whats better a 3.4 ghz cpu or a 3.8?
  • Phaihn
    • Jan 2009
    • 842
    a 3.8 ghz pentium 4 cpu with 1m / 800 mhz fsb or a 3.4 with 2m / 800 mhz fsb
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • 31047
    Re: whats better a 3.4 ghz cpu or a 3.8?
    the 3.4 will give better performance - the cache size makes a lot of difference.
    • toastygoodness
      • Jul 2005
      • 813
      for sure the 3.4 with 2mb cache. but why p4s? and is it pentium d-core, northwood, or prescott? actually i'm sure its probably prescott, so why prescott? you can probably get an athlon64 or something similar for really cheap and it will be faster.
      • mockingbird
        • Dec 2008
        • 5484
        3.4 with 2mb cache. And this can't be a 478.. The only 478s with 2mb cache that I'm aware of were the Extreme Editions. What he probably has is an LGA775 Pentium D.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I'll always go with more cache.
          The $$ kind too.
          Mann-Made Global Warming.
          - Dr Seuss
          • Phaihn
            • Jan 2009
            • 842
            i dont like amd besides its for a system i got for 50 bucks its a socket 775 mainboard with case no hard drive a dvd rom burner windows xp coa on the case has a celron d in it i want a better cpu thats why besides i like Pentium 4 its gonna be a great upgrade to my main system.
            My Computer.
            • Phaihn
              • Jan 2009
              • 842
              your right but its a 775 celeron d in the case but i want to put in a P4
              My Computer.
              • Phaihn
                • Jan 2009
                • 842
                The $$ kind too.
                yeah thats what i was thinking.
                http://cgi.ebay.ca/Pentium-4-P4-3-8G...227215?pt=CPUs
                http://cgi.ebay.ca/Lot-2-Pentium-4-P...646056?pt=CPUs
                My Computer.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Not to be an ass but what is there to like about the P4?
                  I give you a challenge; find a reputable review where a Core 2 Duo with any stock clockspeed is beaten by a stock Pentium 4
                  Sure it can be done but A Pentium 3 1Ghz is faster than a Pentium 4 in many tests
                  Pentium 3 Tualatin 1.4Ghz can beat the P4 in tests where the P4 approaches 2Ghz
                  The AMD Athlon64 processors eats the P4's for lunch
                  And the Core 2 Duo processors eat the Athlon64's for lunch
                  And you say you have a S775 mobo?
                  Spocks voice: I fail to see the logic in your reasoning
                  • brethin
                    • Dec 2008
                    • 1907
                    They are both socket 775 I am sure. You cant get anything faster than a 3.4 in socket 478 and the 2 meg lvl 3 cache of that chip is a Gallation core which is kinda rare now.
                    As to which is faster it depends on what you are using it for.
                    If its cpu clock speed intensive software (like say EverQuest II) the 3.8 will smoke the 3.4.
                    Are they single core? are they Hyper Threading? are they 32 or 64 bit? are they dual core? are you going to overclock?
                    Model or S-spec #'s of the 2 chips you are comparing along with the intended use would help to provide you with the answer you seek. :P
                    • Phaihn
                      • Jan 2009
                      • 842
                      i dont like AMD simple as that and i am looking at a pentium d too it looks nice but i am not sure waht will be better the pentium do 3.4 or the pentium 4 3.4. pentium d has a 4 mb cache
                      My Computer.
                      • brethin
                        • Dec 2008
                        • 1907
                        Like I said it depends on what its used for. Standard benchmarking yes any newer cpu multi core will beat a faster clocked older chip. But if its used in a app that is based on cpu clock speed (and there are alot out there) the older fast clocked chip will be faster.
                        I have a 3.6 64 bit hyperthreading socket 775 P4 with 1 meg cache in one machine and a 3.4 64 dual core Pentium D 2x2 meg cache in another, other than that they are exactlly the same in all hardware and the 3.6 beats the 3.4 in some apps and the 3.4 beats the 3.6 in others.
                        • Phaihn
                          • Jan 2009
                          • 842
                          yes its a socket 775 well the pentium 4 should be a HT core.. ill probley use it for WOW and a few other multimedia things like music and videos
                          My Computer.
                          • Phaihn
                            • Jan 2009
                            • 842
                            i dont over clock the p4 is a single core the pentium d is duel
                            http://cgi.ebay.ca/INTEL-Pentium-D-9...es_Processeurs
                            My Computer.
                            • Phaihn
                              • Jan 2009
                              • 842
                              and i dont have a 64 bit os just windows XP home so the duel core wont do me any good.
                              My Computer.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                see if your new found board can take a c2d or even the cheap pentium dual core.anything should stomp a presscott.
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  this is waht i got. http://www.intel.com/support/motherb.../cs-026950.htm
                                  D915PCY
                                  the CPU it came with Intel® Celeron® D 331 SL7TV only 2.66 GHz 533 MHz 256 KB
                                  and from the looks of it it wont take a duel core or a pentium d so pentium 4 it is.
                                  My Computer.
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    LGA775 Pentium D is not Pentium 4 at all IIRC but Dothan. Oddly enough, the 865 chipset can take both Pentium 4 (Netburst) chips and Dothan-based chips (Core Duo, etc...). I've seen a motherboard with an 865 that had a socket 775.
                                    • Phaihn
                                      • Jan 2009
                                      • 842
                                      i knew that. :>
                                      My Computer.
                                      • pegdizzler
                                        • Aug 2010
                                        • 19
                                        Unfortunately, Pentium D isn't Dothan at all. =P
                                        Dothan came after Banias (both Pentium M, mainly mobile but some desktop use) which actually was derived from--you guessed it--the P3. Namely, the cool running Tualatins.
                                        The spec sheet for Pentium D is here:
                                        It's Netburst! As Per Hansson and others have stated, P4/Netburst stuff isn't really economical anymore. Sure, one core may be fast, but almost any competing CPU architecture a generation newer OR older than it will be far more efficient. If you don't pay the electric bill, it might not matter to you as much...
