Bad Idea - Adaptec 29160i
  • bigbeark
    • Jan 2010
    • 661
    This is a "brainless" SCSI card. Look closely there is no Bios chip on the card. Had the misfortune to buy several of these, thinking low profile card, how nice.
    These are used in some HP server, the design makes them instant landfill, unusable anywhere else
  • mockingbird
    • Dec 2008
    • 5488
    Re: Bad Idea - Adaptec 29160i
    1) It looks like there are two empty places there for chips to go in. My guess one of them is the cache and the other the BIOS. If you could get a hold of the correct part (It looks like a standard square bios chip you could salvage off a motherboard), you could flash it and solder it on. It's a lot easier than you think.
    2) A lot of motherboards had SCSI bios integrated into theirs for these type of cards. Though I never saw any with Adaptec, mostly LSI IIRC.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i think there are some other missing SMD parts... i wouldn't try that. OEM's like to do that... reminds me of dell dimensions w/o the floppy also missing the floppy caddy... strip it down until it fails, and replace the last part.
      i thought ebay had cards with a brain cheap... i spent $12 for a 2 port 3ware hardware raid ATA133 card... perfect match for the fileserver conversion of a hp evo d530... well, that and a little mod to reroute the HDD light to the card... i came across a lot of old scsi cards with that port cheap... but not compact at all (they were monsters)
      sigpic
      (Insert witty quote here)
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Maybe intended for use as a secondary to a primary 29160 family card, to support > 15 devices, and the primary provides BIOS
        But no use on its own as a primary, as you've discovered
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          if you were running linux (this may be possible with windows as well), you could use a tiny drive for the bootloader and use that to boot the scsi.
          sigpic
