in a ups near you?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    in a ups near you?
    this is a bad case of positive plate growth.
  • japlytic
    • Oct 2005
    • 2086
    Re: in a ups near you?
    This battery was most likely to have not been charged within 3 months.
    I am also aware of a malpractice with lead-acid batteries in new UPS units in stores, which are not charged every 3 months (especially in second-hand ones). This can lead to the battery becoming sulphated, which renders the battery useless, and more expensive for the consumer.
    UPS units (and other equipment with lead-acid batteries) need to have a "sell-by" date (if they are in their box and cannot be recharged without the need to open the box).
    Also, I recommend that the manufacturers of UPS units and other equipment with lead-acid batteries provide a recharging port on the box, so the batteries inside them can be recharged without the need to open the whole box.
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • howardc64
      Where do repair shops buy MB replacement batteries?
      by howardc64
      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
      07-25-2024, 10:42 AM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • dbuergi
      DIY: Modified smart charger for all types of batteries
      by dbuergi
      sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
      Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
      My first work was to bring my Samsung watch battery back to life with was not recognized...
      07-18-2025, 03:17 AM
    • davidebaldini
      UPS ruins batteries every three months
      by davidebaldini
      Problem description:
      My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
      UPS model:
      The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
      10-02-2019, 06:19 AM
