D915GAG RAM issue
  • stevo1210
    • Oct 2006
    • 4156
    D915GAG RAM issue
    My friends computer has an issue where he installed 2x 1GB ram chips and another 2x 512MB ram chips, totalling 3GB... only problem is that it displays only 2.37GB is installed. Even after a BIOS update the issue is still there.
    The motherboard is an Intel D915GAG and the OS is Windows 7 64 bit. If I'm not mistaken the CPU is an Intel P4 3.2GHz... maybe a 640?
    What's the problem here? I'm stumped.
    Thanks.
  • yyonline
    • Jul 2009
    • 692
    Re: D915GAG RAM issue
    Displays 2.37gb where? BIOS setup? In Windows?
    Integrated video will take away some ram...but not that much. Are all the slots working? If there is a dead slot or bad dimm, 2.37 could easily be 2.5 less some for video...just a thought.
    • stevo1210
      • Oct 2006
      • 4156
      it has an external pcie graphics card and it's the bios that displays 2.37GB.
      • yyonline
        • Jul 2009
        • 692
        Ah, ok. The images I googled of D915GAG didn't have a PCI Express slot. I probably pulled up a related board and didn't bother checking it closely.
        The 915 chipset is pre-memory remapping. I think Intel first supported that feature with the ICH7. So, the total addressable space the chipset can use is 4GB. (Much like a 32-bit OS can only use 4GB addressable space, but this is a chipset limitation, not an OS limitation.)
        See p. 55 of the technical spec for more info:
        MS KB article (Vista, but still relevant to Win7):
        http://support.microsoft.com/kb/929605
        How much memory does the video card have? If it's a 1GB card for instance, that puts a huge dent into the 4GB addressable space. If it's less than that, it's much less likely that it would be reserving that much memory for system functions. Futhermore, I'd expect the BIOS to show the installed memory. It's the OS that wouldn't be able to use the reserved memory. The fact that it's the BIOS screen, and not Windows reporting the discrepancy is strongly pointing to some sort of incompatibility or malfunction. I'd try swapping the memory around different modules, different slots, try one at a time, etc. to see if you can isolate the problem somewhat - bad slot, bad memory, partially incompatible memory, etc. I have seen boards with bad memory controllers that do all sorts of weird things, so that's a possibility too.
        • mockingbird
          • Dec 2008
          • 5484
          Interesting.
          That's a good point. Check at the BIOS screen how much ram it's counting.
          • BigTroll
            • Sep 2010
            • 1317
            • LAMBDA SOND
            i have a 915gag board i have 4x512 sticks and have no problems, of course it has the "AWARD WINNING" Kalyway OS X 10.5.2 loaded on it.
            My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Did you perhaps mix high and low density RAM?
              Mann-Made Global Warming.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Sure that system is x64 compatible?
                Not all P4 3.2 GHz support x64
                http://ark.intel.com/Product.aspx?id=27467
                http://ark.intel.com/Product.aspx?id=27466
                D915GAG doesn't officially support Vista or Win7 in 32 or 64 bit.
                http://www.intel.com/support/motherb.../cs-008326.htm
                - Dr Seuss
                • stevo1210
                  • Oct 2006
                  • 4156
                  I have my doubts with the 64 bit CPU bit, I will have to ask my friend again.
                  • yyonline
                    • Jul 2009
                    • 692
                    If Win7 64-bit is actually installed and says 64-bit OS in system properties, then it's definitely a 64-bit CPU.
                    • DqMagetz
                      Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                      by DqMagetz
                      Good day!
                      I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                      Here are the voltage readings:
                      • Input – 19V (stable)
                      • +LCDVDD – 3.3V briefly, then drops to 0V
                      • EDP_HPD – 3.3V briefly, then drops to 0V
                      • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                      • EC BKOFF# – 1.8V briefly, then drops to 0V
                      • PANEL_OD_EN – 0.3V
                      Is it possible that the EC chip is corrupted or damag...
                      07-12-2025, 09:37 PM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • feherhollo
                      WSON8 NEW Bios Chips READ, ERROR, ETC.
                      by feherhollo
                      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                      11-26-2023, 09:33 AM
                    • piernov
                      NVidia bumpgate
                      by piernov
                      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                      May complete this post at a later date with more details.
                      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                      03-27-2021, 10:34 AM
                    • shahnld
                      Lenovo legion 5 pro startup issue
                      by shahnld
                      Good day Experts
                      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                      Today, 12:31 PM
