getting quote together for rack build
+ More Options
Posts
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: getting quote together for rack build
    There are no changes from EPS 2.91 to EPS 2.92 that affect connectors unless the PSU has Five +12v rails.
    EA650 is EPS 2.91 compliant.
    http://store.antec.com/Product/power...5-27650-4.aspx
    And a review that clearly show the connectors.
    http://www.techaddicts.net/reviews/ea650/ea650.html
    Mann-Made Global Warming.
    - Dr Seuss
    • Wizard
      • Mar 2008
      • 2296
      #42
      I have finally got the Dell tower case, Optiplex 780 motherboard, E6700 (dual pentium 2.93GHz 1066fsb), 4GB ram (2x2GB). Rest of other parts I use mine. Planning to put together these tomorrow and transfer data.
      Cost is not that bad. Case 30 dollars but it got all the goodies (wires, PSU etc) and Dell heatsink for another 15 (from same mailorder store) 2.93GHz CPU was about 79 , 4GB ram Mushkin was about 45, both local store. Motherboard was about 45 plus shipping and was packed well with 775 socket protector and bagged in antistatic bag.
      This is to replace aging Dimension 8300 with P4 2.8C HT, 2GB (recapped several years ago, and reliable BTW.)
      Cheers, Wizard
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        #43
        what I ment was it just dosen't have the 4 & 8. the pics on newegg show a 4+4 only. Maybe they revised it? if this is a simple linux fileserver & pbx i'm getting half tempted to just get a normal motherboard. I was trying to get something with ECC and high quality. and yes I know ecc is usually a feature I would not need for something this low of usage (simple file server and 6-phone pbx)
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Well, as I already pointed out....
          The ones I have here have the 4+8...
          The one in the review has the 4+8.
          Antec's product page says it's EPS 2.91 compliant which means it has the 4+8.
          That's 3 to 1 against what newegg's crappy picture of the connectors show.
          But you can take what you see in newegg's picture over what two people have observed [myself and that reviewer] and the manufacturer's product information says if you want.
          - Dr Seuss
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            #45
            well I think I may have discovered a cheap way of doing this.
            the link you gave me bonez for the dual sossman board has no io shield. and even yes thats not required, it does bug me
            when you add the cost of the fully buffered dimms, and the heatsinks, it adds up
            but here
            http://www.newegg.com/Product/Produc...82E16813131654
            is an am3 board that supports ddr3 UNREG/UNBUFF ECC
            100% poly caps, with a Athlon II x2 chip (which has naitive ECC support)
            take the hard drive controller down to legacy and use linux raid. this might not be such a bad idea when paired with a earthwatts psu
            it almost feels like that dual xeon board is too much for what they need
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Just because two CPU sockets are there doesn't mean you have to use two CPU's.
              A single 5148 is equivalent to a C2D E6550 so it's less CPU than your original E8400 plan.
              Your going cheaper on RAM [or you think you are] but how does that CPU compare to $18.50 for a 5148?
              http://cgi.ebay.com/180666449825
              Stock Intel coolers can be had cheap and are more than adequate for a 40 watt CPU.
              http://cgi.ebay.com/150587974587
              I actually got a box of 6 new ones for $6.50 each a couple months ago.
              [ They go cheap sometimes because some bare-bones servers come with a heat-sink/fan and so does the retail CPU. They end up with two coolers. ]
              As I pointed out in an earlier link FB RAM can be had for $17.50/GB.
              You probably already know what I think of Asus. - LOL
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Incidentally
                I have a new in box Intel S5000PSL listed in the for sale section, but I only have one.
                - Dr Seuss
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  #48
                  yeah but this is a newer full poly asus and has good reviews. Asus's old days of kgz's and nvidia chips are pretty much over...
                  but yeah you're right.
                  i'm thinking
                  http://cgi.ebay.com/INTEL-SE7520BB2-...item3f033ac4ee
                  and 4 of those 2ghz sossmans. if they're only $9 then why not double up
                  i'm only concerned about the lack of slots, but built in sata ports
                  most of the 771 boards on ebay are hp, dell, or are insanely expensive
                  i'll go for one of those I know has an I/O shield, I can get that board new for ~$40-50
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    #49
                    wait a minute, this board only support. ddr2 400 registered dimms? I thought it was the fully buffered board, hmm those are cheaper (not the fb dimms, the 400 regs are cheaper)
                    hey, whats the single rank and dual rank stuff?
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I mentioned they use regular DDR2 Registered earlier.
                      Remember I suggested that board specifically for a 'dumb' file server.
                      I also mentioned they are 32-bit OS only. - Dunno if that matters.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        http://shop.ebay.com/i.html?_nkw=S50....c0.m270.l1313
                        This one..
                        http://cgi.ebay.com/320699203395
                        .. is a newer revision than mine but the same board.
                        Only difference is it takes the 45nm or 65nm CPU's and mine only takes the 65nm.
                        This one..
                        http://cgi.ebay.com/160589166307
                        .. comes with a pair of coolers.
                        This one..
                        http://cgi.ebay.com/170636037228
                        .. comes with a pair of 5148's -and- a pair of passive coolers [you could add fans to]
                        - Dr Seuss
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          #52
                          I wasn't planning on going 64 bit linux (x86 ubuntu is what i'm planning)
                          they mostly just need a quickbooks fileserver (still messing around /w the quickbooks linux package)
                          the other one will be an elastix pbx, i've already been messing around with it and I like it so far, more updated then trixbox ce
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I dunno how much CPU those programs need.
                            Sossamans are Yonah cores w/2Mb cache & 667FSB.
                            The 2GHz [the common one] is about equivalent to a T2500 Laptop C2D.
                            If those programs are basic office work type programs a pair would certainly handle it.
                            - But use the 4GB RAM plan, it's a multiple user situation and each user needs enough RAM to do their work.
                            - Dr Seuss
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              #54
                              question for some of you linux gurus out there
                              recently i've been playing with quickbooks server manager on a testserver. Of course this is only available as an RPM. I ran alien and converted it all to deb and installed it and the qb diagnostic saw the port just fine, let me open the file, let me run everything perfectly
                              after using it a while, quickbooks started to give me an error when I tried to open up the company, and checked and it reads the QBW as 3.1TB, and the HDD is 8gb (pentium III, 384M, running Ubuntu 10.04.2 LTS). I booted to livecd and ran fsck -a -f and it dosen't give me any serious errors. says someting about 0.1% non-contiguous files, but dosen't say anything about any other kind of errors in the filesystem
                              now, I DID install this with EXT4, should I of just stuck with 3?
                                Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                                Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                                I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                                09-13-2024, 06:47 AM
                              • Dobrowol
                                Dell Latitude 3520 help with bios build/repair
                                by Dobrowol
                                Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                Steps i done and results:
                                I exported a clean bios from update file via pfs extract.
                                1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                Result: Dead
                                2. Build clean bios with no changes in ME, new PMC, PCH
                                Result: Dead
                                3. Build old bios with clean ME, new PMC, PCH
                                Result: The same
                                09-22-2023, 02:43 AM
                                ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                09-12-2024, 03:28 PM
                              • iotaa
                                How to build this little device please for my campervan security
                                by iotaa
                                You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                09-18-2022, 09:52 PM
