Lenovo ThinkBook 15p G2 ITH BIOS update, laptop does not turn on with image
  • grigor0088
    • Jul 2018
    • Poland
    Hello, when updating the BIOS batch from under Windows, the laptop does not start with the image, in the attachments I am sending the batches copied from the BIOS chip. Please help
    S/N: PF3A8L60
  • volinakis
    • Jan 2021
    • 2748
    • N/A
    S/N: PF3A8L60
    try
    • grigor0088
      • Jul 2018
      • Poland
      Hi, Volinakis, thx for you, but Bios Dump it's doesn't work. It's same problem, laptop turn on but lightscreen is black and laptop restart. I also uploaded the BIOS dump from this thread and after the startup sequence the backlight comes on for 1 second and then goes off, leaving the screen dark. I uploaded the BIOS file uploaded by the user: BruBi
      Greetings, please can someone help me delete my bios password for Lenovo ThinkBook 15p G2 ITH BIOS password. Chips are: UB3 - winbond 25q128jv UB1iUB2 - gigadevice 25r64csig thanks in advance​
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • al3m0di
        Update bios EFCN58WW to EFCN59WW
        by al3m0di
        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
        The BIOS version is EFCN58WW.
        When I turn on the device, it displays the message:
        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
        I've tried
        07-29-2024, 10:32 AM
      • Focus2005
        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
        by Focus2005
        Hello everyone.
        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
        05-01-2025, 05:41 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
