Help after recapping
  • orentha
    • Nov 2005
    • 9
    Hi
    I just received my motherboard back after it was recapped.
    And I cannot get it to work.
    (yes, i have doubled checked and it was put back together properly)
    I get a blue screen stop error message.
    0x000000CE
    Driver_Unloaded_Without_Cancelling_Pending_Operations
    I cannot load up into safe mode, nothing... I get this error everytime, no matter what...
    I'm running Windows2000.
    Any Ideas...
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Help after recapping
    windows got trashed while the caps were bad?
    it happens.
    save important data and reinstall windows without formatting.
    i would try running a live distro like knoppix.
    if it boots to a desktop your hardware is likely ok.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      recommended to do a clean reinstall of win2k
      if you get no file copy errors or crashes on install then all is probably ok
      • orentha
        • Nov 2005
        • 9
        how can I save important data if I get the stop error everytime ??
        • orentha
          • Nov 2005
          • 9
          nevermind
          disregaurd my last post...
          • orentha
            • Nov 2005
            • 9
            OK, still having problems... but a different problem now
            I reinstalled Windows 2000.\
            And now my computer is pretty much doing the same thing as before it was recapped.
            It just reboots from a bugcheck, a lot.
            It's done it twice already, and I've only had teh computer on for about 1 hr...
            any ideas... ??
            • Rainbow
              • Aug 2005
              • 1375
              I'd check the caps in the PSU too.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                can you run some rounds of http://www.memtest86.com/ so we can eliminate bad ram as an issue also.
                check your bios settings, perhaps the board was returned at default settings.
                did you clean the cpu and heatsink, put some new thermal compound, check the heatsink is attached properly and the fan is working.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  all good info.
                  i am leaning toward bad ram.
                  • orentha
                    • Nov 2005
                    • 9
                    Ok, thanks for the ideas. I'm going to run memtest in a little bit.
                    also, I checked out a website that lists what 0x000000D1 errors do, and it said it could be caused by a faulty driver. and I have only installed 2 drivers so far after I reinstalled. One was a driver that came with my motherboard for the built in NIC card. The other was for my soundcard... So I uninstalled the sound card driver yesterday evening, and everything is running fine so far.... (knock on wood)
                    I'll post the results of the memtest after I get this also.
                    thanks for the help.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      you didnt install motherboard chipset drivers? it is recommended. i usually do that first, then vga card drivers before i go blind.
                      recommended to install service pack 4 as well. i have that on many pcs no prob.
                      i usually use updated drivers not the mobo cd. usually it is kinda old.
                      what is the soundcard model? are you using the same driver and slot as before? dissapointing to see pissy drivers
                      • orentha
                        • Nov 2005
                        • 9
                        memtest went just fine. no errors
                        as for the motherboard chipset drivers... I dont have them, and I just looked on Tyan's website, and couldn't find anything for my motherboard...
                        I have upgraded Windows 2000 to SP4.
                        Actually, I did find 1 driver on Tyan's website. it's for the built in network card, so I'm downloading that, and will update that driver.
                        I am using the same slot and driver as beofre for the sound card. I'll check on what kind it is and edit this post.
                        • orentha
                          • Nov 2005
                          • 9
                          I just checked my sound card. I have no idea what it is...
                          It's got nothing to identify it, no brand name, but it does have some stuff printed on a chip on it. it says CMI8738/PCI-SX HRTF Audio Com
                          The driver cd says "mad Dog multimedia" predator blastwave 5.1
                          • Rainbow
                            • Aug 2005
                            • 1375
                            http://www.cmedia.com.tw
                            • orentha
                              • Nov 2005
                              • 9
                              sweet. thanks.
                              I'll check that out
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                what is the motherboard model?
                                • orentha
                                  • Nov 2005
                                  • 9
                                  It is a Tyan S2462 Thunder K7
                                  and after a while, i did find a couple more things on Tyan's website, but wasn't sure if I needed them, their website is not very user friendly...
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    i agree. it is terrible.
                                    i do think that board needs drivers though. if they are not on the cd then email tyan. they will probably refer you to a download of amd reference drivers. nice board btw. perfect for server or workstation. how are you using it. do you have scsi headers?
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16959
                                      One more thing to check that I've seen VERY frequently on AMD systems:
                                      Check the heatsinks and amke sure there's heatsink compound on them, and also make sure that there's enough tension being applied to them, or they'll overheat and cause such problems. Your PSU was just fine, as well as the board. It booted to XP Pro for testing, running SiSoft's burn-in.
                                      <--- Badcaps.net Founder
                                      Badcaps.net Services:
                                      Motherboard Repair Services
                                      http://folding.stanford.edu/
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Originally posted by orentha
                                        0x000000CE
                                        This likely is caused by a buggy driver. Saw this one before when hanging up a 56k modem. (probably buggy modem drivers)
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • laskr1999
                                          DFI Lanparty NF3 250GB recapping
                                          by laskr1999
                                          Hello!
                                          I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
                                          I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
                                          I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
                                          - 20 x Nichicon 1000uF 6.3v HM 105C
                                          - 5 x Chemi-con KZG 1000uF 10V
                                          - 1 x Chemi-con KZG...
                                          11-25-2025, 04:44 PM
                                        • kupa97
                                          Help recapping DFI motherboard
                                          by kupa97
                                          I have a DFI LANParty UT nF4 Ultra-D with A TON of bad capacitors and I need help deciding which caps to replace them with, I've never done this before so I'll use this as a learning experience. I have included a color-coded photo of every single bulging capacitor on this motherboard. All bad caps are KZG, the KY and KMG caps seem to be in perfect condition at least visually. I've read about replacing these caps with polymer ones, but I'm not sure which ones to buy. Thanks.
                                          BLUE = 470uF 16v 8mm x 11.5mm
                                          GREEN = 1000uF 6.3v 8mm x 11.5mm
                                          PINK = 1500uF 16v 10mm x 19.5mm...
                                          11-23-2025, 11:36 PM
                                        • Green Probe
                                          Recapping a Denon AVR X6400h SMPS
                                          by Green Probe
                                          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                          Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                          Always use caution when working around mains power and high voltage capacitors!
                                          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                          SYMPTOMS:
                                          -No display...
                                          07-18-2025, 03:36 PM
                                        • slerner
                                          Recapping KRK VXT6 without original datasheets
                                          by slerner
                                          I'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
                                          Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
                                          Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets...
                                          01-31-2023, 02:21 AM
