Need help removing “Managed by: ABC Company” from BIOS on Surface Laptop 4 and 5
  • nerujan
    • Apr 2025
    • Sri Lanka
    I need step-by-step guidance for an issue I’m facing. I’m a technician, and I have several Microsoft Surface Laptop 4 and Surface Laptop 5 devices that were MDM-locked through Autopilot.
    There is no BIOS password, and I successfully removed the Autopilot lock using PowerShell. The laptops now work fine, but the BIOS still shows “Managed by: ABC Company” under the Management section.
    I would like to know how to remove this management information from the BIOS without changing the serial number. I’ve searched a lot but couldn’t find any proper guidance.
    Any help or step-by-step instructions would be greatly appreciated.
    Thank you in advance.
  • FalconPunch
    Surface Pro X 1876 Bios corrupted
    by FalconPunch
    Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
    Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
    08-09-2025, 03:56 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • muhuruu
    Surface pro 4 bios request
    by muhuruu
    Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
    01-22-2024, 05:38 AM
    by Vesko356
    08-11-2023, 03:27 AM
