Frankenstein TV
  • handsworth
    • Oct 2015
    • 175
    Frankenstein TV
    Anybody ever build a frankenstein tv just for fun? I took 2 similar 55" Samsungs (circa 2012) and built 1 that looks good and works well. Tcon is taped down and the Main and screen wont match the label, so I wont sell it to anyone, but it was fun building it. What do you guys do when you put things together like this? I dont need another tv. Guess its a garage tv
  • nomoresonys
    • 12331
    • U.S.
    Re: Frankenstein TV
    Give it to a friend or poor relative.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Re: Frankenstein TV
      I made one out of Vizio parts. One screw in each backlight inverter and epoxy to hold it in place.
        Lift Master garage door opener with WiFi capability application through your phone
        I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
        This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
        01-21-2023, 08:31 PM
        Linear Garage Door Opener Control board took a crap install a new control board back normal
        I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
        02-08-2025, 06:52 AM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • jm1234
        Garage door module Nice SNA4/A - burnt component
        by jm1234
        I'm trying to guess what component got burnt on the control board for my Nice garage door motor Nice SNA4/A. You can see it in front of the 2 capacitors. The component is connected across the 36V rectified input wires, maybe it was some kind of protection device?
        All the pictures I could find were of the whole product, so enclosed in the plastic box, eg. https://www.ebay.co.uk/itm/123998876212
        Any help appreciated.
        06-28-2024, 03:06 AM
