DIY PSU load tester
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    DIY PSU load tester
    Since shovenose got me started on it, i'm going to build one. Most of the specs i decided upon you can see here: https://www.badcaps.net/forum/showth...?t=7319&page=3
    Considering the demand for cheap ATX PSUs here, i think i could even be in business. Time to give a friend of mine some competition hehehe. If anyone has something to contribute about the specs, comments are welcome. I'm thinking of something along these lines:
    • 700W loading capability. This should easily cover 90% of PSUs.
    • Adjustable load by means of a variable voltage source driving a bunch of MOSFETs thru their linear range.
    • Four amp meters and four MOSFET banks. Two for the 12v rails, one 5v and one 3.3v. Simple resistor loading for -12v, -5v and 5vsb, no amp meters needed there.
    • Opamp-based voltmeters and ripple detectors. Latched LED indicators that show whether any of the rails has gotten our of spec during the test, and what got out of spec (voltage or ripple).
    • No power supply required. The load tester shall derive all necessary voltages from the 12v rail of the PSU under test.
    • Output terminals for connecting an external voltmeter or oscilloscope to any of the rails.
    • Variable speed fans and over temperature protection.
    • Cost: Under $150.
    Other stuff you will need to borrow, steal or beg for to calibrate the tester:
    • Oscilloscope >10MHz
    • High current, high precision amp meter
    So whatcha think? I'll start designing the ripple meters and come with some schematics.
    A working TV? How boring!
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: DIY PSU load tester
    dont know how mosfets work
    and i have no oscillioscope.
    o.o what do i need that for?
    can i just attach the mosfets to a metal case? good enuff heatsink? or can i use psu heatsinks?
    please make one, post pictures, schematics, then i will be able to make one. thanks!
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      If not your PSU also, your current motherboard definitely uses MOSFETs for all its voltage regulation needs, so you should learn how they work. MOSFETs are esentially voltage controlled resistors, but they can also be used as switches. In a linear application, the resistor between drain and source is adjusted by varying the voltage going to the gate. This is called biasing.
      In a switching application, the MOSFET is intended to switch between the lowest (piece of wire) and highest (basically open) resistances. In a switch-mode power supply this switching must be done as quickly as possible, because if the MOSFET is in its linear range it does nothing more than dissipate heat. So to keep them cool in a SMPS application, high current drive circuits are used, that turn the gate voltage between 0 and maximum (usually 10 to 20 volts) at speeds in the 100s of nanoseconds.
      An oscilloscope is used to visualize the waveforms in your power supply. It is essential for you to have one if you're serious in doing SMPS work. If done right (1% tolerance resistors in the reference dividers, more on that later), the ripple indicators will work without needing a 'scope to calibrate them, but you'll still want to have one around.
      BTW i decided against using opamps for the ripple and voltage meters, i will use comparators instead, most likely the common LM339, which i hope will be accurate enough. Now you can build the power supply tester from power supply parts!
      • c_hegge
        • Sep 2009
        • 5219
        Couldn't you do it with resistors? I was thinking of doing that if I made one.
        • c_hegge
          • Sep 2009
          • 5219
          OK I've drawn up a quick diagram in paint of what I was thinking. Something like this for each rail.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Of course. But like i said, high power resistors are expensive, and don't offer the degree of control given by an active load. Right now, what i worry about is how much of a difference is actually required to trigger a comparator. LTSpice says it's a bit too much to be useful as a ripple indicator... But real parts are different, of course. We shall see.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              hey th3-uniqu3 did you get progress?
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                So um any luck?
                If you DO do this please make a parts list, schmetics, and how u did it. Then im gonna make one too!
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  I'm not at home atm, will resume work on this thing when i get back (next Wednesday).
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I tried a simulation with IRF530s (as they're cheap), but i will need 8-10 devices per rail, and the more devices in parallel the lower their resistance, which makes them extremely sensitive to gate voltage.
                    The sim shows 200mA load at 4v gate voltage (just above threshold), and 26A at 5v. The voltage range is too narrow and controlling it will get complicated. I'll have to find something with higher RDS(on).
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I did eventually come to terms with the IRF530s and have completed the feedback circuit that keeps the load constant. It uses cheap opamps, a standard TL431 2.5 volt reference, and a 0.001 ohm current sense resistor. So basically the "power" part is done, all it needs now is metering.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Where are you dissipating the heat that is cheaper than resistors?
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          ok whats a irf530s? and a tl431? and i have no clue wtf ur talking about ???
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            In the 'fets internal resistance and some BIG heatsinks. Power resistors are more expensive and harder to find in usable values than a bunch of MOSFETs, at least in this part of the world.
                            Besides, if i don't like it, i can always turn it into a big ass power amplifier.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              They are both MOSFET Model numbers.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Close but not quite. The TL431 is a shunt regulator with 2.5v reference, which is commonly used as a 2.5v voltage reference.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  Can you make a schemtic?
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Yes, that's what i'm working on atm.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      ok
                                      and pictures too maybe?
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        I've decided I will build one too. I'll probably take the somewhat more expensive but easier apporach and use resistors. For now, though, I'm deciding on what resistors to use where and what to house it in, as it will need some fairly large heatsinks.
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
