Torroide chokes txrs
  • barry wilkins
    • Aug 2009
    • 172
    Does anybody out there know how these are actually made ?
    I can only assume the wire is wound through the doughnut by hand with the wire on a shuttle .
    Some chokes on power supplies have an awful lots of turns of wire on them ,so are these made by hand by Ladies in Nottingham ,or is there a clever winding machine that makes these coils ?
    Barry Wilkins
  • wnlewis
    New wire for my RDE3340 Whirlpool electric range
    by wnlewis
    OK. I got the rocker switch figured out thanks to the good advice on this forum.
    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
    This is a Whirlpool RDE3340 electric range.
    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
    Where may I find parts...
    01-08-2025, 11:21 PM
  • emeskay
    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
    by emeskay
    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
    08-06-2024, 07:13 AM
  • technicalspecialist
    Vintage fan repair, copper wire question
    by technicalspecialist
    I currently have a customer's vintage fan on the work bench to repair.
    It uses an induction motor with 4 poles. One of the poles is open.
    I couldn't find the break so i cut off the original wire.
    I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
    I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
    The enamelled copper...
    03-16-2023, 12:54 PM
    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
    12-16-2023, 08:39 PM
  • kalemaroni
    Dell DC Brown wire
    by kalemaroni
    There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
    08-26-2025, 10:10 AM
