I did it!!! k7sem
+ More Options
Posts
  • SonicSteve
    • Oct 2005
    • 54
    I did it!!! k7sem
    I'm a youthworker who also has advanced computer knowledge. OK I also drive a school bus.
    One of the teens I work with is very poor, his mom is in and out of the hospital and quite frail. She can't work because of it. So this teen works many hours and goes to school, takes care of many family related things etc. You get the Idea.
    As a help and ministry to him I fix his computer for nothing when it goes bad. A while ago it turned out that his capacitors were all bad on the ECS k7sem board he had. They were G-Luxon caps and they were all buldging.
    Thanks to all of you here I was able to learn how to replace them and the computer is now updating itself behind me as I type this. In the words of Old Doc frankenstein " ITS ALIVE"!!!
    I'm still in a bit of shock that I did it!
    Thank you to each of you for your posts and great FAQ's.
    Steve
  • AK0R
    • Mar 2005
    • 204
    Re: I did it!!! k7sem
    Good job all around (and not just for getting the computer working again!)
    • Chris1992
      • Apr 2005
      • 561
      Great to hear success stories, especially ones done for the good of others.
      The great capacitor showdown!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        nice work Steve you sound like a great guy
        we just love to hear success stories
        i remember that feeling....wow....
        can you tell us a bit about how you did it. what iron did you use and what method you used.
        • SonicSteve
          • Oct 2005
          • 54
          OK so here's the full story.
          I run a youth program with Youth 4 Christ called Sonic. We play games (gamecube) and refurbish computers I also have a "spiritual discussion" time. Over the summer I was given an Acer P3 computer. It would freeze everytime windows would boot up. One of my teens showed me that all the main caps were not only bulding but leaking too. For some reason I got the idea that maybe i could replace them. I then found this site and spent quite a bit of time reading all the FAQs and guides. From there I talked to the computer guy at the school that I drive for and He gave me two more boards with bad caps. Since they were AMD socket A the P3 acer went on the back burner. I ordered replacement caps and literally a week after they came my friend (the teen) mentioned that his computer was giving him loads of trouble. When I looked at it realized that all the main caps were buldging and to boot they were the same value as the ones I ordered! 2200uf 6.3v 105c. Thanks to you guys I targeted a good name brand nichicon.
          I then found out that a father of one of the kids on my bus works on electonics all day long and arranged for him to give me some pointers. like;
          1. Its all about heat transfer
          2. Solder isn't soup don't stir it
          I use a Weller wlc100 that I bought just for these projects (I've never soldered anything in my life before) with my birthday money. I read enough from you guys that I thought a variable control temperature would be good.
          I used your method of heating one side of the bad cap and bending it out then heating the other side. I have a bulb sucker to remove the solder but in the end I used the stainless steel pin to clear the holes. You guys were so right clearing the holes was far and away the hardest part. I found that in order to heat the holes enough I had to turn the temp up slightly past 4 out of 5. This would be about 830c.
          This was a very rewarding experience.
          • SonicSteve
            • Oct 2005
            • 54
            I forgot to mention that used the solder tip that the weller came with. It's much like a flat head screwdriver.
            • stretch0069
              Screwed Up Super Moderator
              • Oct 2003
              • 2658
              • oooo ess aaaaaaaaa
              Good on ya, mate.
              "Its all about the boom....."
              Guns kill people like spoons made Rosie O'Donnell fat.
              We now return you to your regularly scheduled drinking.
              "Fear accompanies the possibility of death.....calm shepherds its certainty"
              Originally posted by Topcat
              AWD is just training wheels for RWD.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i can hear it now.
                kids go home and parents ask what they did today.
                we learned to recap computer boards!
                huh?
                good work.
                put a few pc's back in use that would likely get junked.saved the kids some money too.
                • handsworth
                  Frankenstein TV
                  by handsworth
                  Anybody ever build a frankenstein tv just for fun? I took 2 similar 55" Samsungs (circa 2012) and built 1 that looks good and works well. Tcon is taped down and the Main and screen wont match the label, so I wont sell it to anyone, but it was fun building it. What do you guys do when you put things together like this? I dont need another tv. Guess its a garage tv
                  10-14-2020, 06:56 PM
                • Oled_gambler
                  LG OLED; Component-level repair on OLED panel?
                  by Oled_gambler
                  So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
                  one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
                  Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
                  Looks like the actual panel is at fault. I can...
                  11-22-2024, 03:58 PM
                • elpatxi_bcn
                  Samsung HG75EJ690UB Hotel TV, change main?
                  by elpatxi_bcn
                  Hello!
                  I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                  Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                  The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                  05-19-2023, 03:21 AM
                • grimacelord
                  Mac Mini Late 2018 |A1993| Fan Connector Damage & Lots of Weird Issues
                  by grimacelord
                  Hi guys.
                  I have a customer's Late 2018 Mac Mini in for a ripped fan connector after the customer tried upgrading his RAM.
                  Some pretty hefty damage occurred because the connector was ripped off entirely including all 6 pads for the fan connector. The connector on the end of the fan itself was also completely ripped off exposing all 6 wires. There is also an exploded component with what appears to be a resistor or filter. Not sure? (See pic). macOS also doesn't boot. Apple logo comes on screen and then moves to the question mark folder. Cannot boot from USB or Recovery...
                  05-30-2020, 05:52 AM
                • texassoul
                  Acer AL2416W No Logo, Backlight works, Still no picture.
                  by texassoul
                  Hello Folks.
                  I have read through every thread I could find on this website and I don't seem to see anyone with the same issue as I have.
                  This monitor was working a week ago. Then all of the sudden it just went dark on boot up. The backlight is on, and no logo or image shows when hooked up to a working source. The green led stays lit.
                  Probably worth mentioning that for months before this happened the menu would pop up and stay on and flicker randomly. It should also be noted that I have 2 of these monitors and one of them is still functioning fine.
                  First I tried...
                  02-16-2018, 09:24 PM
