Hardware RAID
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Hardware RAID
    Need some input from you characters. I've been spending some (actually most) of my time trying to tie up some (read:quite a few) unfinished projects.
    Is there such a thing as a hardware RAID controller that has RAID5 (RAID6 would be a plus), SATA II, minimum 6 internal drives, PCI bus, and under...oh...say...$300?
    more is always better....except with price
    I have GOT to get this damned HTPC done and off the "bench".
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Hardware RAID
    http://cgi.ebay.com/NEW-3ware-9650SE...item230b747bb1
    I've got one myself. it works like a champ! BBU allows you to safely run write caching. Full hardware RAID, supports all popular arrays, and can get up to 24 channel. I just linked that as a reference, if you hunt you could probably find one cheaper.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • mockingbird
      • Dec 2008
      • 5484
      Re: Hardware RAID
      I assume youre going to fit them in an NAS or an enclosure with a port replicator. I've been doing some reading at storagereview, and if you want to save a lot of money, you should go with ZFS. This way you don't need TLER/CCTL drives, nor an expensive controller. And the redundancy is a lot better too. You will need some familiarity with Linux however.
      • stretch0069
        • Oct 2003
        • 2658
        Re: Hardware RAID
        $400?!?!?!?!?!?!?!
        <cough> <cough>
        <passes out>
        <regains consciousness sometime later.....>
        ok...i guess i need to start taking drugs......or just say screw it......
        i just want a large array that allows redundancy in case a drive fails. I want to put a bunch of ripped DVDs on it and I don't want to have to rerip shit when a drive fails....knock on wood...i haven't had one fail yet...but....
        the Abit IX38 GT I have supposedly has Intel ICH9R RAID5 support. I set the option in BIOS. I get the RAID configurator (prior to OS boot) and set all 6 drives to a single RAID5 array. Then when WinXP 64 boots, I have to tell it is GPT or some shit. Then its happy. Next time I boot it, it tells me I have to format the drive. Yeah right. I don't have the patience to put up with its crap anymore. If I had patience, I'd be a frickin' doctor and if i was a doctor i'd have tons of money to get someone to do this crap for me.
        • mockingbird
          • Dec 2008
          • 5484
          Re: Hardware RAID
          This is not reliable. ICH Raid without TLER/CCTL is unreliable. When your drives deveop weak sectors, there is a timeout period in which they are allowed to recover.
          Drives that allow this to be changed can be set to a short retry period. Common desktop drives try for too long and the array drops them out. Yes, even RAID 5 will be unsafe in this scenario.
          Like I said, set yourself up a cheap Linux box and run the drives in a ZFS array. Won't cost you a penny.
          • severach
            • Aug 2007
            • 1055
            Re: Hardware RAID
            Why not buy a couple of 4 bay enclosures with port multipliers and plug them into the free SATA card included?
            sig files are for morons
            • mockingbird
              • Dec 2008
              • 5484
              Re: Hardware RAID
              No, don't get the cheap enclosures. The Sil multiplexer chip that they use is a piece of junk.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Re: Hardware RAID
                Originally posted by stretch0069
                $400?!?!?!?!?!?!?!
                <cough> <cough>
                <passes out>
                Unfortunately, if you want TRUE hardware SATA2 RAID with more than 4 channels, be prepared to pay, the controllers arent cheap......but in the end, you get what ya paid for. As I mentioned, I linked that one as reference only. They can be had a little cheaper if you dig around.
                Team : 49813
                Join in!!
                Team Stats
                • mockingbird
                  • Dec 2008
                  • 5484
                  Re: Hardware RAID
                  For redundancy, hardware raid is a waste of money. The only thing it's good for is speed.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Re: Hardware RAID
                    Not correct.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Re: Hardware RAID
                      I refer you to this post at the StorageReview forums:
                      Why don't you want TLER even if your disks are capable?
                      If you don't need TLER, then you don't want TLER! Why? Well because TLER is dangerous! Nonesense? Consider this:
                      1. You have a nice RAID5 array on Hardware RAID, being a valuable customer you spent the premium price on TLER capable disks.
                      2. Now one of your disk dies; oh bummer! But hey i have RAID5; i' protected, RIGHT?
                      3. So i buy a new disk, and replace the failed one! So easy, ha ha!
                      4. Oh noooes! A bad sector on of the remaining member disks, and it caused TLER to forfeit; now i got an I/O error during rebuilding my degraded array and the rebuild stopped and i lost access to my data! Arrrrgh!!
                      The danger in TLER lies that if you lost your redundancy, then if a weak sector occurs that COULD be recovered, TLER will force the drive to STOP TRYING after 7 seconds. If it didn't fix it by then, and you lost your redundancy, then TLER is a harmful property instead of a useful one.
                      TLER works best when you got alot of redundancy and can swap disks easily, and want disks that show any sign of weakness - if even just a fart - to be kicked out and replaced ASAP, without causing hickups which are unacceptable to a heavy-duty online money transaction server, for example. So TLER can be useful, but for consumers this is more like an interesting way for vendors to make some more money from you poor souls!
                      Like he says, ZFS is currently the best redundant solution for RAID. Maybe there are hardware cards out there, probably exclusively proprietary, ranging in the thousands of dollars that can do what it does.
                      • smason
                        • 1652
                        Re: Hardware RAID
                        While I agree with you that hardware RAID on SATA isn't worth the trouble, and ZFS is a great solution, that person doesn't get it. Hard to take him seriously when he spells and writes like a 12 year old. TLER prevents the drive from going away and contemplating its navel for 30 seconds. With TLER the drive reports an error, and the RAID controller handles it. Without TLER the controller fails the drive and drops it out of the array. A "heavy-duty online money transaction server" wouldn't be using SATA drives.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Re: Hardware RAID
                          As I've written in other posts on this matter software RAID (the kind of fakeraid implemented on mainboards and cheap add in controllers) is best avoided when it comes to complex RAID levels (like RAID5 or RAID6)
                          They can work quite fine with RAID0, RAID1 or RAID10 though
                          And herein lies the problem, a disk is very cheap today
                          A hardware RAID controller is not so cheap
                          So for example if you want 4TB of usable space you could buy 3x 2TB drives and RAID5 them.
                          Or you could buy 4x 2TB drives and RAID10 them
                          The latter will provide both better performance, better redundancy and lower cost as long as you compare vs a true hardware RAID controller...
                          Disclaimer: I own a LSI 8704ELP RAID controller which i run RAID5 on via 3x 1TB drives, I've also used the same drives before I bought the controller on the ICH9R controller on my Maximus Formula X38 mainboard....
                          • Behemot
                            • 4845
                            • CZ
                            Re: Hardware RAID
                            I agree with SW RAID under Linux. If you want some interesting transfer speeds, Linux (VsFTPd) is the way to go.
                            • TheLaw
                              • Jan 2011
                              • 477
                              Re: Hardware RAID
                              On 32-Bit PCI? You want 6 x Sata 3.0Gbps?
                              I don't think that's physically possible.
                              For PCI-Express, one of these http://www.newegg.com/Product/Produc...82E16816103097 are pretty awesome.
                              You'll need a SAS to SATA breakout cable, which is cheap...
                              • bgavin
                                • Jan 2007
                                • 1355
                                Re: Hardware RAID
                                Back on track, I would be interested in finding a hardware RAID card suitable for ESX 4 (vmware).
                                Most of my operating environment is now on VM, but it would be nice to have the underlying disk system at RAID1 (mirror).
                                As noted above, the consumer/desktop drives present potential problems to ICH raid.
                                I run ICH10 as RAID1 anyway, because potential for a problem is less impact than a single disk failure and guaranteed data loss.
                                Yes, it takes two days to rebuild a 2+2 TB RAID1, but the data is preserved.
                                The super paranoid can also do an ICH10 RAID1 as 3x drives.
                                As noted above, be prepared to pay for stable hardware raid.
                                Those coughing over a few bucks should check into EMC array$...
                                They cost more than most folks make in a life time.
                                • stretch0069
                                  • Oct 2003
                                  • 2658
                                  Re: Hardware RAID
                                  sorry about being away....lots of crap happening.
                                  i think what i will do is use the onboard RAID and do a RAID10 with 1TB drives.
                                  too much crap to think about
                                  we have two EMC big honkin' DASDs at work. Run 24/7....in the past 6 years we've had one 72GB drive go bad, but everything kept running smoothly.....which is good since we keep track of all that metal flying around
                                  • bgavin
                                    • Jan 2007
                                    • 1355
                                    Re: Hardware RAID
                                    We run rows of Symmetrix.. drives go bad all the time... EMC comes in and replaces them.
                                    Life in Big Storage.
                                    Best of luck on the RADI10.
                                    I'm skeptical of Windows+firmware (Intel ICH), so I restrain myself to RAID1 only.
                                    The points made above about TLER issues with consumer level drives are valid.
                                    I've had a couple of arrays crap out, so I try a rebuild on the array first.
                                    If it succeeds, I chalk it up to TLER burps and keep an eye on it.
                                    • stretch0069
                                      • Oct 2003
                                      • 2658
                                      Re: Hardware RAID
                                      here's what sucks.....just did an update to the PS3.....netflix is there....if they have all the movies i have, i just might pay the $8 a month and just not worry about it. plus all the time to rip my DVDs. Still might do a couple of the TV shows I have, but not the whole collection.
                                      Oh well....wait long enough and the world changes around you.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        Re: Hardware RAID
                                        netflix online dosen't have the selection you might think, they don't even have star trek!
                                        anyways, if you want to make any kind of server, linux software raid (mdadm) is what i've used like forever, but keep in mind not all chipsets support hot swapping under linux
                                        thelaw, it certainly is possible because even though 3.0gbps is the protocol, most drives peak at about ~60-70MBps, higher for enterprise class drives (SAS, WD RE's, raptors)
                                        • Hondaman
                                          Hardware firewall to block ad servers?
                                          by Hondaman
                                          I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                                          The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                                          02-05-2025, 05:04 AM
                                        • canadaboy25
                                          Drive SMART status not showing up through RAID controller?
                                          by canadaboy25
                                          Hey guys,
                                          I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                          Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                          I rebooted...
                                          09-24-2021, 01:56 PM
                                        • nobbnobb1
                                          DIY NAS Service Life (Hardware)
                                          by nobbnobb1
                                          So I'm probably a decade behind on this, but my current NAS is a low power machine I built in 2009. It was originally running Windows Home Server, then eventually I migrated to Windows 10 using Storage Spaces for my drive expandability and redundancy. Despite being slow for W10, I love the familiarity and functionality so I never bothered getting into NAS specific OS.
                                          Hardware wise, it's got 4x drives but the hardware is all super low draw, so the Antec EarthWatts EA380D power supply is barely above ambient. This PSU is apparently known for capacitor issues but when I went in to...
                                          09-25-2023, 04:35 PM
                                          Fintek F71868A Super I/O and Hardware Monitor Datasheet
                                          The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
                                          Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
                                          10-23-2024, 02:26 AM
                                          Post your Microsoft Automatic bios Update Hardware ID`s
                                          by SMDFlea
                                          Some of the newest laptops have the capability to automatically update the bios from Microsoft update.
                                          If its enabled there will be Hardware ID listed in device manager under
                                          Firmware - System Firmware - Details - Property - Hardware ID`s - UEFI\RES_
                                          Example: UEFI\RES_{5E28725C-AA01-4AAA-9E44-414B5EE2EA44}
                                          Entering the hardware ID {without the curly brackets} at https://www.catalog.update.microsoft.com/Home.aspx
                                          will show a list of available updates.The downloads are cab files,they can be extracted with winrar or 7-zip.
                                          Each extracted cab...
                                          08-04-2022, 12:30 PM
