Hi i have recently got some laptops sold in and have tried to reinstall windows however even after fresh install the laptop requires to sign in via the company email only. is there a way to remove this? all help much appreciated
Company Locked Laptops
Re: Company Locked Laptops
Contact the company who sold them to you and ask them to remove them from their device management system.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic -
Hi these are sold in to second hand stores and are checked to see if they are stolen and are not so when purchased the system was working until was reset to sell onto a customer.
SO bottom line these are useless?Comment
this is probably some "malware" installed in the EFI bios.
so you could try taking a full bios dump and looking at it in a bios editor like this:
https://github.com/LongSoft/UEFIToolComment
Youve already posted a bios unlock request,more than once... https://www.badcaps.net/forum/showthread.php?p=1201219 .If the Lenovo Autopatcher doesn`t work then the only option is unlocking via JTAG, and you`ll need a dedicated programmer to do that.
T14s forum search - https://www.badcaps.net/forum/search...rchid=32154929
P14s forum search - https://www.badcaps.net/forum/search...rchid=32154934
I/O Programmers:
Vertyanov SUCCESSOR
SVOD4
RT809HLast edited by SMDFlea; 01-24-2023, 01:05 PM.Comment
Windows Autopilot
https://learn.microsoft.com/en-us/me...dows-autopilot
Is there a solution? Yes, we make all models here.
Hi the bios request for a different laptop I have 3 the first with a bios password and the other two as explained have a block onto a company which i cannot over come my question is if I get a fresh Bios will this solve the Issue? also you said about if the Auto patcher does not work i need to use JTAG. On which chip? and is there a instruction on this topic?Youve already posted a bios unlock request,more than once... https://www.badcaps.net/forum/showthread.php?p=1201219 .If the Lenovo Autopatcher doesn`t work then the only option is unlocking via JTAG, and you`ll need a dedicated programmer to do that.
I/O Programmers:
Vertyanov SUCCESSOR
SVOD4
RT809HComment
I am considered a noob in this matter even if i did get a dump is there any instruction on what exactly I'm supposed to be looking at? and what I do when I find the problem?this is probably some "malware" installed in the EFI bios.
Easiest would be to install either Linux or Windows Home since Autopilot is a Windows Pro/Enterprise feature and Home/Linux will not check if autopilot is enabled.
There is a more advanced method aswell but since I haven't tried it myself, I won't even comment on that.Comment
when installing the option never pops up to install windows homeEasiest would be to install either Linux or Windows Home since Autopilot is a Windows Pro/Enterprise feature and Home/Linux will not check if autopilot is enabled.
It's Windows Autopilot. The message says "Sign in with Microsoft - School or work account"
I've seen this before on several laptops. You can't bypass the screen, it demands it.
There is workaround - installing very old version of Windows10.
"It seems like" this "thing" writes something into the UEFI. Even complete wipe of the drive and new installation won't do any good. Even if the machine isn't connected to the internet. First it will demand internet connection to continue and wont allow you to create local account. When you connect it to the internet, it will demand you to enter your "work or school account" to continue, without an option to create new microsoft or local account.
I've tried modifying ei.cfg, using different edition, bypassing the screen using OOBE bypass and command prompt to create new account. One can truly call this thing "malware".
Even with enabled default administrator or creating local account or even linking another microsoft account, it continues to demand to enter the old "work or school account".
Unfortunately, there isn't really much information about this. And I am not so keen on dissecting and digging in the bios flash of laptop that isn't my own to analyse the problem.
Surely, rewriting the bios flash will get rid of it. But there is that little issue that most likely this won't be the only thing you will need to rewrite/modify. And information about this is relatively scarce.Last edited by televizora; 01-25-2023, 02:28 PM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34gramsComment
by MTT97Not too long ago i bought a used HP Probook 440 G8 from an online market place. The bios is locked, seller does not know the password so i'd assume it's a company laptop that he got (which is normal here in sweden that you get to keep the device).
I could still access the boot menu and create a fresh install of Windows. However, i just learned about Absolute Persistence and Wolf Security and they could monitor anything you do in Windows, including browser and such. Can someone confirm if that's the worse case? The bios is locked and i can't really confirm if Absolute is enabled/active,...-
by nerujanHello everyone,
I need step-by-step guidance for an issue I’m facing. I’m a technician, and I have several Microsoft Surface Laptop 4 and Surface Laptop 5 devices that were MDM-locked through Autopilot.
There is no BIOS password, and I successfully removed the Autopilot lock using PowerShell. The laptops now work fine, but the BIOS still shows “Managed by: ABC Company” under the Management section.
I would like to know how to remove this management information from the BIOS without changing the serial number. I’ve searched a lot but couldn’t find any...-
Channel: BIOS Requests ONLY!
by test_devI requested support at Lenovo, and they say it will cost around 705 euro to get rid of the bios lock by replacing the mobo.
Lenovo e14 i5 10th gen
"Thank you for getting in touch. On ThinkPad systems, BIOS and Supervisor passwords are security measures that are set exclusively by the end user. For data protection reasons, Lenovo has no way to unlock or reset them.
In cases where the password is not known, the only available service procedure is a complete replacement of the system board; a non-binding cost estimate has already been prepared for you. Please...-
by NanoTestingThis audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.02-21-2025, 12:33 AM -
by SuperAmanI have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...08-31-2024, 07:30 PM - Loading...
