PSU specs
  • Allasso
    • Jan 2011
    PSU specs
    Can anyone tell me where I can find specs for G5 iMac PSUs? Specifically I am looking for ripple and noise specs on model # 614-0293.
    Googling hasn't come up with anything so far.
    Thanks,
    Allasso
  • MapleS
    • Nov 2010
    • 7
    Re: PSU specs
    http://www.ebay.com/ or http://www.amazon.com/
    • ryogadan78
      iMac A1418 - No LED, no power after overvoltage on Ethernet port
      by ryogadan78
      Hi guys, I need your help again.
      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
      06-10-2025, 03:49 AM
    • Stephen
      iMac M1 DFU restore issue
      by Stephen
      iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
      this is the message it gives me with the error
      Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
      Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
      03-07-2025, 12:19 PM
    • Stephen
      iMac 27” 2020 Boot issue
      by Stephen
      Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
      08-16-2024, 09:32 AM
    • tommy97
      iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
      by tommy97
      we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
      Any ideas what might've...
      04-20-2024, 04:48 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
