Hot gx620
  • styxbound
    • Aug 2010
    • 91
    Hot gx620
    Replaced 3 caps on a gx620, redid the thermal, cleaned and oiled the fan,but it's still running hotter than I think it should. Tried speedfan but apparently the thing has no sensors. Anybody have any ideas how I can speed this fan up_seems pretty slow_or otherwise cool this monkey down?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Hot gx620
    That's the way Dell designs them. They spin the fans slow, so that the PCs are quiet. I have a 960 at work that I run folding@home on... all 4 cores pegged, and it doesn't come up off of idle fan speed.
    That's why the caps cook...
    Oh, and the boards do have sensors (though sometimes they're built into the fans), they're just not accessable by speedfan.
    Ludicrous gibs!
    • styxbound
      • Aug 2010
      • 91
      Re: Hot gx620
      The pits. And no room to put another fan either. I'm thinking surely there must be some way to speed this thing up, like what happens, I wonder, if you cut the control wire and just feed straight power?
      • brethin
        • Dec 2008
        • 1907
        Re: Hot gx620
        I use this program http://www.diefer.de/i8kfan/index.html
        It says its for laptops but it will let you change the fan speed on a Optiplex GX620. The wife has one and I have tested it on her machine. None of the sensors will give a reading but if you just want to control the CPU fan it will do that.
        • styxbound
          • Aug 2010
          • 91
          Re: Hot gx620
          Great!_thanks for that. Found about one and a half inches of space over an agp and pci slot; was thinking about rigging a fan in that. Don't know if it would be big enough to do any good anyway though. I'll try your program tomorrow.
          • brethin
            • Dec 2008
            • 1907
            Re: Hot gx620
            Agp slot? Hum you did say GX620 which I assumed you ment Dell Optiplex GX620 and they have no agp slot, only PCI-E and PCI.
            • lti
              • May 2011
              • 2545
              Re: Hot gx620
              If you can't control the fans using software, you can use a fan controller. Does this computer use four-wire fans?
              Does anybody know what frequency the fan expects on the PWM line? I might be able to design a circuit that switches at the correct frequency and has a temperature and fan failure warning.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                Re: Hot gx620
                you *might* be able to get a normal sized fan in there to replace the dell one-hooked to molex, but some of those dells have a minimum number of molex connectors so a splitter might be required. I google imaged the 620 and it looks like a normal 60-80mm fan, but make sure you get the width
                • styxbound
                  • Aug 2010
                  • 91
                  Re: Hot gx620
                  Brethin, you're doubtless right about the Pci-e, just glanced and assumed it was agp. At any rate it couldn't ever be used with a fan stuck over it.
                  The fan in it plugs into the board; I'll have to check if it's 3 wire or four. The power supply only has the p4 connector and one sata hd, but I guess I could patch into it; have oodles of fans from an inch up.
                  Thanks for the other ideas, guys. I'll try Brethin's program; if that doesn't work I might have to get low down and dirty.
                  • brethin
                    • Dec 2008
                    • 1907
                    Re: Hot gx620
                    Its 4 wire. Also I just checked and Speedfan 4.44 now supports Dells so it will let you change the speed of the fan too. You just need to go into the config and enable Dell laptop support. It will also tell you the fan speed.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      Re: Hot gx620
                      you know if its the heatsink thats hot, this is normal--heatsinks are supposed to be hot, i'd be worried if they were not on a P4. Hot heatsinks mean they're doing thier job
                      I don't think the cpu fan connector is standard, which is why i'm saying you might have to use a molex connector right from the power supply
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Re: Hot gx620
                        Hey, good to know! I didn't know there was a new version out. I just tried it on my Optiplex 960, and it was able to read GPU and CPU sensors, as well as the CPU fan. I was also able to adjust the fan speed.
                        Ludicrous gibs!
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          Re: Hot gx620
                          Here's a screencap of speedfan with my fanspeed set at 50% (the dell default). Processor is a Q9650, and it's running F@H
                          And here it is at 100%, after the temps stabilized (about 20 minutes)
                          Ludicrous gibs!
                          • styxbound
                            • Aug 2010
                            • 91
                            Re: Hot gx620
                            Clearly you guys know something I don't. Tried speedfan again, enabled laptop support, but still couldn't get anything. The other program linked does seem to be doing me some good, however, and it shows the fan speed in the launch bar. If I have it set the way I think I do it will speed up if it gets past 131f. Right now I'm running an av and it's 1700rpm_a good bit faster than it was.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Re: Hot gx620
                              Did you restart speedfan after you turned on laptop support? It only reloads the sensors on startup.
                              Ludicrous gibs!
                              • styxbound
                                • Aug 2010
                                • 91
                                Re: Hot gx620
                                Dood, as near as my feeble mind can recall I don't think I did. I'll have to try it again later.
                                • RetroComputingGrotto
                                  IBM LTO 7 Tape Drive - Dust Sensors??
                                  by RetroComputingGrotto
                                  I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                  I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                  09-19-2024, 01:54 AM
                                • likhsu
                                  Hp Envy x360 13 - hall sensors was broken
                                  by likhsu
                                  Hi any suggestion would really help.
                                  I have Hp Envy X360 13 which is AMD.
                                  Model : 13-ar0005AU
                                  motherboard No : 18740-1.
                                  Problem : can't turn on.
                                  After inspecting the motherboard, I discovered that one of the hall sensors was broken. Can't find the schematic for this board, so not sure about this SMD device number.
                                  Does anyone know the serial number of this LID Switch?
                                  03-03-2024, 02:34 AM
                                • insomniacno1
                                  Lenovo Thinkpad L540 - name of the I/O chip that control fan and sensors?
                                  by insomniacno1
                                  Anyone here know the name and model number of the Super I/O chip in the L540 20AU (HM86 EXPRESS CHIPSET)?
                                  I need the information to solve an issue in Linux Mint, where fan is not detected correctly.
                                  If anyone know the exact name of the sensor that show fan speed it would also be great.
                                  I tried looking on my motherboard but can't see it without taking the laptop apart and I really don't want to do that. I asked Lenovo, but they are not answering. I searched google for photos of the motherboard but they were too blurry to read anything, according...
                                  09-26-2024, 11:48 PM
                                • Sleepiest
                                  HP Omen 17 Laptop GPU power sensors
                                  by Sleepiest
                                  Hi, My HP Omen laptop started having performance slowdowns, and while restarts initially fixed it, it seems to have become permanent. GPU-Z shows that it's power limiting the 2070 to 300Mhz constantly, and shows two fields labeled "Board Power Draw" and "PWR_SRC Power Draw" that are sitting idle at about 405-410W. (this with a 230W power supply and basically 0 load). I'm not an expert by any means, but my best guess after looking around seems to be an issue with the shunt resistors(?) on the motherboard. Basically just a sensor giving the wrong reading. Does this sound like...
                                  07-23-2024, 10:10 PM
                                • TheBloke
                                  MBP 13" late-2011 (820-2936-B): bad sensors, need to fix VN0R, IB0R, IC0R
                                  by TheBloke
                                  Hi everyone
                                  I recently bought a used Apple MacBook Pro 13" late 2011 for my mother, but with a known fault. Her existing laptop is old and dying, and I think she'll do better with macOS than Windows, but neither she nor I can afford a fully working Apple laptop. I knew it did turn on and ran the OS, so I hoped it might be fixable.
                                  The symptoms:
                                  1. Only starts with a 10-second press on the Power button. Therefore it can't wake from sleep, only do a full startup each time.
                                  2. In macOS it runs slower than an asthmatic snail slithering through glue with some...
                                  03-28-2018, 02:29 PM
