Which nVidia mobo chipsets are bad?
  • mockingbird
    • Dec 2008
    • 5484
    #41
    Re: Which nVidia mobo chipsets are bad?
    acstech:
    I just finished my A8N-E (Recapped) nForce4 system today with Radeon 2900XT and so far it is absolutely rock solid.
    If you want the drivers I'll be using, visit this thread:
    http://www.nforcershq.com/forum/xp-o...ks-t70968.html
    Go to B. "Modded Driverpacks for Windows XP (32/64bit)" and get the non-AHCI version because nForce4 does not support AHCI (Though they claim it somehow supports NCQ without this).
    I'm about to install the drivers, and will let you know how it goes.
    • mockingbird
      • Dec 2008
      • 5484
      #42
      Ok, update:
      I was getting BSOD with the file "ATI2DVAG", I thought it could either be the performance pack, or the Catalyst drivers.
      So, first I tried installing the WHQL, and it took a little longer but eventually crashed. So I remember Catalyst crashing for a customer, so eventhough the latest one works fine for what I'm using now (HD3xxx), I tried the 10.8 for the 2900XT.
      So far it hasn't crash. but Team Fortress 2 is updating, so when it finishes I'll throw at it a few "tests"
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Why did you recap the A8N-E ?
        I'm just upgrading to an A8N-E - all except the tiny caps on mine are Panasonic FJs
        Will try the drivers you've suggested
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • mockingbird
          • Dec 2008
          • 5484
          #44
          Mine had UCC KZGs by the VRM and a few elsewhere. Everything else was Panasonic and some tiny Teapos on the top left corner which I didn't concern myself with. Replaced with Nichicon HM.
          It is stable for now, TF2 is still downloading, but the crash I got was very similar to a new build on an 880G motherboard, so I'm pretty sure it was indeed the new Catalyst driver. Funny, the driver works solid on my Intel based system.
          If everything is ok, I will go back to the performance pack from the WHQL.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Originally posted by NxB
            How about soldering the balls by hand
            That sounds like it would hurt.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by acstech
              Just trust me that I narrowed it down to the board in each instance. It did not happen on just the one board either.
              "What has been seen cannot be unseen."
              Remain skeptical if you want. I really don't care, nor do I have any point to prove here on the internet. I don't get anything for it. You asked, I shared. Period.
              I didn't see it, there for it's unseen, and so I ask questions.
              Shall we call you "Grumpy Mod" in the future?
              - Dr Seuss
              • mockingbird
                • Dec 2008
                • 5484
                #47
                Well my system is 100% stable, I'm going to go back to the performance nForce from whql. The problem was indeed the latest Catalyst drivers which seem to have issues with non-Intel chipsets (Including their own 8xx chipset).
                I played Team Fortress 2 for a bit and the performance of this old Socket 939 + 2900XT system gave a Core i3 with a Radeon 5650 a run for its money.
                Also a correction, my A8N-E doesn't have small Teapos in the top left corner, I was confusing it with the Foxconn... Indeed, everything on it besides the KZG was Panasonic.
                • acstech
                  GrumpyModerator
                  • Jul 2007
                  • 1432
                  Yes, please!
                  The reason it was unseen was that it would take more time, and space, than it's worth to explain my entire testing methodology on this forum. I can't be sitting on here all day; I've got work to do!
                  A man convinced against his will is of the same opinion still.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    as far as i can tell, everything flip-chip & post-RoHS -> trash.
                    i've had GeForce 6800's and 7800/7900's fail with the very same symtoms like the G84/G86 GPUs (GF8400-8600). Plus a bunch of dead 8800/9800GT's and GTX's.
                    As for the chipsets..
                    - Gigabyte 73PVM-S2H Socket 775 (GeForce 7100 / nForce 630i) - doesn't wanna run stable whatever i do. added a fan to the NB heatsink as it was smoking hot (70°C).. made no difference anymore.. dead
                    - half a dozen Asus A8N series Socket 939 boards (nForce 4) - almost never POSTs, locks up if it does POST.
                    - 4 Foxconn GF6xxx series socket 939 boards - they don't always POST. if they do, they just lock up some time afterwards
                    - Biostar GF7025-M2 TE AM2 board (GeForce 7025 / nForce 630a) - random HDD glitches, sometimes lockups with corrupted graphics (onboard), no POST every 15 or so power ups..
                    everything older (up to nForce 3 and the GeForce FX5xxx graphics cards) doesn't seem to have those problems..
                    which is kinda interesting.. since those were pre-RoHS.. go figure..
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #50
                      A8N boards are fine and nForce4 is fine after you change the KZG caps. I have one running 100% stable. Tested with BF1942, Jedi Outcast, Academy and soon Movie Battles 2.
                      I also use it to run Desert Combat dedicated server for when I have 4 way lan games with like 100 bots and 25% CPU.
                      • hardwareguy
                        • Jun 2006
                        • 405
                        Most NVIDIA chipset issues are in small laptops that run hot, this aggravates the RoHS issues they had.
                        nForce 1...the original socket A nForce. Meh....NF2 was way faster due to a dual channel memory interface, but it did work reasonably well. It's not common, I've seen exactly ONE board in the wild. You were better of with a KT400 and a GeForce 2MX....it didn't cost much more either.
                        nForce 2 was rock solid for the Athlon XP, its probably the best all round socket A chipset. Integrated video didn't suck too badly either.
                        nForce 3.... avoid. NF4 is much better and in my experience, much more reliable.
                        nForce 4 / nForce Professional 2200 is solid, just AVOID LIKE THE PLAGUE the Forceware Network Access Manager. That bit of software has more bugs than a roach motel. It has caused BSODs on just about any nForce 4 system I've put it on.
                        nForce 5xx: A minor update to nForce 4. Nothing huge to write home about. Was not produced for very long, 6xx series followed shortly.
                        nForce 6xx....good except for no 45nm LGA775 support. (7xx fixed that). AMD variants are uncommon due to chipset competition from AMD.
                        6150 on laptops is troublesome sometimes, in desktops its usually OK. 7150 has a similar feature set. Two southbridges are available, thee 410 and the 430. The 430 is the one to get, it has gigabit Ethernet. The 6100 and 7100 versions are a slightly reduced feature set version of the 6150 and 7150 respectively. These cheap chipsets are usually paired with the 410 southbridge.
                        G84 is fine on desktops in my experience, laptops occasionally had heating issues. All the other chips are basically solid.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          Here's one, using the nForce 420D chipset - given to me because of bad caps
                          Also has "Twinbank Memory Architecture/128-bit DDR memory controller"
                          • gixie
                            • Feb 2011
                            • 14
                            #53
                            @mockingbird
                            I'm about to do the same with an identical board. I am pretty sure that that's the problem with my board too.
                            Could you send me a pic with the locations of the caps that you changed (and if possible with the specs of the caps)?
                            Thanks in advance!
                            acstech:
                            • mockingbird
                              • Dec 2008
                              • 5484
                              #54
                              Sure, my board is working great, I played hours of Movie Battles 2 on it with a Radeon 2900XT without a hitch. Very fast, though not fast enough to keep me over 20fps with all settings maxxed out. I'm debating whther it's a CPU or GPU bottleneck.
                              I cans end you a pic, but keep in mind that all A8N-Es are different. The board has a mix of UCC and was it Rubycon I think, but Asus interchanged them.
                              Essentially, you want to replace all the brown capacitors with the honeycomb vents on top. If you can post a picture of the board, as well as a list of the caps with their location indicated, I would be glad to show you what you need.
                              • gixie
                                • Feb 2011
                                • 14
                                #55
                                Here's the image:
                                Uploaded with *************
                                Now, the caps are as follows:
                                1 - KZG 1500uf, 6.3V, the red rectangle
                                2 - KZG 1000uf, 16V, the blue rectangle
                                3 - looks like KZG too, 100uf, 16v, the green rectangles
                                4 - no clue about the manufacturer, 820uf, 8.3V, the yellow rectangles
                                5 - no clue about the manufacturer, looks like #4, but different specs, like #1, 1500uf, 6.3V, the purple rectangle.
                                Let me know if you can understand everything properly. And also, which ones I have to change...Looks like, from what I've read, the culprits are the #1's.
                                ...And thanks for your support!
                                • yyonline
                                  • Jul 2009
                                  • 692
                                  Your unknown capacitors appear to be Panasonic, which are very reliable.
                                  Replace all your KZG capacitors and your board should be good. As for the KZG-like capacitors, only KZG and KZJ are bad. KZE and the other series by the same manufacturer are reliable.
                                  I'd also check the small fan while you have the board out of the case. They like to seize up. Replacing it while its apart would be pretty easy.
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    ^ those stupid fans killed a lot of those A8N series boards.
                                    i've seen tons of them where the fan was seized solid or just barely moved..
                                    chipset runs at 90+°C if the fan fails.. kills the chip pretty quickly
                                    • delaware74b
                                      • Apr 2009
                                      • 628
                                      I had an A8N-E board (still in use) where the fan started to scream when the so-called bearings dried up. Put a drop of 3-in-1 oil in it until the replacement fan arrived. I also have an A8N-SLI Deluxe, which is actually older and the fan started to fail last August. I also did the 3-in-1 trick until I got the new fan.
                                      I've rescued a couple of 120mm fans the same way and they're still in use.
                                      Stupidity should be a crime, especially for drivers. I have NO patience for them.
                                      • gixie
                                        • Feb 2011
                                        • 14
                                        #59
                                        Thanks for the tip...BTW what is 3-in-1 oil? Will jig-a-loo work?
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #60
                                          I indicated with an arrow what needs to be replaced. Please confirm that they are all 8mm in width. They should be either 16V 1000uF or 6.3V 1500uF.
                                          For the 16V 1000uF:
                                          http://www.mouser.com/ProductDetail/...E4E2mSMph7c%3d
                                          For the 6.3V 1500uF:
                                          http://www.mouser.com/ProductDetail/...LJ%252bKVJk%3d
                                            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                            10-02-2024, 08:52 AM
                                            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                            10-02-2024, 07:51 AM
                                            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                            10-01-2024, 01:54 PM
                                            HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:30 PM
                                            Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...
                                            09-07-2024, 03:10 AM
