HP Netraid 4si Firmware Upgrades/Drivers
  • NxB
    • Feb 2009
    • 1595
    I have an HP Netraid 4si controller I'm trying to upgrade. Its very similar to the 3si but it has 4 ports.
    Thing is, I can't find any link to drivers or updates on the HP site. I tried the 3si stuff and while the drivers/software work, the firmware updates don't.
    Any ideas?
  • bgavin
    • Jan 2007
    • 1355
    Re: HP Netraid 4si Firmware Upgrades/Drivers
    If you can identify the PCI ID, you can probably find drivers from Driverpacks.Net.
    You will need:
    VEN_xxxx
    DEV_xxxx
    SUBSYS_xxxxyyyy
    Very often, the SUBSYS won't be a perfect match, and the drivers work just fine. The first two have to match.
    • NxB
      • Feb 2009
      • 1595
      I'm still SOL on the firmware. There is no page at HP for this card. The only thing I find are documents. The 3si has updates that correct issues going till 2005. This one seems to be stuck in 2000.
      • slavetothesound
        HP ProDesk 600 G6 Mini BIOS unlocked - now EC can't find valid firmware
        by slavetothesound
        I Used a T48 and RCUnlocker to remove password from the BIOS on a previously fully functional HP ProDesk 600 G6 Mini. Everything went very smoothly and I was able to boot the machine and install an OS. I then unplugged the machine and put it on the shelf for a week.
        Now when I boot the machine, it does not POST. It plays 5.2 beep codes which are interpreted as:
        I read the firmware with the T48 and it is different than what I flashed to it, so I flashed the unlocked firmware that I had saved. No change. I could use some advice on next steps to take.
        04-12-2024, 10:05 AM
      • gurj1979
        Ubiquiti firmware help. US-8-150W POE
        by gurj1979
        Hi guys.
        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
        Got New chip and writes good.
        THE PROBLEM...
        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
        Does anyone have a Good Firmware I can have?...
        07-22-2024, 05:13 PM
      • titomno2
        Surface Pro 7 type 1866 PD controller firmware issue
        by titomno2
        Hi guys,
        Hope you are fine.
        I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
        The boot time is so long (up to 5-10 minutes).
        After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
        I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
        In the past I have found that if the update is a success, the boot...
        04-27-2025, 01:02 AM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
      • macabook
        πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
        by macabook
        🧩 Initial Issue
        Today, 02:17 PM
