For the CRT monitor freaks - highest resolution you ran on your tube?
  • ivtec
    replied
    Re: For the CRT monitor freaks - highest resolution you ran on your tube?
    Originally posted by weirdlookinguy
    ^ If I'm ever in MO I'll take that lovely beast off your hands. I fucking love Trinitrons.
    Me too,i have A Trinitron old tube Sony KV36HS500 and i connect it to my computer and to my Roku4 and My Nfusion HD combo OTA Satellite receiver and the HD pic put my Vizio LED and Vizio LCD displays to shame as Picture concern.
    And this Sony has 14 years,i only had to repair it once it was the integrated circuit IC MCZ3001DB that faild.
  • Behemot
    replied
    don't think so
  • TechGeek
    replied
    Ever done 150hZ?
  • Behemot
    replied
    Finally installed the Vision Master Pro 514 (HM204DT) and it's pervert! Back to 1920x1440@85 baby…just have to get used to smaller texts once again lol. But I am looking forward to all those FullHD movies again in full quality!
  • ChaosLegionnaire
    replied
    try the following terminal commands on this page. from the device id e.g. [10de:xxxx] (rev xy), we should be able to figure out what card it is.
  • Compgeke
    replied
    Originally posted by eccerr0r
    Well, as far as I know I have 256MB on this card, which sort of conflicts with the 128M that the Wikipedia article seems to imply that the 6200A . I probably have the 6200LE "low excrement" edition?
    That'd probably be 128 card and 128 Powercache. Powercache just uses some system ram as video ram and slows down the 6200 worse than it already was new.
  • eccerr0r
    replied
    Unfortunately I no longer own any copies of Windows on a machine that can run the card. Hoping the data can be gleaned from debug output from nouveau.
  • ChaosLegionnaire
    replied
    run gpu-z with the driver installed to be sure. look at the number of shaders, texture units and rops then compare it to the list to be sure. evga could have used a non-standard, unofficially supported memory size...
  • eccerr0r
    replied
  • ChaosLegionnaire
    replied
    Originally posted by momaka
    I looked it up - it's an e-GeForce 6200 256MB DDR2 AGP (made by e-VGA). Possibly the 256-A8-N341-LX model.
    Yes, it uses a 64-bit memory bus and it's the latter NV44 GPU with TurboCache (TC). Can't do the softmod on this one to unlock the 4 extra pixel shaders :\ .
    yes, according to this link on wikipedia, eccerr0r has the geforce 6200A. the 'A' version of the 6200 is always on a 64 bit mem bus. ah~ nice memories looking at that gpu list too. excuse me while i stare at it for awhile and then scroll down and hiss and spit at the crappy newer cards~ hahaha~
  • eccerr0r
    replied
    Yeah I was keeping the Rage Pro Turbo AGP (8MB) mostly as a test card, but perhaps now I can use the GeForce 6200 as a test card
    Alas the Rage is probably quite a bit less power than the GeForce. The Rage has no heatsink, and I don't need to worry about it running into any cards right next to it.
    I also have a GeForce4 MX440 and a GeForce2 Ti but both these cards have fans. I think I also have a GeForce 5200 somewhere. I need to find something to do with these cards...
  • goodpsusearch
    replied
    Does that include Rage 128?
    replied
    Originally posted by Dan81
    I don't want to die from the high voltages inside (seriously)
    It would be a quick painless death, so no worries. I promise!
    It's slow however, seems like a 64-bit RAM data bus card.
    Anyways, info here:
    http://www.newegg.com/Product/Produc...82E16814130233
    And the 512 MB version:
    http://www.evga.com/Products/Product...512-a8-n403-lr
    It's a spare... maybe I should dump the Rage.
    Rage is crap. Maybe way-back in the days it was okay. But today, I wouldn't use it for anything else other than a test card to check faulty motherboards.
    256MB 64-bit GeForce 6200, partially recapped.
    Do a full recap - even if it's with ChangX/ChongX/Chong-whatever caps. Those FZ caps are pure garbage. Guaranteed to pop.
    Sorry about hijacking thread... just wonder if the RAMDAC in this is better for my CRT monitors
    That e-Gefore 6200 has a 400 MHz RAMDAC, whereas the Rage has 250 MHz (IIRC). Should be able to do higher resolutions (if needed) with the GF 6200, and yes, it probably does have a better image.
    Originally posted by ChaosLegionnaire
    and lastly, please put a fan on that gf 6200. its affected by the bumpgate scandal which means NO operating at temperatures above 60°C or else u will get treated to an "abstract art painting" on your screen soon enuff...
    ^ What he said.
  • Dan81
    replied
    Even if it's clear, that's still crazy-small on a 17" screen! No scratch that - the viewable diagonal is only 15.9" for 17" CRTs. Did you increase all of the system fonts and icon sizes? I just can't imagine how painful that would be to look at from any reasonable distance without squinting your eyes all the time.
    Anyways, I also wonder what tube that 17" of yours had. My D1025HTX and D1025TM (both 17" Trinitrons) have M41LKN70X and M41LKN50X tubes, respectively. I guess those are run-of-the-mill??
    No doubt it's small. I have to stay very close to the screen so I can read the fonts,especially on Windows 7.
    I still have this monitor,and although it works perfectly,I don't want to die from the high voltages inside (seriously)
  • eccerr0r
    replied
    Before
    https://www.badcaps.net/forum/attach...1&d=1454478594
    After (and yes those two caps on the top also need to be replaced... they )
  • eccerr0r
    replied
    Ah that's probably a good way to guess. And yeah this looks like it's a 64-bit card despite the amount of ram on it (256M). I also have a bunch of Radeon 9250's with 128M but have bumps for another 128M, I wonder how bad it would be to stick more RAM chips on it... and in this case the bumps are in an 'L' formation to each other and thus the 128M upgrade is more of the 128-bit upgrade...
  • ChaosLegionnaire
    replied
    hmm i can help identify if its a 64 bit or 128 bit version by looking at the arrangement/placement of the ram chips. if its arranged in an "L" pattern its 128 bit. if its in an "I" pattern, esp if its a low profile board, its 64bit. post a pic of the card to be sure.
    another way, is to look at the part numbers printed on the ram chips and then looking up the part numbers to see if its an 8, 16 or 32 bit wide individual memory chip then multiply it by the number of ram chips on the card. that will give u either 64 or 128 which is the overall bus width of the video memory.
  • eccerr0r
    replied
    I ended up replacing most of the caps on the GeForce 6200 (256M -- this is a lot of memory compared to most of my video cards minus my 1G RadeonHD 5770). I ended up putting in cheap and some phony caps I "got had" that I had onto it, because I wasn't sure if the card worked. When I first stuck the card in, bad caps and all, my computer would not even finish POST. After putting the "new" caps in, it at least POSTed and looks like the Linux Nouveau driver works fine. It's slow however, seems like a 64-bit RAM data bus card. I'll need to see if there's a way within Linux to be sure.
    Now I wonder if I should replace the rest of the caps. I had chumped the card replacing two pairs of exploded 1000 microfarad capacitors with two fake nichicon 3300 16V microfarad capacitors (which I measured to be 2200 microfarad, probably 10V, and look like teapos). And one 1000 microfarad capacitor I swapped with another 1000 microfarad 16V Chongx. All of them I had to make the capacitors bend over as they're way too high and would run into the card right next to it.
    Since the original caps were all 6V, I figure the slightly higher voltage margin might help things out a bit.
    I suspect this GeForce 6200 may end up killing these new caps too as it's fanless, and probably can get quite hot. Alas, I don't think I'll use this card much anyway. It's a spare... maybe I should dump the Rage.
    replied
    It actually is. Believe it or not,Philips was crazy enough to make that resolution the native resolution. And yes,it's a 100% Trinitron tube.
    The colors are so vivid on it that my Horizon H-W2205S (a custom-built Benq FP92W from what I know) is
    No doubt there.
    I find that 17" and 19" tubes usually offer the best contrast. With the 21" tubes, not always - at least not with my Trinitrons. Only my Hitachi SuperScan 814 has good contrast that is actually comparable to the smaller tubes.
  • Dan81
    replied
    Was anything even visible at that resolution? Also, are you sure it was a Trinitron tube? IIRC, Philips was always shadow mask or Chromaclear in some cases. If it was a Trinitron, I bet the vertical convergence was terrible. Trinitrons always have good horizontal convergence, due to the aperture grill design.
