p5ld2 vs d915pcy
  • Phaihn
    • Jan 2009
    • 842
    p5ld2 vs d915pcy
    Ive got both of these boards and i was woundering what one would be better to use in a decent high end setup.
    with a p4 Cpu 3.2 ghz cpu 2gbs+ of ram and a good video card in teh near future.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • seanc
    • Nov 2008
    • 1319
    Re: p5ld2 vs d915pcy
    P5LD2 is 945P chipset - has more life left in it. Core 2 & Pentium Dual Core support.
    Have one of these at work covered in Panasonic
    Prepare to buy DDR2 memory.
    • Phaihn
      • Jan 2009
      • 842
      it has 2 and half gigs of ddr2 in it right now i am prolly going to buy more and a video card.
      My Computer.
      • brethin
        • Dec 2008
        • 1907
        *Only PCB R2.0(or higher) support Intel® Core™2 processor
        • Phaihn
          • Jan 2009
          • 842
          it says right on the box that it supports Duel core cpus
          My Computer.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            note that Pentium D's (P4 x2) are also dualcores, while still being slow as shit.
            look up the board revision. if it's V2.0 or higher, the asus is the better board from a technical point of view (Core 2 CPU support).
            if it's not, they're both just old use-/worthless P4-only boards..
            • eccerr0r
              "amd" ddr2...
              by eccerr0r
              So what's with the "AMD" DDR2?
              My (Intel) board "officially" supports 4G DDR2's (four slots, 16G total) but this "AMD" deal is kind of scary recalling back to the old SDRAM deal. In fact I have a few 512M SDRAM modules now but they don't work in my 440BX board, which is too bad, would rather run this board with 2GB RAM through its four slots, else have to use the VIA boards with only 3 slots is the best I can otherwise do.
              But anyway I heard these "AMD" DDR2 still "work" on an Intel board but cannot clock at PC6400...
              03-09-2021, 02:57 AM
            • aaronkatrini
              by aaronkatrini
              - Autorange
              - DC volts up to 30V
              - Accurate Resistance
              - Diode test (Beep mode)
              - Frequency up to 200MHz
              - Capacitanze up to 5000uF
              - as cheap as possible
              05-06-2024, 09:54 AM
            • pkslowk
              Debug Card Error Code and Solution
              by pkslowk
              Sr. Motherboard Debug Error Code Solution
              1 Intel 845 E9 Bios Related Problem
              2 Intel 845 D4 CPU Socket Related problem
              3 Intel 845 37 Bios Related Problem
              4 Intel 845 7C Bios Related Problem
              5 Intel 945GCPE 34 Bios Related Problem
              6 Gigabyte 845 2 Ram Related Problem
              7 IBM Server A6 A7 Ram Mismatch Problem
              8 Asus 845 29 CPU Related Problem
              9 Lenovo I946 97 C-Mos Jumper related
              10 Gigabyte 845 A0 CPU Related Problem
              11 Asrock G31M-VS D7 Bios Related Problem
              12 Compaq 845 BD-70G B0 CPU Socket Related problem...
              01-28-2021, 12:51 PM
            • eccerr0r
              DDR2 resistor packs... 0804?
              by eccerr0r
              Are those typical resistor packs on DDR2 modules 0804 (2010 metric?) 22Ω x 4?
              Wondering what I need to buy if I can't find a sacrificial board with one... which will be annoying if I only need one, just like buying 1 resistor, except I'd be buying 4...
              04-14-2021, 11:56 PM
            • Topcat
              Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
              by Topcat
              This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
              ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
              03-12-2022, 10:58 PM
