Re: emachine e725 freezes randomly
you are right it does, but this only works for things only written for x64.
windows has both x32 and x64 versions. going back to my example, say we had a program in 4 bit:
000ilike00my0rod
and in 8 bit:
0000000i0000like000000my00000rod
and upon releasing it as a product, we find out it mistaken as saying something to do with "willy". to fix it, we change it to :
000ilike00myiron0rod
0000000i0000like000000my0000iron00000rod
had we taken advantage of the 8 bit words, we would have 2 completely different codes to manage (one issue would not be the same in the other). in addition, it is much easier and more reliable to use old proven code rather than starting from scratch. you wonder why microsoft copyrights on operating systems mention years long ago (or use a range)? thats because they used old code from then since it was not worth the effort to rewrite that.
think about it, for some things , is it worth all of the code writing, R/D, and bugfixing to rewrite some things? even though they had DOHC engines a long time ago (the offy engine), why did OHV stay a standard for so long? it was not economical to reinvent the wheel (or the engine) when OHV got the job done just fine. it was not until there was enough of an advantage that OHC designs hit consumer vehicles. x64 is the same way, for a lot of operating system things, you may be faster, yes, but the gain would be so little that all of the resources needed to make it work at the same reliability rate would be too much trouble.
a good example would be vistrash. look how bad it was... with such a large overhaul, look how much time and energy it took just to fix things (sp1 and sp2). it would have been less powerful but more reliable if they kept the xp base. as seen, xp did what most needed done, the advantages of vista were of little benefit to most.
make sense at all?
edits to address the latest post:
you do get that part. what you are missing is that by writing stuff to be 64 bits but using mostly 32 bit instructions, you are allowing things that DO use 64 bit instructions to run... things like games, CAD programs, graphics apps, etc.
also, it will run slower x64 because all of the 0's need to go somewhere, so they hog up the RAM. or go to the paging file.
The point is if Win7 32-bit will run [albeit slow] on 1GB then so will Win7 64-bit [albeit slow].
Beyond that, yes we did agree on that. So why you jumping on me when I was expressing that same idea to SOMEONE ELSE?
If you have more than 4Gb it probably is idle most of the time.
[For the average typical PC user I'd say 2Gb.]
And I stand by what I said...
The average typical PC user will never NEED more than 32-bit.
.Leave a comment:
The main point remains: We have cluttered the OP's topic with trash that does not belong here and does not answer any of his questions. And i still run 64-bit whether you like it or not. If 64-bit capability is something you have already, why throw it away ffs? Okay, 64 bit uses twice the memory. Booooooo. But a 64-bit instruction can now execute in a single clock cycle as opposed to two if the processor was running in 32-bit mode. Yay. You have to face it: From a $$$ standpoint more RAM is much cheaper than faster CPU.
PS. Doing 16-bit math in ASM on a 8-bit PIC micro. Not funny.Last edited by Th3_uN1Qu3; 06-25-2011, 03:12 AM.Leave a comment:
Imagine that...I'm not sure you are aware of it, but you can still directly address 32, 16, and even 8 bit registers on a 64 bit CPU. You use as many bits as you need. Just because a variable CAN be 64 bits in length, it doesn't mean that it WILL be. Look up some x86 ASM and you will understand.
@ PCBONEZ: If ratdude747 was right on this one then there would have been no reason to progress past the original 8088 (8 bits) and 8086 (16 bits). Heck, maybe we should be all browsing the internet on PICs and ATMELs. Look, they even got 16 and 32 bit ones. Besides, i didn't buy my RAM to have it sitting idle. And it's a fact that x64 runs better on 2GB and up than 32-bit.Leave a comment:
"But a good programmer could put more instructions in one 'word'." = "you can say more things which in some cases allow using fewer words"
Which validates what I said here..
https://www.badcaps.net/forum/showpo...1&postcount=33
.Leave a comment:
edit for unique- unused bits become zeroes, see belowBut a good programmer could put more instructions in one 'word'.
By your theory 2GB/32-bit = 4GB/64-bit because of the # of 'words' in the code.
If that's true a 32-bit system with 4GB RAM will perform the same as a 64-bit system with 8Gb RAM.
Is that what you're saying?
it will use the same % of memory.
do you program? from my understading in my DE class in high school, the word size has more to do with additional instructions and value sizes. perhaps my knowedge is skewed, but you cannot exactly cram more instructions into a word, you just have more words you can use.
example:
say you could only write words 4 letters (bits) long. ok, you can curse all you want
but you are limited to that specific list of words no longer than 4 letters. any unused places in a word are nulled out by a "0". in a way this is a 4 bit system.
the instruction set is like a dictionary here (defining what means what, so we know 0dog = domesticated canine that eats its own poo).... so you could say things like:
00I like food
0you 0are nice
debt 00is 0gay
but then you want longer words and more words. so we go to an 8 letter system.
since we want to use the same words a s before (old words still mean the same thing) and just ADD to it, it will be like using x86-64. itanium would be like changing and re-defining all of the words, so "00000dog" now = feline that poos in a box of sand and says LOL in a lot of pictures (a cat).
the above would be :
0000000i 0000like 0000food
00000you 00000are 0000nice
0000debt 000000is 00000gay
but we now can say things like:
0000000i 0000love 000000my joystick
00topcat 00000has 0000nice vehicles
if you ignore the spaces, the old 4-word things become double the length:
000ilikefood
0000000i0000like0000food
0you0arenice
00000you00000are0000nice
debt00is0gay
0000debt000000is00000gay
and if the space needed is equivalent to memory, then moving to 64 bit doubles the memory, but you can say more things which in some cases allow using fewer words (in stead of 00up0anddown , you say diagonal). however, with the complexity of an operating system, adding 4 zeros to everything is a lot faster and easier to manage (fixing bugs) then optimizing by using the new words 100% of the time.
0000000i0000hope0000this000clears00things0000000up
(i looked it up, x86-64's legacy mode works like this)Last edited by ratdude747; 06-25-2011, 03:00 AM.Leave a comment:
@ PCBONEZ: If ratdude747 was right on this one then there would have been no reason to progress past the original 8088 (8 bits) and 8086 (16 bits). Heck, maybe we should be all browsing the internet on PICs and ATMELs. Look, they even got 16 and 32 bit ones. Besides, i didn't buy my RAM to have it sitting idle. And it's a fact that x64 runs better on 2GB and up than 32-bit. And we have already agreed that 1GB is not enough to run Windows 7. So, the point is?Last edited by Th3_uN1Qu3; 06-25-2011, 02:49 AM.Leave a comment:
If that's true a 32-bit system with 2GB RAM will perform the same as a 64-bit system with 4Gb RAM.
So, spending twice the $ on RAM to use 64-bit nets zero performance gain?
Are you paying attention Th3_uN1Qu3? - Because I think RD has a point..
To flip it.
A 64-bit system w/4GB will have memory performance approx 1/2 as good as a 32-bit system with 4Gb.
- Because the 32-bit system can hold more 'words' in RAM.
.Last edited by PCBONEZ; 06-25-2011, 02:47 AM.Leave a comment:
hello?
64 bit by itself ALWAYS takes twice the ram. double the word size since everything is 64 bits, not 32 bits.
64 bits has performance increase, yes, but the fact you are in a 64 bit world means you will use double the ram.
doesn't matter how bloated the drivers and whatever are. double is double. what you are saying makes no sense. a 0 still takes up memory. the only way what you said would work would be if you ran out of memory, in that case, you are hitting the page file either way, but 64 bit will hit it a LOT more.
if 64 bit let you write code that was over twice as small (using 64 bit instructions), then it would use the same or less... but taking something and doing a direct conversion will always double the required memory.
the microsoft bit was discussed in the posts before this.Leave a comment:
So obviously what they had last year didn't work and they went right out of business.
- It's a WANT, not a need.Leave a comment:
It takes x-amount of RAM to run a LAN chip, x-amount of RAM to run a Sound chip, x-amount of RAM to run every other chip.
Barring sloppy and/or bloated drivers that [x-amount] doesn't change from 32->64 bit.
Regardless of the 'bits' if you start with 2GB you have the same amount of RAM left for the user regardless if it's 32 or 64 bit.
And: regardless of the 'bits' if you start with 1GB you have the same amount of RAM left for the user regardless if it's 32 or 64 bit.
So MS saying 1GB for 32-bit and 2GB for 64-bit is nothing but marketing bull shit.
.Leave a comment:
Since i have no idea what the original question was, i'll just provide my best guess of an answer: Two 32 bit values still take the same memory space as one 64-bit.Leave a comment:
You're the warmest yet but not right unless that first line was sarcasm.
.Leave a comment:
Is that a *need* -> Not really.
And what % of the servers in the world do that?
.Leave a comment:
Win98 had a metric ton of bugs. I still have a computer that runs Win98 to this day but that doesn't make me love it any more than i did back when i was a little kid who cried for his daddy whenever he broke his computer. Win98 still sucks for most serious intents and purposes. Heck, it even fails at surfing the 'net nowadays. Win2k had less bugs, but had a fair bunch of usability quirks instead.
Because it's the same system.Leave a comment:
by grosseaderHello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
What is the issue:
PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
Hardware:
MSI B450 Gaming Plus Max , MSI A320m A-pro
BIOS : 7B86vHG - latest
CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
GPU: Vega 7 in 3200g and MSI 1060 6GB
RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
...01-30-2023, 03:24 PM -
by pcwhiz24This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
Things I tried so far:
- Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
- BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
- Tried multiple working NVME drives... -
by amingpxhi guys...hp probook 6555b freezes randomly and no key on the keyboard doesnt work..sometimes after 30min somtime after 60min and sometime after 20min..i chech out pads on.the cpu and vga chip..fan is ok...i flash bios..i changed ram..hard...i dont know any more..help me
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
- Loading...
