Silicon image Sil3114 bios update
  • Xenon-Codex
    • 183
    • Finland
    Does anybody have update for these? It does not support over 500GB HD's.
    AM29F010 memory chip.
    I found some but those didn't work.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Silicon image Sil3114 bios update
    That's a really old chipset. I remember those back in the XP days....and when transitioning to 7, driver support was also very sketchy. I don't recall diddling with the firmwares for these. Is there something specific you need this controller for?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Xenon-Codex
      • 183
      • Finland
      It was in my backup-computer. Needed to build a new one. Probably e-waste then.
        • 30994
        bound to be a card out there with LBA48 bios on it.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          have u checked the vogons forums? they have a number of threads there with firmwares for the sil3112 and sil3114 pci raid cards. VOGONS Vintage Driver Library - Silicon Image SiI3114 file collection 101.49 MiB
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • al3m0di
            Update bios EFCN58WW to EFCN59WW
            by al3m0di
            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
            The BIOS version is EFCN58WW.
            When I turn on the device, it displays the message:
            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
            I've tried
            07-29-2024, 10:32 AM
          • Focus2005
            HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
            by Focus2005
            Hello everyone.
            I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
            05-01-2025, 05:41 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
