Call to anyone with RAID 1E experience
  • Digital Technophile
    revrse engineer
    • May 2011
    • 144
    Howdy,
    I've been doing some research into RAID controller card in preparation of a new PC build I'm planning. For a long time I was really sold on RAID-5, until someone pointed out the drawbacks which I agree outweigh the pro's of that mode and started reading up on RAID-6. But I recently found this Areca card, which fits my budget, satisfies my requirement for PCIe bus, and supports a whopping 12 SATA II HDDs! Looking over the specs, I notice a RAID mode I've never seen before... RAID 1E (E=enhanced), which I understand is an IBM developed RAID mode.
    Quiz time:
    1) Anyone have experience with this Areca 1231ML card?
    2) Does anyone have experience with RAID-1E?
    3) If question 2 is yes AND you have experience with RAID-6, which would you prefer for a 4-6 drive array and why?
    I'd also just like to point out this card supports both modes (1E and 6), so unless anyone has some definite reasons I shouldn't get this card I'd like to discuss the pros and cons of these RAID modes.
    Thanks!
    If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Call to anyone with RAID 1E experience
    raid 5 (single redundant) and 6 (dual redundant) still suck donkey balls
    go with raid 10, decent size and less of the parity complications
    raid 1e is non standard, and google is wonderful
    http://www.techrepublic.com/article/...aid-1e/6181460
    • mockingbird
      • Dec 2008
      • 5488
      Are you using Windows or Linux? What type of environment will the computer sit in? I would stay away from proprietary stuff.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Use RAID-1.
        If you need speed use 10,000 RPM drives.
        Generally only a small portion of data needs that much speed anyway.
        The files that aren't accessed often can be on a slower array.
        To get a little more performance use [say] a 36 or 74 GB 10,000 RPM Raptor [or some SCSI 10k] as a dedicated swap/page file drive.
        It doesn't need to be mirrored so can be on a mobo connector.
        [Speeds things up by freeing the drives on the array of the Virtual Memory and/or Swap File duties completely. The heads have more time for the 'real' job.]
        Mann-Made Global Warming.
        - Dr Seuss
          revrse engineer
          • May 2011
          • 144
          Hey that's the article I found when I first searched to see what it was. Nested 1+0 (stripe of mirrors) seemed like a better option than RAID-5, although the latter seems to be more tolerant of a bunch of different sized drives. RAID-6 is a new one to me, but 1E sounds like the most attractive mode to use.
          @mockingbird: I've still got my copy of Server 2003 Standard edition, which I want to get going again (not installed ATM, don't get me started...long story), but I've got an interview with GE Aviation on Tuesday and IF it goes well I'd really really like to put something together that runs VMware ESX; got those hungry eyes for that MSI 890FXA-GD70 main board right now possible paired to a 6-core processor, who knows?
          @PCBONEZ: I'm still working on (got so many damn irons in the fire ATM) getting my Intel D850EMV2 MoBo recapped and upgraded to pc1066 rambus. I also found on fleabay (GOD I love to hate those scumbags) some still sealed 3.5 10k Raptors (WD1600ADFS) that I'm also watching and drooling over. Any recommendations for a PCI bus SATA adapter; Server 2k3 + Intel D850 + SATA II PCI RAID card + 2 WD1600ADFS (80GB) in RAID-1 sounds like good recipe for new domain controller, eh?
          But back to RAID-1E. That Areca 1231ML card supports many RAID modes, but the thought of migrating between different modes sounds time consuming to say the least. Trying to do mathmagic here is making my head hurt. Between 5, 6, and 1E, which has the greatest parity overhead? From what I can gather It's RAID-6, but let's through some variables in the mix.
          What about 4 disk arrays from the three modes in question versus 6 disks? Or even 8 disks (man that better be one honking powersupply; err, maybe if we're talking fault tolerance better make it two honking PS's ), Would there be a difference in the amount of overhead; it seems like an array of more than 5 disks and parity becomes more important to justify the overhead.
          Or how about the size of the disks, which mode become more efficient - an array of 80GB hdds, or one made up of 160 or even 320GB. Then we have to think of time to recover if one drive fails.
          And let's just for the sake of argument consider a 6 disk nested Raid 1+0; three striped mirrors, still a 50% overhead even if it is not overhead associated with parity. Is it faster than the three aforementioned modes?
          And after reading through IBMs pages on RAID levels, I've become curious of the difference between "data redundancy" (RAID-1,1E, 1+0) and "data protection" (RAID-5 and 6). Thoughts? Oh and they really threw a curve ball when they mentioned the existence of modes like 1E+0, 5+1, etc.
          Man, that's a lot to consider, but I've got time. I want to work through this multitude of RAID modes to figure out what has the best performance while maintaining redundancy (or protection?); I haven't checked yet, but I hope that Areca card will work with ESX server...that's going to be the end result of this whole RAID discussion as far as I'm concerned. I'm still rethinking the whole of my storage needs as well; my data's still held hostage by that SATA III and my own blind ignorance and will need a safe place to go when I get it back. But I digress (probably because the hour grows late) for now.
          As always I value your C & C - thanks!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Originally posted by Digital Technophile
            Any recommendations for a PCI bus SATA adapter....
            I'm assuming you mean a RAID SATA controller.
            For 5v PCI slots I [now] use 3Ware 9500 series.
            They are PCI-X but they work in standard PCI slots when there is clearance in front of the slot for the card extension.
            -- Use some electric tape over the otherwise exposed fingers. [Connectors]
            Some people just hack off the extension.
            I haven't gone that far. [Yet.] Haven't needed to.
            If you have a board with the rare 3.3v PCI then you can use the 3Ware 9550 series.
            The 9500 series is 3.3v -or- 5v.
            The 9550 series is 3.3v only.
            Pay attention when shopping for those though.
            Some of them use multi-lane connectors vice standard cables.
            The special cables aren't hard to get but it's a bummer when you think you are about done and discover you don't have the right cables.
            - Dr Seuss
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              the multi-lane SFF 8087? You can get fan-out sata cables for those
              I would imagine raid 6 has the most overhead cause it has to calculate two drive parity stripes per drive
              the size of raid 5 is (n = number of drives, s = size of drives)
              s * (n - 1) for raid 5
              s * (n - 2) for raid 6
              nested raid 10 IMO is till the best bet cause it gives you good space and performance
              raid 5 is still ok if you have a lower number of drives, cause the more drives you have the higher chance of rebulding while another dies, in the case of raid 6 chance of 2 dying, but it has big overhead
              raid 10 dosen't have much overhead cause there is no parity, only striping
                revrse engineer
                • May 2011
                • 144
                Thanks PCBONEZ, I'll check that card out. The Intel board I have has 5v PCI 2.2 slots (and slot 4 has SMBUS routing enabled), so I'll take a look at the 9500. I'm sure I'll have room for PCI-X using your suggestions; never considered doing that and to be honest never read up completely on PCI-X bus specs. Getting this board going as a domain controller just going to require pc1066 RDRAM (seems to becoming more affordable finally), the card and two drives (thinking WD1600ADFS Raptors). I've got two boards the first of which blew two Nichicon HM 6.3v 3300uF 105c caps (oddly the only two Nichi's on the board; the balance are United Chemicons and some polys on the vcore). The second one was still in service when I took it offline, but I'd like to try recapping both starting with the earlier rev. board first. More on that coming soon (some interesting oddities regarding the selection of caps on the earlier board vs. the later board).
                Thanks for all the RAID tips, they are certainly appreciated. I want to get a definite idea of which mode I want to use when the time comes to implement that array. Still somewhat confused over the terms "data redundancy" (mirroring) vs. "data protection" (parity).
                It seems that redundancy means that the data is simply mirrored with no error correction, whereas protection (parity, like with Raid 5 & 6) seems to imply some error correction (like ECC RAM does).
                And what I've come to understand about Raid-1E, it simply means that striping and mirroring occur on a single unnested level.
                So really what I'm down to now and again state the purpose of exploring these modes is for VMware ESX server - will the overhead for RAID 5/6 be that much of a performance penalty considering what that overhead provides ( redundancy ≠ protection (error correction please correct me if I'm wrong). Worse comes to worse, I'll get the components together for this upcoming build (the Areca card supports ALL of these RAID modes we've been discussing) and test the performance of them.
                And URANIUM-235 nested RAID-1+0 is probably the "safe" route. But I don't consider sucking donkey balls a reasonable enough argument not to use them; I'm the kind of guy who also wants to know why (yes mommy hated me when I was a kid ).
                Cheers
                • gerg
                  • Nov 2010
                  • 278
                  The 9550 series are solid cards I would stay away from the 9650 series, I have 100 of them in service and the cards are beginning to fail after only being in service for a year. I have had 3 begin to fail in the last 30 days and it sounds like a common problem with the controller card. It will randomly drop my second raid 1 drives in my suse VM boxes.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I don't have experience with that particular RAID mode but I would stay away from it because there are many properiatry modes like that, from different manufacturers
                    Like RAID 50 etc etc
                    What they all share in common is that if you get in trouble you really are gonna have a hard time to fix it, since it's such a special setup there wont be much info on the web about recovery procedures etc...
                    Stay with tested true RAID modes like RAID5 or 6, or even better RAID1 or 10
                    Also the Raptors are quite old drives nowdays, I can really recommend the Seagate Cheetah 15k.7 drives, they are quite affordable and really puts the Raptors to shame...
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Seagate Cheetah has been around since SCSI-II and Raptor is old?
                      The Raptor line is still in production, so how is that old?
                      And $150 vs $250 [for the same storage capacity] is affordable?
                      http://www.newegg.com/Product/Produc...82E16822136322
                      http://www.newegg.com/Product/Produc...82E16822148538
                      - Dr Seuss
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        raptor line is old and discontinued VELOCIraptor is the new offshoot line from it
                        the seagate cheetah line is still in development, and 15k sas drives can outperform velociraptors, which might be worth the extra $$$. but if you already have raptors, I would say just use those
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Same line as far as I'm concerned.
                          Most other people too.
                          http://en.wikipedia.org/wiki/Western_Digital_Raptor
                          If that small a change [1.5G/s -> 3G/s] makes it a new line then when Cheetah went from U160 -> U320 [and every other transition] then it was a 'new line' each time.
                          - Dr Seuss
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            true but compairing a velociraptor to a sas 15k drive is appes and oranges. cheetas are built to a higher standard. VR's are for enterprise and enthusiast use, you're more likely to find cheetas in server storage then vraptors
                            that isn't the only difference. vr's are 2.5", ice pack cooled and are generally faster, neither can really reach up to the sata limit (150 then 300)anyways
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Which is why I objected to the suggestion.
                              Cheetah's don't reach their interface speed either.
                              Head-disk transfer [media transfer rate] is the bottleneck.
                              - Which incidentally for a Cheetah 15k.7 SAS series is only 122-204 Mb/s. [Looked it up.]
                              -- Still not even close to SATA 1.5 Gb/s interface speed.
                              No, appes and oranges don't look alike at all.
                              - Dr Seuss
                                revrse engineer
                                • May 2011
                                • 144
                                Stay with tested true RAID modes like RAID 5 or 6, or even better RAID 1 or 10
                                Thanks for reply Per. In creating this thread and all of the thoughtful replies with regard to RAID modes, I've been "back to school" scouring the 'net of any and all articles I can get. I just found this one, which explains RAID-1E better than IBM's site (they're the ones who came up with it in the first place)! And reviewing IBM's site, it occurred to me to see what hardware they implement this mode on. And to my surprise, IBM's ServeRAID family of adapters (SAS/SATA) are based wholly on LSI's host bus adapters! And in reading that byte pile article it has become apparent that RAID-1+0 is still superior to this new hybrid RAID-1E (especially if the 1E array contains an odd number of disks). So, I'm feeling pretty good about RAID-10 at this point, but I'm still in consideration of RAID 5 & 6. What is attractive about these two modes is their error correcting capability. For me, it is not enough that that an array is simply "redundant", I like the idea that even through the overhead, the data can remain safe from corruption (a far scarier scenario than simply losing a disk, IMHO). BUT...I feel with the proper hardware overhead can be minimised; and "proper" in the sense that a healthy amount of cash (> $1000) will need to be expended to obtain an IT strength card. As far as "proprietary" RAID technologies go,RAID 1E, 5+0, and 6+0 are becoming more mainstream in the high-end hba's. I would go as far to say as long as a card featured "ROC" (RAID On Chip), I would trust running these modes. That only leaves the last variable in the equation....
                                ....the physical drives (truly the weak link in the chain). As I have no doubt discovered, name brand alone doesn't guarantee reliability. Here, a good measure of discrimination is called for. As my signature proudly states, mechanical hard drives will never be able to saturate a SATA III link period. Not 10k RPM, 15.7k, ever. SAS is a new one to me, I've never had real world experience with them. Yet I see there are SAS 6gbps drives offered?! I'd really like to see some empirical evidence of the drives sustaining that kind of load. As far as apes and oranges go, WD raptors, while not coming close to saturating a SATA II link, still have a measurable improvement over standard 7200 RPM drives. Cheetahs are definitely better suited for SAS (due to their history in the SCSI segment) anyway so there truly isn't a comparison to be made (though they have some bragging rights in the IOPS and random read/writes dept.). BUT as far as speed comparison: SAS = SATA II, and U320 SCSi a tad faster; but again show me a drive that can saturate these links. Haven't seen one yet and probably never will. This is the domain of Solid State Drives!
                                I can still find sealed 80GB WD800ADFS Raptors available for a nice low price, and if I'm really feeling adventurous, I might even scoop some 160GB USED WD1600ADFS drives I've seen there (hey that's what redundancy's for right?). It would be great to try some SAS drives for tickles and grins, but I'd rather direct the funds to a nicer HBA that support both SAS and SATA and be able to upgrade in the future when budget permits. And Velociraptors I scratch my head at trying to understand the reduced size of the platters. As a machinist there's an interesting effect of diameter to RPM ratio called surface speed per minute. Simply stated, a 3.5" platter (for sake of argument) spun at 10k RPM is moving faster at it's periphery (outside edge) than a 2.5" platter spinning at the same speed. I can understand the vibration and balance issues involved, but with the advent of fluid bearings, these effects are minimised considerably. But hey I'm no engineer, so I can't speak with authority in that realm. I will say though I still don't like the ultra high areal densities being bandied about by hard drive manufacturers. I don't care how good the engineering may be, there's just to much complexity and risk involved with owning terabyte HDDs. For me, any new drive I acquire will be <500GB.
                                Thank you all again for your insights and comments, keep 'em coming. It's refreshing to discuss these things with people interested in and knowledgeable in these subjects. And check out that Bytepile article, it's a very good read into those RAID modes.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Power consumption.
                                  They only use about 6 watts. [The Cheetahs are a bit over 16 watts.]
                                  Sounds small but 10 watts x # of drives in an array adds up fast.
                                  Consequently I scratch my head about the need for that heat-sink frame thing.
                                  I think the REAL reason is simply to keep people from putting one in a laptop because Velociraptors use 12v and laptops don't provide that for drives.
                                  - Dr Seuss
                                    revrse engineer
                                    • May 2011
                                    • 144
                                    Power consumption.
                                    Yeah, it's definitely a lot less power to spin those tiny platters. But by the same token that should be producing less heat, thus negating the need for "ice pack" cooling mechanisms. I suppose that's a fancy way of saying 2.5 to 3.5 drive bay caddy
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5045
                                      • US
                                      actually, for once, you're wrong, by 8 (factor of)
                                      122-204 MB/s
                                      one site has it average 166 MB/s = 1328 Mb/sec = 1.3Gb/s, almost to 1.5 gb, but it bursted to 200 MB, which is past 1.5
                                      • severach
                                        • Aug 2007
                                        • 1055
                                        I had a flaky 120GB IDE hard drive that would corrupt data without the drive or controller noting any problem. I diagnosed it by testing copied ZIP files. When I got a SMD tool I replaced the RAM chip and the drive works fine.
                                        I looked high and low for a disk RAID level that would use ECC to help ferret out failing drives that don't know they are failing. Raid 5 and 6 aren't it and none of the others are either. The industry seems unconcerned that drives can be something other than perfect or non working.
                                        Raid 5 buys space at the expense of convenience and speed and Raid 6 uses extra drives to keep the speed up with failed drives. Parity was clever back when hard disks were more expensive than card processors. It's counter productive now that hard drives are so cheap. Once you give up on Raid 5 as a relic from the past a lot of el-cheapo RAID cards without hardware XOR become practical and you can spend the money you'd waste on a phat RAID card on more drives.
                                        Raid 1 Mirror FTW!
                                        sig files are for morons
                                        • canadaboy25
                                          Drive SMART status not showing up through RAID controller?
                                          by canadaboy25
                                          Hey guys,
                                          I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                          Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                          I rebooted...
                                          09-24-2021, 01:56 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • coinwizx
                                          Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                                          by coinwizx
                                          The power supply is 2020 Corsair HX1200 modular power supply.
                                          Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                                          Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                                          09-15-2025, 12:46 PM
                                        • coinwizx
                                          NZXT C850 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                                          by coinwizx
                                          The power supply is 2024 newest version of NZXT C850 modular power supply.
                                          Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then...
                                          09-15-2025, 12:44 PM
                                        • EasyG0ing1
                                          Anyone have experience with an RC driven temporary "ON" transistor switch?
                                          by EasyG0ing1
                                          The idea is to use a transistor to activate a latching relay once a voltage is applied but to prevent a constant voltage from being applied to the relay coil, I thought it might be a good idea if it were possible to make sure that the voltage applied to the coil is temporary even though the source voltage could be "ON" for long periods of time.
                                          This is the circuit that I came up with. I have not tested it yet because I don't have the relay yet, though I am looking for anyone who might have experience with this kind of a setup to hopefully offer some advice,...
                                          07-03-2024, 10:25 AM
