_SRC Power Draw" that are sitting idle at about 405-410W. (this with a 230W power supply and basically 0 load). I'm not an expert by any means, but my best guess after looking around seems to be an issue with the shunt resistors(?) on the motherboard. Basically just a sensor giving the wrong reading. Does this sound like...07-23-2024, 10:10 PM
- Loading...
